vernon.franklin(at)gmail. Guest
Posted: Sun Jun 17, 2012 2:54 pm Post subject: AHRS OP-48 Kit |
Has anyone successfully used the OP-48 AHRS kit with Dynon AHRS?
The instructions specifically mention GRT and Garmin; no mention of Dynon.
So I do not know if it is just going to be a matter of drilling new mount points, or I should send it back.
Anyone have any thoughts?
Vernon Franklin
Kellym
Posted: Sun Jun 17, 2012 3:20 pm Post subject: AHRS OP-48 Kit |
You do not want to use it for Dynon, because their AHRS include a
magnetometer which will respond to the elevator bellcrank rod ends, as
well as the autopilot pitch servo. I am going to use mine for mounting
ELT, because it seems sturdier than the ELT mount Vans sells.
On 6/17/2012 3:53 PM, Vernon Franklin wrote:
| Quote: | Has anyone successfully used the OP-48 AHRS kit with Dynon AHRS?
Dynon.
Vernon Franklin
Checked by AVG - www.avg.com
KCHD |
