AeroElectric-List: Main contactor to starter contactor conne
BobsV35B(at)aol.com
PostPosted: Tue Aug 28, 2012 3:00 pm    Post subject: AeroElectric-List: Main contactor to starter contactor conne Reply with quote
Good Evening Michael,
I think the bend is OK, but I would suggest you try to support it at the apex of the curve to reduce the potential for failure at a fitting.
Happy Skies,
Old Bob
In a message dated 8/28/2012 12:58:36 P.M. Central Daylight Time, mburbidg(at)gmail.com writes:
Hi Folks,
I'm using a short length of battery type cable made by B&C to connect my main contactor to the starter contactor. Both contactors are from B&C. The orientation of the terminal bolts on the contactors does not make for using copper bar easily.
I've enclosed a picture. My question is, do you the think the radius of the bend will put too much stress on this wire? If so, what would you suggest?
Michael-
 Filesize:  24.57 KB
 Viewed:  1106 Time(s)
 Filesize:  31.42 KB
