Video- Long Draw Fire
Tom McCarthy
PostPosted: Thu Jul 19, 2012 3:58 am    Post subject: Video- Long Draw Fire Reply with quote
Larry,
Just an FYI for you. My HKS Slingshot was giving me some intermittent, alarming oil pressure reading in flight, especially climb. The first thing I did was remove the electric sender and replace it with a mechanical oil pressure line and gauge from a test kit from harbor freight, and fly around a few times. I found everything to be fine and ordered a new sending unit and installed, which fixed the problem. I hope yours is as easy, keep us informed.
Tom McCarthy
Original Firestar N441TM
Slingshot N863GB
Zenith 601HD N514TM [quote][b]
Tom McCarthy
N514TM Zenith 601HD
N414TM Kolb FireStar 1
N863GB Kolb Slingshot
russk50(at)gmail.com
PostPosted: Mon Jul 23, 2012 4:21 pm    Post subject: Video- Long Draw Fire Reply with quote
LarryCan't watch your video without a password!
Russ
On Jul 18, 2012, at 5:45 PM, Larry Cottrell wrote:
[quote]I rolled out Dart today to check on the fire. The visibility has finally cleared up a bit. It was quite windy, but since it was early, it was only just faster one direction more than the other, and my crosswind strip while pretty short, was right in line.
I have been having some issues with my oil pressure in my HKS after a recent oil change. I replaced the recent oil filter with a new and different one, and had thought that it had helped. I had only flown some 12 miles when the pressure started fluctuating enough to cause an "alarm" from my EIS. Not wanting to walk back through a charred landscape, I turned tail for home, so the video is not as extensive as I would have liked it.
The Kolb however preformed flawlessly as usual, and while the wife thought my landing was one of my best, it scared the crap out of me. My depth perception is not the greatest, and a 10 MPH headwind had me a bit slower than I really wanted, but the Firestar made it look easy, and a little throttle at the right time kept us high enough to clear the fence and touch down like a feather.
https://vimeo.com/45984093 The password is "owyheeflyer"
Larry
PostPosted: Mon Jul 23, 2012 4:29 pm    Post subject: Video- Long Draw Fire Reply with quote
You are a little quick on the draw.
Try reading the original email.
Right next to the url: "The password is "owyheeflyer". Wink
Larry
Russ
Larry
pc.king(at)comcast.net
PostPosted: Mon Jul 23, 2012 7:54 pm    Post subject: Video- Long Draw Fire Reply with quote
John,
Are you a fan of David Mallett or did you search for a fire song?
He's not well known outside New England. In truth he isn't known much outside Maine.
A powerful song.
PCKing
lcottrell
PostPosted: Mon Jul 23, 2012 8:51 pm    Post subject: Video- Long Draw Fire Reply with quote
I am assuming that your question was aimed at me, since I made the video and used the song. I am a fan of David Mallett, and I think I have all his albums. He is quite a word smith, and I hope to hell he doesn't mind me using it. Perhaps its use will encourage some to try some of his stuff. I think I have sold a few Indian flute music CD's with my videos. Smile
Larry
On Mon, Jul 23, 2012 at 9:54 PM, pcking <pc.king(at)comcast.net (pc.king(at)comcast.net)> wrote:
John,
A powerful song.
PCKing
jackinkeywest
PostPosted: Tue Jul 24, 2012 5:43 am    Post subject: Video- Long Draw Fire Reply with quote
Larry,
I purchased the CD from your first published video... Rain Dance. It's a wonderful CD...
Jack in Key West
DO NOT ARCHIVE
smime.p7s
 Filename:  smime.p7s
 Filesize:  5.16 KB
 Downloaded:  413 Time(s)
