kearney
Posted: Sat Aug 11, 2012 2:48 pm Post subject: Glassing Window Transition |
Hi
Somewhere recently I read about using fibreglass tape (RC model) to glass over the gap between the canopy and windows. I did a bit of shopping today and was only able to find tape that was of 6 oz weight. For this application I was thinking that a very light cloth would be appropriate.
Can one of the f/g experts shine some light on what weight of glass I should use. ACS has 1.45 oz "deck" cloth. Would this be appropriate? How may layers should I use…..
Inquiring minds need to know…
Les
#40643 [quote][b]
Dick Sipp
Posted: Sat Aug 11, 2012 3:38 pm Post subject: Glassing Window Transition |
Les, et. al.
I commented on the recent post that I had used one layer of the light weight RC fiberglass tape around the windows. I have some minor cracking now with 430 hours.
I don’t think the light tape has much strength and if it touched at all in the sanding filling process it is probably further weakened. The problem with using heavier or more layers of fiberglass is the build up that would be difficult to contour down to the level of the window and then back into the natural curve of the top. I spent a lot of time on this area; it is tricky to get it to look right if one starts building up the area of the seam.
$.02 worth.
Dick Sipp
N110DV 430 hours
Strasnuts
Joined: 10 Feb 2009 Posts: 502 Location: Salt Lake City, UT
Posted: Sat Aug 11, 2012 3:55 pm Post subject: Glassing Window Transition |
I put two layers of thick glass around mine after others had cracking around the windows from using rc glass. It took me a long time to contour mine and ready it for paint. The paint shop I took it to sanded down most of my work and the windows started to show the seams after 50 hours. I took mine back to the paint shop and made them take off the paint and build back up the seams around the windows. They re-sprayed it and now I think it will remain uncracked.
_________________ 40936
RV-10 SB N801VR Flying
780 Hours
SuperSTOL 60 hours |
rleffler
Posted: Sun Aug 12, 2012 3:33 am Post subject: Glassing Window Transition |
I did the same as Sean. Dan Horton has a good write up on VAF on how to contour the transition with several layers of tape. That process works well. The one recommendation I would have would be to use different colors of tape so that you can better see when you sand through the top layer.
On Aug 11, 2012, at 7:54 PM, "Seano" <sean(at)braunandco.com (sean(at)braunandco.com)> wrote:
[quote] Glassing Window Transition I put two layers of thick glass around mine after others had cracking around the windows from using rc glass. It took me a long time to contour mine and ready it for paint. The paint shop I took it to sanded down most of my work and the windows started to show the seams after 50 hours. I took mine back to the paint shop and made them take off the paint and build back up the seams around the windows. They re-sprayed it and now I think it will remain uncracked.
_________________ Bob Leffler
N410BL - Phase I
http://mykitlog.com/rleffler |
AirMike
Posted: Sun Aug 12, 2012 8:24 am Post subject: Glassing Window Transition |
I used a lot of microbaloons in my epoxy/tape mix. Holding up well after (150hrs) 3 years.
_________________ See you OSH '18
Q/B - sold. |
Ron B.
Posted: Sun Aug 12, 2012 10:48 am Post subject: Re: Glassing Window Transition |
Exact same experience as Dick Sipp only with less hrs. I would use heavier cloth and make sure I did not sand it off.
tsts4
Posted: Mon Aug 13, 2012 6:40 am Post subject: Re: Glassing Window Transition |
Anyone have pics or video of the glassing process? What I'm trying to figure out is the mechanics of the glass strips. Is each layer cut in one piece to conform to the window's shape or multiple strips that are butted together until the entire gap is covered?
_________________ Todd Stovall
aka "Auburntsts" on EAA and VAF
RV-10 N728TT -- Flying |
Strasnuts
Posted: Mon Aug 13, 2012 6:59 am Post subject: Glassing Window Transition |
Probably a better way than how I did it but I overlapped so there were two
layers and the seams were offset.
780 Hours
Lew Gallagher
Joined: 04 Jan 2008 Posts: 402 Location: Greenville , SC
Posted: Mon Aug 13, 2012 7:09 am Post subject: Glassing Window Transition |
Hey Todd, et al,
I think I've still got pictures, but not on this computer. This discussion
has been posted in the past, here goes again. What I've done is to use a
right angle air die grinder with a 2" sanding pad to grind out a slight
shallow in the plexi and fiberglass overlapping the joint (after the plexi
is glued in). Maybe 3/4" wide, 1/16" deep. Think edge of sheetrock that
is tapered so that you can mud in tape and be flush when sanded. I glass in
cloth (don't know what thickness, just whatever I've used for everything
else from West Systems!) in this shallow, butting around corners, at full
strength, then finish it out with micro balloon slurry, sand flush (doesn't
get into cloth) ... done. Three years flying and no cracks.
Later, - Lew
_________________ non-pilot
crazy about building
NOW OFICIALLY BUILDER #40549
Fly off completed ! |
Kellym
Posted: Mon Aug 13, 2012 7:24 am Post subject: Glassing Window Transition |
Has anyone gone with the formed aluminum retainer strip like many
certified aircraft have? I recall seeing it on a website but can't find
it now.
On 8/13/2012 8:10 AM, lewgall(at)charter.net wrote:
Hey Todd, et al,
discussion has been posted in the past, here goes again. What I've
done is to use a right angle air die grinder with a 2" sanding pad to
grind out a slight shallow in the plexi and fiberglass overlapping the
joint (after the plexi is glued in). Maybe 3/4" wide, 1/16" deep.
Think edge of sheetrock that is tapered so that you can mud in tape
and be flush when sanded. I glass in cloth (don't know what
thickness, just whatever I've used for everything else from West
Systems!) in this shallow, butting around corners, at full strength,
then finish it out with micro balloon slurry, sand flush (doesn't get
Later, - Lew
Checked by AVG - www.avg.com
KCHD |
kearney
Posted: Mon Aug 13, 2012 8:03 am Post subject: Glassing Window Transition |
Hi Kelley
Here is the link. http://www.mlblueskunk.com/News.html
It says only 3 have been done so far.
Cheers
Les
On 2012-08-13, at 9:23 AM, Kelly McMullen <kellym(at)aviating.com> wrote:
Has anyone gone with the formed aluminum retainer strip like many certified aircraft have? I recall seeing it on a website but can't find it now.
> Hey Todd, et al,
> I think I've still got pictures, but not on this computer. This discussion has been posted in the past, here goes again. What I've done is to use a right angle air die grinder with a 2" sanding pad to grind out a slight shallow in the plexi and fiberglass overlapping the joint (after the plexi is glued in). Maybe 3/4" wide, 1/16" deep. Think edge of sheetrock that is tapered so that you can mud in tape and be flush when sanded. I glass in cloth (don't know what thickness, just whatever I've used for everything else from West Systems!) in this shallow, butting around corners, at full strength, then finish it out with micro balloon slurry, sand flush (doesn't get into cloth) ... done. Three years flying and no cracks.
> Later, - Lew
tsts4
Posted: Mon Aug 13, 2012 8:03 am Post subject: Re: Glassing Window Transition |
I've attached a crude graphic to illustrate for visual learners like me what I 'm trying to figure out. The window shape is the black rectangle, the colored lines rep individual tapes butted together at the corners and the gray is a single ring of tape cut to the window's shape in lieu of using individual pieces.
Seems like based on the answers so far (and my own very limited fiberglass experience) that the individual tapes are the way to go, but I'm open to suggestions.
40.72 KB |
6877 Time(s) |
