pilotdds(at)aol.com Guest
Posted: Sat Jun 16, 2012 9:07 pm Post subject: oil pressure |
Can I get some input as to where some of you are running your cruise oil pressure ,especially factory motors or those from engine builders.Lycoming refers to airframe manufacturer and that isn't much help since that's me. [quote][b]
Strasnuts
Joined: 10 Feb 2009 Posts: 502 Location: Salt Lake City, UT
Posted: Sat Jun 16, 2012 9:58 pm Post subject: oil pressure |
65-75 psi for me on cruise. Hot days 67 cold days 75.
On Jun 16, 2012, at 23:06, pilotdds <pilotdds(at)aol.com (pilotdds(at)aol.com)> wrote:
[quote]Can I get some input as to where some of you are running your cruise oil pressure ,especially factory motors or those from engine builders.Lycoming refers to airframe manufacturer and that isn't much help since that's me.
_________________ 40936
RV-10 SB N801VR Flying
780 Hours
SuperSTOL 60 hours |
Tim Olson
Posted: Sun Jun 17, 2012 4:30 am Post subject: oil pressure |
That's about what I have.
On Jun 17, 2012, at 12:55 AM, Seano <sean(at)braunandco.com (sean(at)braunandco.com)> wrote:
[quote]65-75 psi for me on cruise. Hot days 67 cold days 75.
| Quote: | Can I get some input as to where some of you are running your cruise oil pressure ,especially factory motors or those from engine builders.Lycoming refers to airframe manufacturer and that isn't much help since that's me.
Posted: Sun Jun 17, 2012 6:34 am Post subject: oil pressure |
Thankyou that helps
tgmeyerster(at)gmail.com Guest
Posted: Sun Jun 17, 2012 6:59 am Post subject: oil pressure |
Which engine?
Which oil do you use?
How many quarts?
Capacity of oil sump or tank?
