hans-chr.erstad(at)c2i.ne Guest
Posted: Mon Jul 16, 2012 3:12 am Post subject: SV: weights and balances |
Jesse
1. empty: 895 lbs empty C.G. STA 58.7
I weighed the aircraft before mounting the battery in order to calculate the optimum location. turned out the optimum location was too far aft to be possible to mont. (or I should have selected a heavier battery - battery is Gill G25) Mounted the battery just ahead of STA 158, but had to add anoter 8 lbs of weight at STA 158 to be able to get C.G within limits with a 165 lb pilot and full of fuel.
2. I use the actual weight of the occupant
3. zero
Hans Christian. TR-1 #32, LN-KIS
Fra: owner-kis-list-server(at)matronics.com [mailto:owner-kis-list-server(at)matronics.com] På vegne av Flyinisfun(at)aol.com
Sendt: 16. juli 2012 03:57
Til: kis-list(at)matronics.com
Emne: weights and balances
I am re-weighing my two place KIS -1 after moving the batteries forward by 30 inches. I feel I have been too near the rear CG and wanted more room at the rear. I would like to compare with you guys the following.
1. What are your empty weights and CG numbers?
2. Do you figure gross weight by using 170 lbs. per occupant or do you use the actual weight of the occupant?
3. How much gas are you leaving home with two 200 lb. bodies aboard and no luggage?
Jesse Wright
href="http://www.matronics.com/Navigator?KIS-List">http://www.matronics.com/Navigator?KIS-List
| | - The Matronics KIS-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
Posted: Mon Jul 16, 2012 8:56 am Post subject: SV: weights and balances |
The continental IO-240-A with Prince wooden prop.
I got the engine mount from Tri-R, but there is good spacing between the engine and firewal so it could have been shorter.
Hans Christian
Fra: owner-kis-list-server(at)matronics.com [mailto:owner-kis-list-server(at)matronics.com] På vegne av F. Tim Yoder
Sendt: 16. juli 2012 14:41
Emne: Re: weights and balances
Hans,
What engine do you have?
Thanks, Tim
