flysrv10(at)gmail.com Guest
Posted: Mon Aug 27, 2012 4:23 pm Post subject: Plane-Power Alternator use |
Hello All,
Anyone using PP 30 Amp accessory mount alternator as a primary?
If so, any comments?
RobK
Begin forwarded message:
| Quote: | From: "Dick Carmichael" <stc(at)planepower.com (stc(at)planepower.com)>
Subject: Plane-Power
Date: August 27, 2012 10:09:18 AM EDT
To: <FlysRV10(at)gmail.com (FlysRV10(at)gmail.com)>
Rob:
See attached. The FS1-14 and FS1-14B are the same size. Only the internal regulator is diifferent. (13.6v vs 14.3v)
Dick
FS1-14_TYPICAL_DIMENSIONS.pdf |
104.02 KB |
435 Time(s) |
FS1-14B_Installation_Instructions.pdf |
106.64 KB |
756 Time(s) |
rv10flyer
Posted: Thu Aug 30, 2012 7:05 pm Post subject: Re: Plane-Power Alternator use |
No way that I could as I am recharging a pc925, pc680 and powering an IFR panel pulling 50-55 Amps after start.
_________________ Wayne G. |
