steve.freeman(at)syntaxds Guest
Posted: Sun Jul 01, 2012 6:41 am Post subject: Expensive Goof up |
Hi Guys,
Yesterday when I was attaching the wire from my starter solenoid to my starter I somehow managed to cross thread the stud on the positive terminal on the solenoid or what I call the “plunger” side of the Sky-Tec 122-12pm starter. There was no way to get this off other than cutting it so now this 100% brand new starter is completely useless.
Question to the group is do any of you guys know why I can purchase just the solenoid side of the starter or do you know why I could possibly send this for repair? Does anyone out there possibly have an old starter where the solenoid side is still good you might want to part with?
This was very disheartening as if I can’t find a solution this turns out to be roughly a $400.00 screw.
Thanks for any advice.
Steve Freeman
psm(at)att.net Guest
Posted: Sun Jul 01, 2012 6:54 am Post subject: Expensive Goof up |
Hi Steve,
I'm not familiar with the starter, but I am confident you can get help from the manufacturer. They must have a way to repair your starter. You might have to pay them to do it but that should be a lot better than buying a new one.
Paul
Camas, WA
On 7/1/2012 7:41 AM, Steven Freeeman wrote:
Hi Guys,
Steve Freeman
BARRY CHECK 6
Posted: Sun Jul 01, 2012 1:37 pm Post subject: Expensive Goof up |
Steve:
You have a couple of options:
1 - Call Sky-Tec and ask for Less Staples, he is a friend, explain the situation and don't BS him, he has heard it all. He is VERY, VERY HELPFUL.
Mention my name.
2 - Tighten down the nut as far as it will go. DO NOT OVER TIGHTEN - The terminal is ONLY COPPER and the Nut is STEEL. Then see how much thread you have showing. Get a THIN WALL NUT, to snug down on top of the lug and first nut.
All this depends on IF you have enough room for the lug and second nut - AND - Do not use a SPLIT Lock Washer - Use a STAR WASHER.
CAUTION GUYS: The lugs on your Master & Starter Relays are also COPPER!
Barry
On Sun, Jul 1, 2012 at 10:41 AM, Steven Freeeman <steve.freeman(at)syntaxds.com (steve.freeman(at)syntaxds.com)> wrote:
Hi Guys,
Yesterday when I was attaching the wire from my starter solenoid to my starter I somehow managed to cross thread the stud on the positive terminal on the solenoid or what I call the plunger side of the Sky-Tec 122-12pm starter. There was no way to get this off other than cutting it so now this 100% brand new starter is completely useless.
This was very disheartening as if I cant find a solution this turns out to be roughly a $400.00 screw.
Steve Freeman
arget="_blank">http://www.matronics.com/Navigator?Zenith-List
tp://forums.matronics.com
Posted: Sun Jul 01, 2012 10:36 pm Post subject: Expensive Goof up |
Hi Barry,
What is your last name so when I call mister staples I'll be able to give a proper a reference. thanks a lot for your help hopefully it'll work out. I sent Sky-Tec an email yesterday I would not expect to hear from them before tomorrow.
Thanks again,
Steve (fingers crossed) freeman
Sent from my Verizon Wireless 4G LTE DROID
-----Original message-----
[quote]From: FLYaDIVE <flyadive(at)gmail.com>
Sent: Sun, Jul 1, 2012 14:36:49 MST
Subject: Re: Zenith-List: Expensive Goof up
Steve:
Mention my name.
Barry
Hi Guys,
Steve Freeman
BARRY CHECK 6
Posted: Mon Jul 02, 2012 3:46 am Post subject: Expensive Goof up |
Steve:
The last name is Schulte, Just say "Chop'd Liver" sent you.
WHOOPS!! I spelled his name wrong... it is* Les *Staples, hope you caught
that.
Barry
On Mon, Jul 2, 2012 at 2:31 AM, Steve Freeman <steve.freeman(at)syntaxds.com>wrote:
[quote] Hi Barry,
hallert
Posted: Mon Jul 09, 2012 1:41 pm Post subject: Re: Expensive Goof up |
The Sky Tec guys are great! I broke the Al casting on an O-200 starter by using the wrong bolt thread and they replaced it no charge.
