Matt Dralle Site Admin
Joined: 08 Nov 2005 Posts: 28109 Location: Toledo Washington (KTDO) USA
Posted: Mon Aug 06, 2012 7:18 pm Post subject: Cork Gaskets For Comant CI122 VHF Antennas |
Does anyone have a good source for the cork gaskets used with the Comant CI 122 VHF Com antennas? When I removed them from the old RV-8 fuselage, I must have put them in a very "safe" place and now I can't find them anywhere. Guess they're pretty safe. Anyway, I need to order a couple more but I checked the Chief, Pacific Coast Avionics, and ACS web pages and found the antennas but no references to just ordering the cork gaskets.
<http://www.cobham.com/media/9104/ci%20122%20data%20sheet.pdf>http://www.cobham.com/media/9104/ci%20122%20data%20sheet.pdf
Thanks for any tips...
Status: 172+ Hours TTSN - Rebuilding Fuselage After Landing Mishap...
Status: 80+ Hours Since Purchase - Upgrades Complete; Now In Full Flyer Mode
_________________ Matt Dralle
Kelly McMullen
Posted: Mon Aug 06, 2012 7:33 pm Post subject: Cork Gaskets For Comant CI122 VHF Antennas |
Probably easiest to visit your friendly National Air Parts Store or
AirplaneZone for a roll of cork gasket material and cut yourself ones
to fit. Nothing special about those gaskets.
On Mon, Aug 6, 2012 at 8:19 PM, Matt Dralle <dralle(at)matronics.com> wrote:
A&P/IA, EAA Tech Counselor
KCHD |
Posted: Tue Aug 07, 2012 7:11 am Post subject: Cork Gaskets For Comant CI122 VHF Antennas |
Seems like I recall someone recommending discarding the gasket and going
for direct metal to metal.
Anyone doing that? Why?
Bill Watson
(do not archive)
On 8/6/2012 11:19 PM, Matt Dralle wrote:
Checked by AVG - www.avg.com
rv10pro(at)gmail.com Guest
Posted: Tue Aug 07, 2012 10:54 am Post subject: Cork Gaskets For Comant CI122 VHF Antennas |
At the airlines, we do Direct Metal to Metal to effect an improved groundplane. We also treat the skin agains corrosion (Alodine), then Fillet seal the antenna flange to the skin for water-tight integrity. The biggest failure is returning the aircraft to service too soon, pressurizing the cabin for passengers and getting blow-outs in the fillet which allows moisture. The corrosion is certain in the presence of millivolts, moisture and dissemilar materials.
John
On Tue, Aug 7, 2012 at 8:10 AM, Bill Watson <Mauledriver(at)nc.rr.com (Mauledriver(at)nc.rr.com)> wrote:
[quote] --> RV10-List message posted by: Bill Watson <Mauledriver(at)nc.rr.com (Mauledriver(at)nc.rr.com)>
Seems like I recall someone recommending discarding the gasket and going for direct metal to metal.
Bill Watson
(do not archive)
http://forums.matronics.com
le, List Admin.
dmaib@me.com
Joined: 25 Apr 2006 Posts: 455 Location: New Smyrna Beach, Florida
Posted: Tue Aug 07, 2012 11:05 am Post subject: Re: Cork Gaskets For Comant CI122 VHF Antennas |
| rv10pro(at)gmail.com wrote: | At the airlines, we do Direct Metal to Metal to effect an improved groundplane. �We also treat the skin agains corrosion (Alodine), then Fillet seal the antenna flange to the skin for water-tight integrity. �The biggest failure is returning the aircraft to service too soon, pressurizing the cabin for passengers and getting blow-outs in the fillet which allows moisture. �The corrosion is certain in the presence of millivolts, moisture and dissemilar materials.
John
[b] |
I did mine exactly the way John describes. Somebody (can't remember who, but probably Stein) recommended this approach. I have had no problems in nearly four years.
_________________ David Maib
RV-10 #40559
New Smyrna Beach, FL |
Posted: Tue Aug 07, 2012 11:11 am Post subject: Cork Gaskets For Comant CI122 VHF Antennas |
Recommend using the gasket.
Recall that the antenna needs an RF ground, not necessarily a DC ground. Using the gasket mitigates the corrosion aspects while still providing the needed RF ground.
Carl
On Aug 7, 2012, at 2:51 PM, John Cox <rv10pro(at)gmail.com (rv10pro(at)gmail.com)> wrote:
[quote]At the airlines, we do Direct Metal to Metal to effect an improved groundplane. We also treat the skin agains corrosion (Alodine), then Fillet seal the antenna flange to the skin for water-tight integrity. The biggest failure is returning the aircraft to service too soon, pressurizing the cabin for passengers and getting blow-outs in the fillet which allows moisture. The corrosion is certain in the presence of millivolts, moisture and dissemilar materials.
John
| Quote: | --> RV10-List message posted by: Bill Watson <Mauledriver(at)nc.rr.com (Mauledriver(at)nc.rr.com)>
Bill Watson
(do not archive)
le, List Admin.
Kellym
Posted: Tue Aug 07, 2012 12:22 pm Post subject: Cork Gaskets For Comant CI122 VHF Antennas |
The antenna has a gasket for a reason. The base of the antenna is more
than adequately grounded by the 3-4 screws that fasten it to the doubler.
On 8/7/2012 11:51 AM, John Cox wrote:
| Quote: | At the airlines, we do Direct Metal to Metal to effect an improved
John
<mailto:Mauledriver(at)nc.rr.com>> wrote:
<Mauledriver(at)nc.rr.com <mailto:Mauledriver(at)nc.rr.com>>
Bill Watson
(do not archive)
<dralle(at)matronics.com <mailto:dralle(at)matronics.com>>
cork gaskets.
Mishap...
Full Flyer Mode
Checked by AVG - www.avg.com <http://www.avg.com>
le, List Admin.
KCHD |
hotwheels
Posted: Wed Aug 08, 2012 9:38 am Post subject: Re: Cork Gaskets For Comant CI122 VHF Antennas |
My brand new Comant antenna came without any gasket. Here's the blurb from ACS:
"Comant Antennas no longer come with a gasket or template. Must order PN 09-00532 separately."
What arrived ended up looking a lot like proseal. I could have done that myself.
Jay
[quote="Matt Dralle"]Does anyone have a good source for the cork gaskets used with the Comant CI 122 VHF Com antennas? When I removed them from the old RV-8 fuselage, I must have put them in a very "safe" place and now I can't find them anywhere. Guess they're pretty safe. Anyway, I need to order a couple more but I checked the Chief, Pacific Coast Avionics, and ACS web pages and found the antennas but no references to just ordering the cork gaskets.
<http>http://www.cobham.com/media/9104/ci%20122%20data%20sheet.pdf
