jill(at)m-14p.com Guest
Posted: Tue Jul 17, 2012 4:28 am Post subject: Air compressor overhaul |
Bill & Group,
We overhaul air compressors here. We are also re-sleeving the Stage I
heads. We have not come up with a suitable fix for stripped threads at the
outlet valve port, though/ The hole is asymmetric, so you have more
material on part of the radius than others. Helicoil is not a viable
option, unless someone else out there has had success.
If anyone is wondering about our support of the Yak & M-14P community, here
are some of the things we do:
M-14P:
- Major repairs including prop strike/hydraulic lock teardown
- Full overhaul
- Accessory overhaul:
Magnetos
Carburetor
Fuel Pump
Oil Pump
Prop governor
Air compressor
-Compressor shear coupling repair
- Cylinder repair:
Guide replacement
Valve grinding & seating
Exhaust port repair
New, M-14P, Inc. rocker covers
-Automotive spark plug adaptor kit
-Nosecase seal replacement ****Flat rate with parts and labor
-Magneto modifications
Rewound coils with external capacitor
High performance auto points conversion
-Hose fabrication
Airframe:
-Hydrostatic testing of air bottles
-Electric trim system: Ailerons and elevators
-Tach Board for EFIS System
- Pneumatic system component overhauls
-Flap & landing gear actuators
-Flap & gear valves
-Uplock cylinders
-Fabric
- Coming soon: New Manufacture Fuel gauge and sending units
Propeller:
-Prop hub overhaul
-Static balancing
-M-14P, Inc. Carbon fiber V-530C blades *****Running OSHKOSH Special from
7/23thru 7/29/12******$500 off a Pair of Blades
Parts Support: We manufacture over 300 parts for the M-14P and Yak 52.
We are working on our new webstore to enable customers to see our vast
inventory and also shop with ease. The website will also be underrehab.
Best regards,
Jill
M-14P, Inc.
www.m-14p.com
bwade154(at)yahoo.com Guest
Posted: Thu Jul 26, 2012 7:13 am Post subject: Air compressor overhaul |
Hi Jill sent the compressor out should hve arrived at your location Tue July 24 was wounder if there is an update yet on what it needs and cost of rebuild.
Bill Wade
23 Wheeler Rd
Edinburg NY 12134
518-775-7431
To: yak-list(at)matronics.com
Sent: Tuesday, July 17, 2012 8:26 AM
Subject: Re: Air compressor overhaul
--> Yak-List message posted by: "Jill Gernetzke" <jill(at)m-14p.com (jill(at)m-14p.com)>
Bill & Group,
M-14P:
- Full overhaul
Magnetos
Carburetor
Fuel Pump
Oil Pump
Prop governor
Air compressor
- Cylinder repair:
Guide replacement
Exhaust port repair
-Hose fabrication
Airframe:
-Flap & gear valves
-Uplock cylinders
-Fabric
Propeller:
-Prop hub overhaul
-Static balancing
Best regards,
Jill
M-14P, Inc.
http://www.m- utilities such as List Un/SubscNavigator?Yak-List" target=_blank>http://www.matronics.com/Navigator?Yak-; -Matt
