Button For Exterior Door Handle C-1007
sean(at)stephensville.com
PostPosted: Fri Sep 07, 2012 8:48 am    Post subject: Button For Exterior Door Handle C-1007 Reply with quote
Anyone fab a button, cover, whatever that fits over the C-1007 that is
depressed to rotate the exterior door handle? Seems odd that there's
nothing that covers the hole and it may be uncomfortable to press it.
-Sean #40303 (finishing cabin top interior)
aerosport1
PostPosted: Fri Sep 07, 2012 9:12 am    Post subject: Button For Exterior Door Handle C-1007 Reply with quote
Here is what I did. Made a little aluminum cap that pressed into the rod.
Looks good and
Is easy on the thumb
Geoff
Geoff Combs
Aerosport Modeling and Design
8090 howe industrial pkwy
canal winchester, ohio 43110
614.834.5227p
614.834.5230f
www.aerosportmodeling.com
 Filesize:  354.96 KB
 Viewed:  12178 Time(s)
Geoff Combs
RV-10 QB N829GW
Flying 500 hrs
40033
Jim Berry
PostPosted: Fri Sep 07, 2012 9:25 am    Post subject: Re: Button For Exterior Door Handle C-1007 Reply with quote
I used a nylon button from HD, held in place with some RTV.
Jim Berry
N15JB
rv10flyer(at)verizon.net
PostPosted: Fri Sep 07, 2012 9:41 am    Post subject: Button For Exterior Door Handle C-1007 Reply with quote
I used a plastic cover from HD as well. Sorry can not locate the part number
nor which section I got it from.
coop85(at)verizon.net
PostPosted: Fri Sep 07, 2012 9:43 am    Post subject: Button For Exterior Door Handle C-1007 Reply with quote
Geoff,
That looks really nice! And the polished handle looks very good too, well done. Just more stuff to add to my list of things to spruce up now that I've had the airplane flying for a number of years.
Marcus
On Sep 7, 2012, at 1:11 PM, "Geoff Combs" <g.combs(at)aerosportmodeling.com> wrote:
Looks good and
Geoff
Geoff Combs
614.834.5227p
614.834.5230f
toaster73(at)embarqmail.c
PostPosted: Fri Sep 07, 2012 4:38 pm    Post subject: Button For Exterior Door Handle C-1007 Reply with quote
I could have sworn the kit came with a little plastic cap that I pressed
into the button hole - don't recall having to source from HD or anywhere.
Only thing I don't like now is that the shaft has a little corrosion ring
around it.
-Chris
N919AR
n223rv(at)wolflakeairport
PostPosted: Fri Sep 07, 2012 7:18 pm    Post subject: Button For Exterior Door Handle C-1007 Reply with quote
Mine also have this nylon button. Came with my kit....
-Mike Kraus
RV-10 Flying
around it.
-Chris
N919AR
 Filesize:  89.94 KB
 Viewed:  12147 Time(s)
bill.peyton
PostPosted: Sat Sep 08, 2012 3:31 am    Post subject: Re: Button For Exterior Door Handle C-1007 Reply with quote
The part number of the button that Vans provides is C-1015
Bill
WA0SYV
Aviation Partners, LLC
amekler
PostPosted: Sat Sep 08, 2012 4:07 am    Post subject: Button For Exterior Door Handle C-1007 Reply with quote
Mike,
Where did you get the door open decal?
Alan
On Sep 7, 2012, at 11:18 PM, Michael Kraus <n223rv(at)wolflakeairport.net> wrote:
[quote] Mine also have this nylon button. Came with my kit....
-Mike Kraus
RV-10 Flying
<image.jpeg>
> around it.
> -Chris
> N919AR
PostPosted: Sat Sep 08, 2012 4:44 am    Post subject: Button For Exterior Door Handle C-1007 Reply with quote
Aircraft Spruce, or make one yourself.
http://www.aircraftspruce.com/catalog/fbpages/FBoearrow.php
PostPosted: Sat Sep 08, 2012 7:54 am    Post subject: Button For Exterior Door Handle C-1007 Reply with quote
Interesting. That part is in bag 1547, but I can't locate anything in
the plans for that.
Thanks all for the insight.
-Sean
Bill
WA0SYV
http://forums.matronics.com/viewtopic.php?p=382663#382663
PostPosted: Sat Sep 08, 2012 3:25 pm    Post subject: Button For Exterior Door Handle C-1007 Reply with quote
I purchased the decals from Vans, it's in their catalog.
On Sep 8, 2012, at 8:07 AM, Alan Mekler MD <amekler(at)metrocast.net> wrote:
Mike,
Alan
> -Mike Kraus
> RV-10 Flying
> <image.jpeg>
> Sent from my iPhone
>> around it.
>> -Chris
>> N919AR
amekler
PostPosted: Sat Sep 08, 2012 3:33 pm    Post subject: Button For Exterior Door Handle C-1007 Reply with quote
Mike,
Thanks.
Alan
On Sep 8, 2012, at 7:24 PM, Michael Kraus <n223rv(at)wolflakeairport.net> wrote:
> Mike,
> Alan
> Sent from my iPhone
>> -Mike Kraus
>> RV-10 Flying
>> <image.jpeg>
>> Sent from my iPhone
>>> around it.
>>> -Chris
>>> N919AR
amekler
PostPosted: Sun Sep 09, 2012 9:02 am    Post subject: Button For Exterior Door Handle C-1007 Reply with quote
Mike,
just went to order door decals and i noticed my door opens(clockwise) the opposite direction of yours.??
Alan
On Sep 8, 2012, at 7:33 PM, Alan Mekler MD <amekler(at)metrocast.net> wrote:
Mike,
Thanks.
Alan
> Sent from my iPhone
>> Mike,
>> Alan
>> Sent from my iPhone
>>> -Mike Kraus
>>> RV-10 Flying
>>> <image.jpeg>
>>> Sent from my iPhone
>>>> around it.
>>>> -Chris
>>>> N919AR
PostPosted: Sun Sep 09, 2012 9:41 am    Post subject: Button For Exterior Door Handle C-1007 Reply with quote
Hmmmm, mine definitely turn counter clockwise to open. You might want to re-check yours, I don't think it should be any different.
On Sep 9, 2012, at 1:01 PM, Alan Mekler MD <amekler(at)metrocast.net> wrote:
Mike,
Alan
> Mike,
> Thanks.
> Alan
>> Sent from my iPhone
>>> Mike,
>>> Alan
>>> Sent from my iPhone
>>>> -Mike Kraus
>>>> RV-10 Flying
>>>> <image.jpeg>
>>>> Sent from my iPhone
>>>>> around it.
>>>>> -Chris
>>>>> N919AR
Tim Olson
PostPosted: Sun Sep 09, 2012 10:10 am    Post subject: Button For Exterior Door Handle C-1007 Reply with quote
Hmmm, how many sides does and RV10 have? Do they BOTH open clockwise or both open counterclockwise?
On Sep 9, 2012, at 12:41 PM, Michael Kraus <n223rv(at)wolflakeairport.net> wrote:
> Mike,
> Alan
>> Mike,
>> Thanks.
>> Alan
>>> Sent from my iPhone
>>>> Mike,
>>>> Alan
>>>> Sent from my iPhone
>>>>> -Mike Kraus
>>>>> RV-10 Flying
>>>>> <image.jpeg>
>>>>> Sent from my iPhone
>>>>>> around it.
>>>>>> -Chris
>>>>>> N919AR
amekler
PostPosted: Sun Sep 09, 2012 10:33 am    Post subject: Button For Exterior Door Handle C-1007 Reply with quote
My pilots side opens clockwise
My copilots side opens counterclokwise
Both sides it is a down direction.
Alan
> Sent from my iPhone
>> Mike,
>> Alan
>>> Mike,
>>> Thanks.
>>> Alan
>>>> Sent from my iPhone
>>>>> Mike,
>>>>> Alan
>>>>> Sent from my iPhone
>>>>>> -Mike Kraus
>>>>>> RV-10 Flying
>>>>>> <image.jpeg>
>>>>>> Sent from my iPhone
>>>>>>> around it.
>>>>>>> -Chris
>>>>>>> N919AR
PostPosted: Sun Sep 09, 2012 1:16 pm    Post subject: Button For Exterior Door Handle C-1007 Reply with quote
Yes, that is how mine work. Sorry for the mistake. The picture I posted was of the pass side. It opens CCW. Pilot side opens clockwise. You need to buy one of each decal.
-Mike Kraus
Alan
>> Sent from my iPhone
>>> Mike,
>>> Alan
>>>> Mike,
>>>> Thanks.
>>>> Alan
>>>>> Sent from my iPhone
>>>>>> Mike,
>>>>>> Alan
>>>>>> Sent from my iPhone
>>>>>>> -Mike Kraus
>>>>>>> RV-10 Flying
>>>>>>> <image.jpeg>
>>>>>>> Sent from my iPhone
>>>>>>>> around it.
>>>>>>>> -Chris
>>>>>>>> N919AR
amekler
PostPosted: Sun Sep 09, 2012 1:31 pm    Post subject: Button For Exterior Door Handle C-1007 Reply with quote
Mike ,
Thanks to Tim's post I went down to the plane and noticed the difference. I always get in the pilot side and unlock the passenger door from the inside.
Alan
Just assumed they
On Sep 9, 2012, at 5:15 PM, Michael Kraus <n223rv(at)wolflakeairport.net> wrote:
-Mike Kraus
> Alan
> Sent from my iPhone
>>> Sent from my iPhone
>>>> Mike,
>>>> Alan
>>>>> Mike,
>>>>> Thanks.
>>>>> Alan
>>>>>> Sent from my iPhone
>>>>>>> Mike,
>>>>>>> Alan
>>>>>>> Sent from my iPhone
>>>>>>>> -Mike Kraus
>>>>>>>> RV-10 Flying
>>>>>>>> <image.jpeg>
>>>>>>>> Sent from my iPhone
>>>>>>>>> around it.
>>>>>>>>> -Chris
>>>>>>>>> N919AR
rv10flyer
PostPosted: Sun Sep 09, 2012 7:09 pm    Post subject: Re: Button For Exterior Door Handle C-1007 Reply with quote
The tube should be made from SS to prevent rusting. I used proseal in the hole, cured, sanded, painted. Since I don't have SS, I just keep it lubricated.
Wayne G.
