Stick - Panel Interference
nukeflyboy
PostPosted: Thu Jun 21, 2012 4:40 pm    Post subject: Stick - Panel Interference Reply with quote
I have been meaning to send this for a while but have been too busy in phase 1 testing. This is an old problem but slightly different spin. I have the infinity stick grips and they are known to have a problem with clearing the bottom of the panel. The fix is to cut the control sticks as short as possible. This gives a nominal clearance of about a half an inch between the top of the stick grip and the bottom of the panel - the bottom strip that usually holds circuit breakers. I was careful and mine cleared the panel.
One of the last things to install are the control cables. Yes, they are too short. More interesting was the interference between the right stick and the mixture control. The right stick when moved full left could be hung up on the LEFT side of the mixture control. See the photo. This was unacceptable even though in flight it would be tough to get it there. My control cables are stock and in the design location.
There are several ways to fix this but the one shown in the photo utilizes the stock cable. A slight modification to the support removed the interference. I actually like the fact that the mixture control is now below the throttle and prop. This minimizes inadvertently grabbing the mixture control instead of the prop.
The Fix
 Filesize:  85.95 KB
 Viewed:  8222 Time(s)
Right Stick - Mixture Interference
 Filesize:  58.28 KB
Dave Moore
RV-6 built and sold
RV-10 built and flying
Bob Turner
PostPosted: Thu Jun 21, 2012 5:23 pm    Post subject: Re: Stick - Panel Interference Reply with quote
Well, you're right, that would not be acceptable. Are you sure the right stick is vertical with the ailerons neutral? On mine the stick just barely touched the RIGHT side of the mixture knob, full over to the left. I adjusted the stick position (under the right seat) a bit, and now it doesn't touch.
BTW, I found I could hang up the stick if I moved to a certain position in a certain way. The culprit was a bolt under the seat in the control mechanism. I installed it per plans and it could hang up. The fix was to reverse the direction of bolt. The head wasn't long enough to interfere with the head forward.
Bob Turner
RV-10 QB
carl.froehlich(at)verizon
PostPosted: Thu Jun 21, 2012 5:49 pm    Post subject: Stick - Panel Interference Reply with quote
On my plane I cut the sticks down to just barely enough to mount the
Infinity Grip. I also replaced the control cable bracket with a more narrow
one (but keep the same knob spacing). This provides just enough clearance.
Both cabin heat, alternate air and oil cooler air controls are on the bottom
panel apron.
Carl
mauledriver(at)nc.rr.com
PostPosted: Thu Jun 21, 2012 9:34 pm    Post subject: Stick - Panel Interference Reply with quote
Nice fix.
For others encountering stick/panel interference, another approach is bending the stick in a press, i.e. increasing the curvature. Lots in the archives.
Dave Moore
RV-6 flying
RV-10 QB - flying
http://forums.matronics.com/viewtopic.php?p=376266#376266
http://forums.matronics.com//files/001_2_reduced_326.jpg
http://forums.matronics.com//files/stick_interference_120.jpg
nukeflyboy
PostPosted: Fri Jun 22, 2012 4:16 am    Post subject: Re: Stick - Panel Interference Reply with quote
There is a lot of back-and-forth adjustments to the sticks to get them vertical at the same time the ailerons are in line with the flaps and wing tips. I'm sure that was not the problem. I considered bending the stick as others have done but my wiring was internal to the stick and I didn't want to disassemble the stick grip and re-pull the wires.
By the way, when you align your sticks vertically with the ailerons locked in trail be sure to do this with the elevator in the neutral position. You do get some minor aileron deflection as you move the stick fore and aft.
Dave Moore
RV-6 built and sold
jchang10
PostPosted: Fri Jun 22, 2012 8:46 am    Post subject: Stick - Panel Interference Reply with quote
The stick can interfere here and there on the extreme ends. However,
before making major changes keep in mind, if you have a passenger in the
right seat, you are far more likely to hit their legs than any other
type of interference. It's an individual decision, but personally, i
never worried about it.
Jae
#40533 RV-10
First flight 10/19/2011
Phase 1 Done 11/26/2011
Dave Moore
RV-6 flying
RV-10 QB - flying
#40533 RV-10
nukeflyboy
PostPosted: Sat Jun 23, 2012 4:52 am    Post subject: Re: Stick - Panel Interference Reply with quote
Jae,
I agree with you. My left leg would not let the stick go that far. I would have to lift up my left leg and move the stick under it and to the left to get the right stick to interfere with the mixture control. Nevertheless, the perfectionist in me couldn't let it be. I was also concerned that the DAR would find it unacceptable. Full control stick deflections in all corners is a standard check and you look for interference, such as mine, binding of bell cranks, adequacy of control stops, and movement of rod end bearings (not hard against the retaining bracket).
In reality though I could not see how I could actually get the stick way over there in flight.
Dave Moore
RV-6 built and sold
Tim Olson
PostPosted: Sat Jun 23, 2012 5:38 am    Post subject: Stick - Panel Interference Reply with quote
This is very true wether you fly with short small people who slide their seat forward or big giant people who have it slid back. You will run out of throw due to body parts before it will hit the stops side to side. You will also never use full forward but will definitely use full aft.
The RV-10 has too much pitch authority to use full forward. I still would recommend cutting the sticks down and making sure the stick doesn't hit the panel or any switches though. But I don't think I'd bother going to extremes about the mixture/throttle/prop controls.
Tim
On Jun 22, 2012, at 9:44 AM, Jae Chang <jc-matronics_rv10(at)jline.com> wrote:
The stick can interfere here and there on the extreme ends. However, before making major changes keep in mind, if you have a passenger in the right seat, you are far more likely to hit their legs than any other type of interference. It's an individual decision, but personally, i never worried about it.
Jae
#40533 RV-10
> Dave Moore
> RV-6 flying
> RV-10 QB - flying
Kellym
PostPosted: Sat Jun 23, 2012 5:46 am    Post subject: Stick - Panel Interference Reply with quote
For those flying, did your DAR make any comments with regards to stick
travel and clearance from panel/switches, etc.? I would expect that nose
down travel would be needed most at full aft c.g. location, and no
flaps...kind of unusual to both be at full aft and need to not use flaps
or flaps inop. Probably don't need near full travel even in that event.
Tim
Kelly McMullen
KCHD
PostPosted: Sat Jun 23, 2012 6:31 am    Post subject: Stick - Panel Interference Reply with quote
I had the FSDO do my plane. He took the stick through full motion looking
for interference (as I expected him to do). I have the Infinity grips with
standard sticks but cut down to just enough to mount the grip.
I agree with all the comments however that the pilot's body is far more
limiting on stick travel than anything else. Recommend however that you
make sure there is no way for the stick to get caught on anything under the
panel. Also remember that the stick travel is much different (less travel)
with all the push tubes connected and in the final rig position. So if you
are still in the fuselage stage take this into consideration before
attempting to fix a problem that you may not have.
Carl
13 hrs
Bob Turner
PostPosted: Sat Jun 23, 2012 12:37 pm    Post subject: Re: Stick - Panel Interference Reply with quote
My DAR looked briefly, and made no comment, about stick travel. But I had made sure it didn't hit anything, nor can it hang up on the panel.
I have a Tosten grip, and I both cut the stick down, and bent it a little more.
Exception: the Tosten grip can rotate, and if I rotate it abnormally then it can touch the alternate air knob (full forward, full right). But it can't hang up, at worst it would activate the alternate air if I pulled it back like that.
As Tim said, I cannot imagine using full nose down in any circumstance, including aft loadings. But for landing with forward CG I do wish it had a bit more nose up authority. I have to carry 18 lbs ballast when solo (I'm short so the seat is one notch away from full forward).
Bob Turner
RV-10 QB
