steve.freeman(at)syntaxds Guest
Posted: Sat Jun 23, 2012 9:42 pm Post subject: Two minute WOT Ground Testk |
And the breaks held ok at full throttle? I have heard many reports that is not always the case.
Steve Freeman
iPad
On Jun 23, 2012, at 7:11 PM, "Ron Lendon" <ron.lendon(at)gmail.com> wrote:
bryanmmartin
Posted: Sun Jun 24, 2012 6:35 am Post subject: Two minute WOT Ground Testk |
The brakes on my plane hold firm at full throttle, but the thrust tends to drag the plane forward anyway, dragging the tires.
_________________ --
Bryan Martin
do not archive. |
BARRY CHECK 6
Posted: Sun Jun 24, 2012 7:02 am Post subject: Two minute WOT Ground Testk |
Brake slippage is usually do to the pads not being SET - Burnt In [See the brake manufacture's procedure]. This also has to deal with WHAT pads you are using. The OLD and VERY GOOD pads are made with asbestos. These are NOT FAA or EPA approved items. They are GREAT, They Work and They Last & Last. The other stuff, well, they are better for the environment, So Say the EPA. Just remember - Don't go SNORTING your brakes after landing; I don't care how much they smoke.
Better to snort - cinnamon.
Barry
On Sun, Jun 24, 2012 at 10:35 AM, <bryanmmartin(at)comcast.net (bryanmmartin(at)comcast.net)> wrote:
[quote]The brakes on my plane hold firm at full throttle, but the thrust tends to drag the plane forward anyway, dragging the tires.
Ron Lendon
DaveG601XL
Joined: 27 Oct 2006 Posts: 351 Location: Cincinnati, Oh
Posted: Mon Jun 25, 2012 8:35 am Post subject: Re: Two minute WOT Ground Test |
Ron,
Great to hear you are working through your pre-first flight checks.
Just chiming in on the angle that this thread took concerning brake strength. When I first started taxi testing, my brakes did not seem to hold hardly anything, much less run-up RPM. Once I performed the manufacturer's "conditioning procedure" and burned them in, holding for run-up and higher RPM was no problem.
Good luck!!
_________________ David Gallagher
Cincinnati, OH area |
