Modifying 12V LED Strip Lighting to work in 24/28V Aircraf
raymondj(at)frontiernet.n
PostPosted: Sun Jul 29, 2012 1:33 pm    Post subject: Modifying 12V LED Strip Lighting to work in 24/28V Aircraf Reply with quote
I always heard: It's good to be good, but it's better to be lucky" (or
Luckey in your case).
Raymond Julian
Kettle River, MN.
"And you know that I could have me a million more friends,
and all I'd have to lose is my point of view." - John Prine
On 07/29/2012 03:17 PM, Jeff Luckey wrote:
What’s that old saying? It’s better to be good than lucky. However, in
my case, I’m always Luckey Wink
*From:*owner-aeroelectric-list-server(at)matronics.com
[mailto:owner-aeroelectric-list-server(at)matronics.com] *On Behalf Of
*Henador Titzoff
*Sent:* Sunday, July 29, 2012 12:47
*To:* aeroelectric-list(at)matronics.com
*Subject:* RE: Modifying 12V LED Strip Lighting to
work in 24/28V Aircraft
Good catch, Jeff. I guess you were Luckey, huh? Good job!
Henador Titzoff
--- On *Sun, 7/29/12, Jeff Luckey /<JLuckey(at)pacbell.net>/* wrote:
Subject: RE: Modifying 12V LED Strip Lighting to work
in 24/28V Aircraft
Date: Sunday, July 29, 2012, 11:36 AM
Are the LEDs shown in that PDF drawn w/ the correct polarity??
[mailto:owner-aeroelectric-list-server(at)matronics.com] *On Behalf Of *Bill
*Sent:* Sunday, July 29, 2012 08:35
*Subject:* Re: Modifying 12V LED Strip Lighting to
On Sat, Jul 28, 2012 at 11:35 PM, you wrote
---------------snip--------------
> One thing to remember is that the number of LED's in each of the strips must be the same
Not to worry, Eric noted this on his pdf below.
SF bay area
http://forums.matronics.com//files/modify_led_strip_lighting_for_24_28_volts_196.pdf
<http://forums.matronics.com/files/modify_led_strip_lighting_for_24_28_volts_196.pdf>
*http://www.matronics.com/Navigator?AeroElectric-List*
*http://forums.matronics.com*
*http://www.matronics.com/contribution*
Checked by AVG - www.avg.com <http://www.avg.com>
07/28/12
Eric M. Jones
PostPosted: Mon Jul 30, 2012 5:21 am    Post subject: Re: Modifying 12V LED Strip Lighting to work in 24/28V ac Reply with quote
Wrong polarity...Rookie mistake see attached correction....
Modify LED Strip lighting for 24-28 Volts revA.pdf
 Filename:  Modify LED Strip lighting for 24-28 Volts revA.pdf
 Filesize:  88.13 KB
 Downloaded:  419 Time(s)
Eric M. Jones
www.PerihelionDesign.com
113 Brentwood Drive
Southbridge, MA 01550
(508) 764-2072
emjones(at)charter.net
