Brake cylinders
Bob Wichita
PostPosted: Tue Aug 21, 2012 3:54 am    Post subject: Brake cylinders Reply with quote
Can anyone suggest some good brake cylinders? My cylinders are not
adaptable to a remote resivore. Bleeding the cylinders is a pain and I want
to eliminate this task.
Bob
Bob, Wichita
dougsnash
PostPosted: Tue Aug 21, 2012 4:08 am    Post subject: Brake cylinders Reply with quote
The matcos that come with the kit are fine. Are you bleeding them by pumping fluid up from the wheel like you are supposed too? If you try to bleed like a car it won't work very well.
If you need more info let us know.
Doug M
CH 701
Sent from my iPad
On 2012-08-21, at 6:53 AM, "Bob Gibfried" <rfg842(at)cox.net> wrote:
Can anyone suggest some good brake cylinders? My cylinders are not adaptable to a remote resivore. Bleeding the cylinders is a pain and I want to eliminate this task.
Bob
