brian
Joined: 02 Jan 2006 Posts: 643 Location: Sacramento, California, USA
Posted: Fri Jan 13, 2006 1:15 pm Post subject: EFIS Comparisons |
Bruce Gray wrote:
Quote: |
No, No, No. You want dual AHRS, with an electronic comparator hopefully. No
if it's a VFR ONLY airplane, anything goes.
My brain is the comparator. I have to compare the display from the
EFIS-1 to the Dynon or 3-pack and make a decision as to which is right.
Brian Lloyd
brian-yak at lloyd dot com
_________________ Brian Lloyd
- Antoine de Saint-Exupery |
cjensen(at)dts9000.com Guest
Posted: Fri Jan 13, 2006 1:56 pm Post subject: EFIS Comparisons |
Alan,
This was just poking a bit of fun at the idea of two AHRS giving one
true redundancy. In the case of the reference to the Crossbow AHRS,
right now if you have two....you have none, since the AD has taken them
out of service due to an identified deficiency which can make them
fail--hence unreliable for IFR work. So, in this instance, having two
of the same thing doesn't double your reliability.
Note: This was not a slam on the Crossbow. Just recognition that they
have a problem right now that they are working to resolve. How they fix
it and how they interact with their customers which they have
inconvenienced will be more revealing of their character than any flaw
that might have been missed despite certification testing and their best
design and QA efforts. Stuff happens.
To close out these ramblings, two of something, especially of the same
thing, does not constitute true redundancy of systems as they may share
the same fail-points.
Chuck Jensen
<aadamson(at)highrf.com>
QUOTE: As an example....if you have two Crossbow AHRS, what do you have?
END QUOTE:
Not sure what that is suppose to mean.... It means the same thing
whether
you have two Crossbow, or GRT, or BMI, or XYZ company AHRS.
aadamson(at)highrf.com Guest
Posted: Fri Jan 13, 2006 2:46 pm Post subject: EFIS Comparisons |
Yes, but Chuck, let's make sure we have the correct information... The
certified version, the Crossbow 500 which ships in the certified Chelton
(and others), does *NOT* have the problem. There currently exists *NO* AD,
that I'm aware of.
The experimental EFIS companies that utilize the 425 series crossbow AHRS,
do have a problem, but it only exists as a service letter from crossbow at
the moment. Because there are none of these in certified airplanes, there
will never be an AD issued. So, this makes the crossbow problem, no
different than the "leaning" problem that BMA, Dynon, GRT, etc have at any
moments notice. You are advised of the problem, suggested that you use the
equipment for VFR only, but not grounded.
http://www.d2av.com/news_images/Service_Letter_NAV425_010506.pdf
Alan
jschroeder(at)perigee.net Guest
Posted: Fri Jan 13, 2006 2:54 pm Post subject: EFIS Comparisons |
Brian -
We have the EFIS/ONE and the Dynon D-10A as the backup. So far, it has
been fairly straight forward to install and check out. I just wish we
didn't have to fool around with all those pesky voltage dividers. There
are 18 resistors and a bunch of connections to add to the parts count.
Since we want to fly and file IFR, the major concern we have is putting
too many functions in one box (EFIS/ONE CPU). We decided against having
the BMA autopilot and installed a TruTrak DFC-250. This is controlled for
navigation purposes by a separate, certified IFR enroute and terminal
GPS/Com/Nav. The BMA GPS is simply not very powerful, especially with
entering and storing flight plans and is not certified for IFR navigation.
We wired the GPS to a separate CDI for legal IFR approaches. To make the
EFIS/ONE capable of monitoring a 6 cyl Continental, we would have had to
buy the extra card and still not have the value of features dedicated
engine data monitors, such as lean find. So we installed a JPI EDM 700 for
that. We also tapped off an oil pressure sender to run both the Hobbs and
a low oil pressure light. Finally, we installed a Proprietary Systems
Software AOA that is separate from most everything except the pitot and
systems.
Just another approach by two other OBAM builders. We did install Bob's
Z-14 as written.
Good to have you back on this list.
John Schroeder
Lancair ES - Painting
On Fri, 13 Jan 2006 13:11:36 -0800, Brian Lloyd <brian-yak(at)lloyd.com>
wrote:
Quote: | You sound like you are on the right track. I am debating between a Dynon
D-10 and a 3-pack for my backup. Decisions, decisions ...
brinker(at)cox-internet.c Guest
Posted: Fri Jan 13, 2006 3:02 pm Post subject: EFIS Comparisons |
The GRT will also display the HSI from the SL30. And will tune the
SL30 from the MFD. Not to mention ILS and Localizer And will display your
engine monitor to either display you choose. Not sure how you get 6k for
engine monitoring. Last I checked a 6cyl was around $1100 with EIS and
probes. GRT is very helpful if there is a way to make it work they will try.
I have a KLN90B gps that Todd is trying figure out if it will work with
they're system now. It looks favorable, I am keeping my fingures and toes
crossed.
Randy
BobsV35B(at)aol.com Guest
Posted: Fri Jan 13, 2006 3:22 pm Post subject: EFIS Comparisons |
In a message dated 1/13/2006 5:06:21 P.M. Central Standard Time,
harley(at)agelesswings.com writes:
Can't let it go without mentioning these new guys based right down the
field from my hangar:
http://xerionavionix.com/
Harley Dixon
Long EZ N28EZ
Canandaigua, NY
Good Evening Harley,
It sure looked good at Oshkosh. How are they doing?
Happy Skies,
Old Bob
AKA
Bob Siegfried
Ancient Aviator
Stearman N3977A
Brookeridge Air Park LL22
Downers Grove, IL 60516
630 985-8503
Posted: Fri Jan 13, 2006 3:24 pm Post subject: EFIS Comparisons |
Just curious, why a separate CDI for IFR approahes if the BMA
show's CDI on screen ?
harley(at)AgelessWings.co Guest
Posted: Fri Jan 13, 2006 6:00 pm Post subject: EFIS Comparisons |
>>How are they doing?<<
Well...they're new! <G>
I haven't been back there in awhile, what with winter and all, but the
last time I was, they were discussing the installation of their unit in
a couple of local birds for testing, and to train the two pilots so they
could be field reps, I would guess.
The VP stopped in to see my plane, and tried to talk me into one, as
well, but I have already purchased another brand ...and I probably
wouldn't be installing it in a time frame that they could use.
He did tell me that they are looking at certification for one of their
models in April or May. Then they'll have units available for both
certified and non-certified installations.
They have an assembly/test area and offices set up on the second floor
of the main hangar at Canandaigua. Still pretty small...but that's how
flying started, didn't it? <G>
Harley
Harley Dixon
Long EZ N28EZ
Canandaigua, NY
Happy Skies,
Old Bob
AKA
Bob Siegfried
Ancient Aviator
Stearman N3977A
630 985-8503
Posted: Fri Jan 13, 2006 6:23 pm Post subject: EFIS Comparisons |
I know that the GAMI & Advanced Pilot Seminar guys are very interested in
this engine monitor. They think it has the potential to be one of the
best, if not the best, on the market.
John Schroeder
On Fri, 13 Jan 2006 21:00:00 -0500, Harley <harley(at)AgelessWings.com> wrote:
Harley
> Harley Dixon
> Long EZ N28EZ
> Canandaigua, NY
> Do Not Archive
> Happy Skies,
> Old Bob
> AKA
> Bob Siegfried
> Ancient Aviator
> Stearman N3977A
> 630 985-8503
Posted: Sat Jan 14, 2006 6:35 am Post subject: EFIS Comparisons |
Alan,
You are accurate all around, first, that the problem is only on the
non-certified Crossbow (which is still likely of greatest interest to
most AE posters) and second, other manufacturer and their product often
have problems also as they grow and mature.
The POINT I was too subtlety (or inartfully) intending to make has not
changed, namely that two of the same thing (i.e. AHRS) do not give true
redundancy. Ask the guy that hooked two AIs up to the same vacuum
system how the flying was when the vacuum pump turned to dust. It's
just a system design consideration. For instance (with NO technical
basis to support these numbers), two AHRAS from the same manufacturing
run, of the same model with the same software from the same bus system
may improve reliability/availability 10% to 25%--certainly not 100%.
Chuck
AD,
that I'm aware of.
AHRS,
at
there
any
the
Alan
--> <cjensen(at)dts9000.com>
Alan,
true
redundancy. In the case of the reference to the Crossbow AHRS, right
now if
you have two....you have none, since the AD has taken them out of
service
due to an identified deficiency which can make them fail--hence
unreliable
for IFR work. So, in this instance, having two of the same thing
doesn't
have
a problem right now that they are working to resolve. How they fix it
and
how they interact with their customers which they have inconvenienced
will
be more revealing of their character than any flaw that might have been
missed despite certification testing and their best design and QA
efforts.
Stuff happens.
the
same fail-points.
Chuck Jensen
END QUOTE:
whether
Bruce(at)glasair.org Guest
Posted: Sat Jan 14, 2006 6:51 am Post subject: EFIS Comparisons |
Well then I guess all those Part 121 airplanes flying around out there with
dual independent EFIS with an electronic comparator/alerter and a third gyro
(tie breaker) are all wrong.
Bruce
www.glasair.org
Posted: Sat Jan 14, 2006 7:15 am Post subject: EFIS Comparisons |
Nope. Not wrong, just expensive. OBAM aircraft are probably somewhat
more interested in something a little more pedestrian (and affordable
than) than "dual independent EFIS with an electronic comparator/alerter
and a third gyro
(tie breaker)." Heck, I'm still trying to figure out the nuances of the
discussion on wiring the master switch.
Our mission profile requires a craft a bit less teched-out than a Part
121 airplane, but for anyone that it trips-their-trigger, then by all
means......
Chuck Jensen
<Bruce(at)glasair.org>
with
gyro
Bruce
www.glasair.org
Posted: Sat Jan 14, 2006 7:26 am Post subject: EFIS Comparisons |
Now, that is exactly the point... And I couldn't agree more! Sorry, I just
took exception to the dig (what appeared to be) at crossbow.
Alan
Posted: Sat Jan 14, 2006 7:46 am Post subject: EFIS Comparisons |
OK, I can understand that.
I hope you've been following the EFIS discussion on this list. Let me beat
my drum one more time.
These low cost EFIS displays (Pick your favorite) are hypnotic and
compelling, if cross checks start to disagree, the pilot is going to want to
keep on flying that pretty EFIS unless you hit him over the head. We don't
know all their failure modes and their software (with the exception of
Chelton) remains untested to the extent necessary to pass DO 178, their
hardware is not DO 160 certified. That means you're the beta tester. Do you
want to bet your life in that situation? Mark my words, we're going to have
some experimental airplanes equipped with low cost EFIS systems get into
some serious fatal trouble. That body count is going to raise the level of
visibility of this issue with the FAA and soon big brother will be breathing
down our necks.
Low cost, noncertified EFIS system are OK for VFR airplanes. But stay out of
IFR conditions.
Bruce
www.glasair.org
Posted: Sat Jan 14, 2006 8:32 am Post subject: EFIS Comparisons |
beat
want to
don't
you
have
of
breathing
down our necks.
out of
IFR conditions.
Bruce
At the risk of further pounding on this dead horse whose meat is already
well-tenderized, the admonishment to avoid the noncertified EFIS for IFR
is a bit broad (IMHO). I fly with a dual GRT EFIS (this does not give
me redundancy, just contemporary PFD and EIS display) driven by a single
AHRS. For redundancy, I rely on old round AS, Alt and vertical compass
and, most importantly, a Mid-Continent AI with its own internal battery.
Secondary redundancy (but reliant on the same electrical system as the
AHRS/EFIS is a TruTrak A/P which will take me where I want to go as long
as the lights are on.
So, I would concede your proposition with just a bit of technical
modification, "low cost, noncertified EFIS systems are okay for VFR
airplanes but stay out of IFR conditions unless you have a well thought
out, well designed redundant primary flight system." But of course, I
would make the same admonishment for a certified EFIS!
Chuck
Posted: Sat Jan 14, 2006 8:56 am Post subject: EFIS Comparisons |
Which is exactly why there are zero certified EFIS systems that are
certified as *primary* (in small single engines anyway). The G1000 in my
C182, is specified as secondary, the primary instruments are the AS, AI, ALT
- regular old vacuum driven 3.125" steam gauges...
Alan
Posted: Sat Jan 14, 2006 9:16 am Post subject: EFIS Comparisons |
Quite often, in discussions like these, we tend to be hardware orientated
and totally overlook the human factors engineering in the systems. With your
dual GRT EFIS you're a step ahead of most. Are you cross checking as part of
your normal scan?
Again, the part of this equation that most worries me is (except in black
screen failures) the time it takes the pilot to realize that something is
seriously wrong, determine the failed instrument, and take corrective
action. In some stages of IFR flight that amount of time will just not be
there. If the ADI rolls inverted at 8,000 feet when you're on top, no
problem. But if you're 300 AGL on the ILS?? This is the main reason for dual
systems/electronic comparator/3rd gyro, to give you a chance to survive when
time is of the essence.
You're free to fly with whatever you want as long as it fits your comfort
level. But when I see builders wanting to charge off into hard IFR with a
BMA, T&B, and ASI, I just got to say - Are you sure you want to do this?
Bruce
www.glasair.org
Posted: Sat Jan 14, 2006 9:24 am Post subject: EFIS Comparisons |
Good point. I'm going to check with Garmin, Chelton, and Avidyne and get the
certification status of their systems.
Bruce
www.glasair.org
Posted: Sat Jan 14, 2006 12:24 pm Post subject: EFIS Comparisons |
Alan -
Try this link on the BMA board:
http://www.bluemountainavionics.com/talk/showthread.php?t=127
It has the ref and cite for the EAA paper.
As I understand it, you can legally do an IFR ILS or VOR approach using
external VOR/ILS inputs connected to the EFIS/ONE. However, as I read this
thread and understand the BMA EFIS, you cannot use the GPS for anything
other than navigation assistance. Thus, if one wants to navigate and do
approaches IFR using GPS, the box has to meet more stringent criteria. I
have not found the reference yet, but I believe that a WAAS approach using
a GNS 480 has to have an OBS/CDI. We wired our 480 to an MD200-306(?). The
EFIS/ONE cannot provide this because it cannot communicate fully with the
480. The EFIS/ONE is a wonderful piece of equipment and we look forward to
using it. But it is not, in my opinion, a box into which I want to put all
the eggs.
I can't comment on the uncertified Chelton line because I have not
followed or worked with them.
John
Quote: | <aadamson(at)highrf.com>
John, I might be wrong and just went to look on the BMA site. I didn't
find
anything specifically, nor did I find it on or searching around the EAA
site.
Can you post a link? You sure you aren't confusing the issue of using
the
BMA with a CNX-480 and the fact that you can't get all the nav signals
that
are needed, some most are using an external head?
The link to specifics would help if you could please? I'm curious as
well
as I'm going down the road to a chelton panel for a Legacy and want to
make
sure I don't mess up. Guys at D2AV say I don't need and external CDI...
Alan
Posted: Sat Jan 14, 2006 1:33 pm Post subject: EFIS Comparisons |
Ah, ok, now that helps...
Ok, so here is some help. The chelton fully interfaces with the SL-30
(notice I didn't say 480 yet) for resolver info and GS, LOC signals.
Actually it does this via a serial interface. The problem is the 480, which
supposedly uses the same engine as the SL-30, didn't implement the serial
interface the same as the SL-30 and so you can't get all the data to drive
the BMA interface.
You don't technically need an external display, you just need a display that
can give GS and LOC information in an displayable format (could be HSI,
could be HITS, could be up/down, left/right).
Notice I've left alone the conversation about GPS approaches for the moment.
So on an ILS or LOC/VOR approach, the BMA or Chelton can be the only display
if talking to an SL-30. If there is a 480 involved, it most likely needs an
external display due to the limitations of the 480 and it's inability to
provide the signals that the eFIS wants. You actually can do it on the
Chelton, but it requires an expensive ARINC 429 to serial converter.
I'm not going to get into the GPS approach topic. There are a whole set of
issues there. However, if you have a GPS which delivers the right outputs
for either the Chelton or the BMA and it's Approach certified, you don't
technically need the external CDI. There is no requirement that I'm aware
of that specifically requires a TSO'd (don't even think there is a TSO for a
CDI anyway) indicator or switch panel for that matter.
As you can tell, this gets all complicated, and even more so depending on
what radio the EFIS is trying to talk to... But then this isn't an Avionics
forum and I'm not an expert
Thanks tho and I'll go read the links you provided.
Alan
