ssssskippy
Posted: Thu Jun 07, 2012 1:51 am Post subject: drain the main oil sump |
Hi All
Which kind of hose and fixation system do you use to drain the oil from the main oil Sump?
Could you show some pictures?
Olivier
byronmfox(at)gmail.com Guest
Posted: Thu Jun 07, 2012 7:09 am Post subject: drain the main oil sump |
To drain the main oil sump, I have a very high tech system - 5' of plastic rain gutter and bucket from the local hardware store. Has worked elegantly for 11 years.
...Blitz
On Jun 7, 2012, at 2:22 AM, Olivier Vigneron <ssssskippy(at)gmail.com (ssssskippy(at)gmail.com)> wrote:
[quote]Hi All
Olivier
Posted: Thu Jun 07, 2012 8:14 am Post subject: drain the main oil sump |
Gotcha beat Blitz. A 2 2/2 foot tall step ladder positioned delicately under the shut off valve on the sump with a 5 gal. Home Depot bucket position so as to catch the oil stream. Of course the chin cowl has to have been removed from the aircraft for this to happen without a huge mess.
Naturally the next step would be to pull the chip detector oil screen after the sump has drained otherwise pulling the chin cowl would be a big pain for something that a 8 mm I.D. PCV clear plastic hose passed through the louvers and slipped over the nipple on the sump drain to drain into a bucket on the hanger floor would do. You need about 5.5 feet of that type of hose to do that.
Doc
From: owner-yak-list-server(at)matronics.com [mailto:owner-yak-list-server(at)matronics.com] On Behalf Of Byron Fox
Sent: Thursday, June 07, 2012 10:10 AM
To: yak-list(at)matronics.com
Subject: Re: drain the main oil sump
...Blitz
Hi All
Olivier
| 01234567890123456
Posted: Thu Jun 07, 2012 9:03 am Post subject: drain the main oil sump |
One of the mods I have seen (and actually had one installed on my engine when it was purchased) puts an electric pump in with a permanent attachment to the sump drain fitting. Actuating a switch pumps the oil back into the main tank. Of course it makes cleaning the screen rather problematic, but it does work.
Mark
k7wx
Posted: Thu Jun 07, 2012 4:43 pm Post subject: drain the main oil sump |
Oliver,
I drain the M-14P oil sump into a paper painter's funnel that has a very fine mesh screen at the bottom. It's temporarily held in place with some cable lacing and drains into a plastic bucket directly underneath. I never expect to find any metal chips, bit it's always nice to know that they are not there.
Warren Hill
[img]cid:E61B75C1-59EC-4F94-BC2C-221F121AEBF8(at)ph.cox.net[/img]
On Jun 7, 2012, at 2:22 AM, Olivier Vigneron wrote:
| Quote: | Hi All
Olivier
1.36 MB |
3479 Time(s) |
k7wx
Posted: Fri Jun 08, 2012 5:48 am Post subject: drain the main oil sump |
Oliver,
I drain the M-14P oil sump into a paper painter's funnel with a fine mesh screen at the bottom. It's temporarily held in place with some cable lacing and drains into a plastic bucket directly underneath. I never expect to find any metal chips, bit it's always nice to know that they are not there.
Warren Hill
[img]cid:4D9AA5BF-03F4-447D-B335-68E5532C0907(at)ph.cox.net[/img]
| Quote: | Hi All
Olivier
210.12 KB |
3477 Time(s) |
ssssskippy
Posted: Fri Jun 08, 2012 6:51 am Post subject: drain the main oil sump |
Thanks for your answers!
Olivier
Le 8 juin 2012 à 15:03, Warren Hill <k7wx(at)earthlink.net (k7wx(at)earthlink.net)> a écrit :
| Quote: | Oliver,
Warren Hill
<sump.jpg>
| Quote: | Hi All
Olivier
| [quote][b]
threein60(at)yahoo.com Guest
Posted: Fri Jun 08, 2012 8:14 am Post subject: drain the main oil sump |
Looks sorta like a mouse trap..
Larry Pine
--- On Thu, 6/7/12, Warren Hill <k7wx(at)earthlink.net> wrote:
Date: Thursday, June 7, 2012, 5:39 PM
Oliver,
Warren Hill
[img]cid:1.3910262877(at)web161403.mail.bf1.yahoo.com[/img]
| Quote: | Hi All
Olivier
1.36 MB |
3471 Time(s) |
markdavis(at)wbsnet.org Guest
Posted: Fri Jun 08, 2012 1:08 pm Post subject: drain the main oil sump |
5/8" heater hose 3.5' long into a 5 gallon bucket for the sump. 5/8" heater hose 5' long from the oil tank to the bucket. A twist of safety wire on the ends of both to hang on a nail above a trash can to finish dripping out on a couple of paper towels after the change prevents a later mess as well.
Mark Davis
N44YK
1.36 MB |
3462 Time(s) |
