jay(at)horriblehyde.com Guest
Posted: Mon Jun 18, 2012 9:02 am Post subject: Generator suppressor |
I’m busy replacing an old regulator (carbon pile with a cut-out relay) on a de Havilland Chipmunk. I bought a modern regulator from Zeftronics (who, in a world of poor service, excel themselves at being at the top of the bad service list) and was about to install it when I noticed that there is also what is termed a ‘suppressor’ between the generator and the regulator.
It is basically what I think is a smoothing filter – two inductors in series with two capacitors, one after each inductor, connected to ground. There are one of these circuits connected to either side of the generator (that is, on either side of the main windings) and one to the one side of the field winding. Since the original of this has disappeared from the aircraft I need to make another one, but I am not sure of what values of inductance and capacitance to use- does anyone have these values squirreled away somewhere so that I can make a new suppressor?
Jay
Posted: Tue Jun 19, 2012 2:55 am Post subject: Generator suppressor |
| Quote: | , but I am not sure of what values of inductance and capacitance to
Not sure what these would be. I'd leave them
off until you find that they are necessary.
Most generator noises were antagonistic to
ADF and low frequency nav services. You probably
don't need them now.
Posted: Tue Jun 19, 2012 3:21 am Post subject: Generator suppressor |
Thanks Bob,
I was thinking along the same lines. It seems to me that these are simply a
broad spectrum smoothing filter. I think that I will test run the generator
on my lathe and have a look at the output on a scope to see if it looks too
rough- a mass produced line filter may just do the job if any smoothing is
required.
Jay
Posted: Tue Jun 19, 2012 6:39 am Post subject: Generator suppressor |
At 06:20 AM 6/19/2012, you wrote:
Thanks Bob,
required.
Jay
That's probably more trouble than it's worth.
Generators produce a lot of trash. A 'scope
picture is almost never informative. A spectrum
analyzer would give you a notion of potential
EMC problems but know that DO-160 calls for
'qualified' devices to shrug off up to 1.5 volts
pk-pk over 1 to 5 kHz
http://tinyurl.com/78kwfk8
and lesser amounts above and below. A 'scope
picture of this is pretty spectacular. Alternators
are less 'spikey' but still offer considerable
ripple voltage.
Any filters you might need would go to issues
in the RF spectrum
http://tinyurl.com/7wrhxbg
and cannot be observed in a time domain display.
