		yakxx21
				 Posted: Sun Oct 14, 2012 8:55 am    Post subject: Kicked off Russian Register |
				A number of us flying YAK 50's and 52's on Russian RA registers( in Europe)  have been advised that we can no longer stay on such and I was wondering what other owner/operators are doing about this and what might be the best and most economical register to go on...I thought of the N reg but not sure if its possible because I believe the 50 is operated on some sort of experimental class in the States so cannot be done...I looked at UK but that seemed very complicated and expensive....
 Any information please
 ken
 Portugal
		richard.goode(at)russiana Guest
				 Posted: Sun Oct 14, 2012 9:45 am    Post subject: Kicked off Russian Register |
				This is a complex topic with which we have been working for many years.
 Americans are exceedingly lucky to be able to have a genuine "experimental"
 register on which to operate such aircraft.
 The main issues are:
 The Yak 50 and 52 are not certificated aircraft, and as such cannot get a
 normal category certificate of airworthiness.
 The problem with the Russian registration which we and many of our customers
 have used for over 15 years is simply that they gave normal category
 certificates to these aircraft, which are not certificated, so you can see
 the position of our different aviation administrations when they say they
 will not accept the Russian paperwork.
 So, for a non-certificated aircraft, it is up to the country in which it
 flies to issue appropriate paperwork. The problem is that, even in Europe,
 there is absolutely no uniformity about this, and each country has different
 legislation. To be specific, some will issue appropriate paperwork for yak
 50 and 52 and others will not.
 Importantly, whatever paperwork is obtained for such an aircraft, it is only
 valid in the country of issue. That is, a US "experimental unquote aircraft
 has paperwork only valid in the USA, although it can fly in other countries
 but only with the specific permission of the local CAA, and that will not
 always be given.
 So, within Portugal, your first approach must be to go to your local CAA;
 explain that these aircraft are flown safely throughout the world and in
 many European countries; you should examine your local aviation law to see
 what rights you have to fly non-certificated aircraft - for example home
 built; "warbirds" etc. It is quite likely there is a specific category that
 will include these Yaks. For example, within the UK, we are allowed to fly
 them because we were able to persuade our CAA that they are "ex-military".
 As you say, an avenue with UK CAA is complex and expensive, but you might
 like to consider it, but remember that a UK "permit to fly" - i.e.
 "experimental" is only valid in Portugal with the formal permission from
 Portuguese CAA.
 I hope this helps!
 Richard Goode Aerobatics
 Rhodds Farm
 Lyonshall
 Hereford
 HR5 3LW
 Tel:  +44 (0) 1544 340120
 Fax: +44 (0) 1544 340129
 www.russianaeros.com
