Plane-Power Alternator use
flysrv10(at)gmail.com
PostPosted: Mon Aug 27, 2012 4:23 pm    Post subject: Plane-Power Alternator use Reply with quote
Hello All,
Anyone using PP 30 Amp accessory mount alternator as a primary?
If so, any comments?
RobK
Begin forwarded message:
From: "Dick Carmichael" <stc(at)planepower.com (stc(at)planepower.com)>
Subject: Plane-Power
Date: August 27, 2012 10:09:18 AM EDT
To: <FlysRV10(at)gmail.com (FlysRV10(at)gmail.com)>
Rob:
See attached. The FS1-14 and FS1-14B are the same size. Only the internal regulator is diifferent. (13.6v vs 14.3v)
Dick
FS1-14_TYPICAL_DIMENSIONS.pdf
 Filename:  FS1-14_TYPICAL_DIMENSIONS.pdf
 Filesize:  104.02 KB
 Downloaded:  420 Time(s)
FS1-14B_Installation_Instructions.pdf
 Filename:  FS1-14B_Installation_Instructions.pdf
 Filesize:  106.64 KB
 Downloaded:  737 Time(s)
rv10flyer
PostPosted: Thu Aug 30, 2012 7:05 pm    Post subject: Re: Plane-Power Alternator use Reply with quote
No way that I could as I am recharging a pc925, pc680 and powering an IFR panel pulling 50-55 Amps after start.
Wayne G.
