carlossa52(at)gmail.com Guest
Posted: Tue Jul 10, 2012 3:39 am Post subject: Fwd: Zenith-List: CH601-HD(S) fuselage assembly |
I took more pictures and a short movie: http://www.flickr.com/photos/54366879(at)N06/
Maybe this will joggle the memory of CH601-HD(S) builders...
Carlos
---------- Forwarded message ----------
From: Carlos Sa <carlossa52(at)gmail.com (carlossa52(at)gmail.com)>
Date: 8 July 2012 19:58
Subject: Zenith-List: CH601-HD(S) fuselage assembly
To: zenith601-list(at)matronics.com (zenith601-list(at)matronics.com), zenith-list(at)matronics.com (zenith-list(at)matronics.com)
Hello, folksMy aluminum stack is finally starting to resemble an aircraft (if you have a lot of imagination, that is): http://www.zenith.aero/photo/img-6058When I put the front side skins in place (just to have an idea of what it would look like), I noticed the interference between the side skins, heel support and floor (the rolled end of the floor). The attached pics show the offending area.The instructions simply say "trim as required" (or something like that). To me, it seems I'll have to remove a semi-circle one or two inches in diameter - as I haven't seen any comments about this, I am a little concerned. I also have looked at a few of the CH601 sites still on-line, but I did not find any picture or comment that would clarify this. Thanks in advance for your comments / suggestions CarlosCH601-HD, plans
