oldjagman(at)yahoo.com Guest
Posted: Wed Sep 19, 2012 6:25 pm Post subject: Left\Right Fuel Systems? |
John
The Cessna 150's and 172's do the same thing.
There's too much fuel in the tank. Heat of the day will also
expand the fuel volume, if re-fueled in the evening,
or early morning.
Try a little less fuel ...a gallon or two is all.
I doubt valves, unless you put them in a vent line...(DON'T!) will help.
Charlie NJ
| Quote: | From: John Marzulli <john.marzulli(at)gmail.com>
Sent: Wednesday, September 19, 2012 7:44 PM
Subject: Re: Left\Right Fuel Systems?
Thanks all for the input...
The main grip is really not uneven feeding during flight, it is the sloshing of fuel on the ground.
If I fuel up for a long flight and taxi on un-even ground there is the very real possibility ( IE it HAS happened to me) for fuel to come out of the vents on the ground.
John Marzulli
http://MarzulliPhoto.net/
http://701Builder.blogspot.com/
On Wed, Sep 19, 2012 at 4:25 PM, <NYTerminat(at)aol.com (NYTerminat(at)aol.com)> wrote:
| Quote: | I am pretty sure those are the ones that I used. Use a tubing bender to prevent kinks in the tube.
Bob Spudis
In a message dated 9/19/2012 7:17:09 P.M. Eastern Daylight Time, craig(at)craigandjean.com (craig(at)craigandjean.com) writes:
| Quote: | Wag-Aero sells a cap with the tube. It is delivered straight. You install it on your tank, clock it to the closed position and then bend the vent pipe to face forward. As I recall people “tune” the pressure to prevent over-pressure by varying the angle of the forward-facing tube downward. The price of $38.95 seems high.
Ram Air Pressure Cap, SKU: E-481-000
http://store.wagaero.com/product_info.php?products_id=8107
-- Craig
ist" target="_blank">http://www.matronics.com/Navigator?Zenith701801-List
tp://forums.matronics.com
http://www.matronics.com/Navigator?Zenith701801-Listhttp://=======================
