toaster73(at)embarqmail.c Guest
Posted: Wed Sep 26, 2012 10:58 am Post subject: AIRCAM Schematic or ideas |
I am beginning to work up an electrical plan for a friends Aircam project, twin Rotax 912's with single battery. Anybody out there have a schematic they would like to share for a twin engine rotax or similar to give me a starting point to look over. I looked at the TECNAM P2006T but I don't think I need the complexity of its system and I do not quite understand the Cross bus switch logic they have. I attached for anyone who wants to comment on it.
Chris Lucas
N919AR
RV-10 and Aircam helper
 Download |
| Filename: |
p2006t_manualas_123.pdf |
91.33 KB |
| Downloaded: |
537 Time(s) |
Posted: Wed Sep 26, 2012 12:01 pm Post subject: AIRCAM Schematic or ideas |
At 01:57 PM 9/26/2012, you wrote:
| Quote: | I am beginning to work up an electrical plan for a friends Aircam
Obviously, this is a day, fair-weather, vmc fun
machine. There's no obvious value srtiving for
a very failure tolerant system. Suggest you wire
like figure Z16
http://tinyurl.com/7vp9g4e
Except you have two-fat wire feeders to the
starter contactors at the engines. These
same feeders just happen to be a good way
to bring each alternator in to the battery.
Run one alternator at a time with second
for back up.
| Quote: | I attached for anyone who wants to comment on it.
Busy . . .
Posted: Wed Sep 26, 2012 3:17 pm Post subject: AIRCAM Schematic or ideas |
Thanks Bob, Z16 is where I was headed but wondered if I was missing something with "twin engines". Definitely not a machine with a need for complexity.
One clarification... when you say run one alternator at a time do you mean just switch one of the alternators off? How does keeping the designated backup off improve system reliability or procedures?
Busy is a good word for the Tecnam.
-Chris
Posted: Wed Sep 26, 2012 4:56 pm Post subject: AIRCAM Schematic or ideas |
At 06:14 PM 9/26/2012, you wrote:
for complexity.
Those alternators are designed to run in parallel on a
single bus. Given the sledge-hammer approach to voltage
regulation, it probably wouldn't hurt anything. At the
same time, if one alternator crapped and both were on,
you wouldn't get a low voltage warning annunciating
the failure. You might land with a dead alternator
and not know it until next preflight.
Better to run one alternator at a time. If it craps,
you've got a second alternator which you'll turn on
when the low voltage warning light flashes . . .
you DO plane active notification of low voltage?
Posted: Wed Sep 26, 2012 7:48 pm Post subject: AIRCAM Schematic or ideas |
CORRECTION
| Quote: | Those alternators are NOT designed to run in parallel on a
single bus.
Posted: Thu Sep 27, 2012 5:52 pm Post subject: AIRCAM Schematic or ideas |
Correction noted.
thanks
Chris
Posted: Fri Sep 28, 2012 7:53 am Post subject: AIRCAM Schematic or ideas |
At 08:51 PM 9/27/2012, you wrote:
Correction noted.
thanks
Chris
If it were my airplane . . .
http://tinyurl.com/cf2ppmx
http://tinyurl.com/cg8falj
Posted: Sat Sep 29, 2012 4:12 pm Post subject: AIRCAM Schematic or ideas |
Thank you Bob, that is very helpful. Can you explain what happens if the
"standby" alternator is activated while the "main" is active?
Chris
nuckollsr
Joined: 24 Mar 2009 Posts: 95 Location: Medicine Lodge, KS
Posted: Sat Sep 29, 2012 7:02 pm Post subject: Re: AIRCAM Schematic or ideas |
Probably nothing serious. But it might mask failure of one alternator when the second one shoulders the loads. A failure that become latent and unnoticed until next preflight. Better that you know it before you land as opposed to just before you wanted to take off.
Posted: Sun Sep 30, 2012 4:59 am Post subject: AIRCAM Schematic or ideas |
Right, but I was picking up on your comment that the "alternators are not
designed to run parallel on a single bus".
I have been wondering if there is a load sharing problem that would be
encountered or any other electrical gremlins I am not smart enough to know
about.
Chris
