drain the main oil sump
ssssskippy
PostPosted: Thu Jun 07, 2012 1:51 am    Post subject: drain the main oil sump Reply with quote
Hi All
Which kind of hose and fixation system do you use to drain the oil from the main oil Sump?
Could you show some pictures?
Olivier
byronmfox(at)gmail.com
PostPosted: Thu Jun 07, 2012 7:09 am    Post subject: drain the main oil sump Reply with quote
To drain the main oil sump, I have a very high tech system - 5' of plastic rain gutter and bucket from the local hardware store. Has worked elegantly for 11 years.
...Blitz
On Jun 7, 2012, at 2:22 AM, Olivier Vigneron <ssssskippy(at)gmail.com (ssssskippy(at)gmail.com)> wrote:
[quote]Hi All
Olivier
viperdoc(at)mindspring.co
PostPosted: Thu Jun 07, 2012 8:14 am    Post subject: drain the main oil sump Reply with quote
Gotcha beat Blitz.  A 2 2/2 foot tall step ladder positioned delicately under the shut off valve on the sump with a 5 gal. Home Depot bucket position so as to catch the oil stream. Of course the chin cowl has to have been removed from the aircraft for this to happen without a huge mess.
Naturally the next step would be to pull  the chip detector oil screen after the sump has drained otherwise pulling the chin cowl would be a  big pain for something that a 8 mm I.D. PCV clear plastic hose passed through the louvers and slipped over the nipple on the sump drain to drain into a bucket on the hanger floor would do. You need about 5.5 feet of that type of hose to do that.
Doc
From: owner-yak-list-server(at)matronics.com [mailto:owner-yak-list-server(at)matronics.com] On Behalf Of Byron Fox
Sent: Thursday, June 07, 2012 10:10 AM
To: yak-list(at)matronics.com
Subject: Re: drain the main oil sump
...Blitz
Hi All
Olivier
mark.bitterlich(at)navy.m
PostPosted: Thu Jun 07, 2012 9:03 am    Post subject: drain the main oil sump Reply with quote
One of the mods I have seen (and actually had one installed on my engine when it was purchased) puts an electric pump in with a permanent attachment to the sump drain fitting. Actuating a switch pumps the oil back into the main tank. Of course it makes cleaning the screen rather problematic, but it does work.
Mark
k7wx
PostPosted: Thu Jun 07, 2012 4:43 pm    Post subject: drain the main oil sump Reply with quote
Oliver,
I drain the M-14P oil sump into a paper painter's funnel that has a very fine mesh screen at the bottom. It's temporarily held in place with some cable lacing and drains into a plastic bucket directly underneath. I never expect to find any metal chips, bit it's always nice to know that they are not there.
Warren Hill
[img]cid:E61B75C1-59EC-4F94-BC2C-221F121AEBF8(at)ph.cox.net[/img]
On Jun 7, 2012, at 2:22 AM, Olivier Vigneron wrote:
Hi All
Olivier
 Filesize:  1.36 MB
 Viewed:  3497 Time(s)
k7wx
PostPosted: Fri Jun 08, 2012 5:48 am    Post subject: drain the main oil sump Reply with quote
Oliver,
I drain the M-14P oil sump into a paper painter's funnel with a fine mesh screen at the bottom. It's temporarily held in place with some cable lacing and drains into a plastic bucket directly underneath. I never expect to find any metal chips, bit it's always nice to know that they are not there.
Warren Hill
[img]cid:4D9AA5BF-03F4-447D-B335-68E5532C0907(at)ph.cox.net[/img]
Hi All
Olivier
 Filesize:  210.12 KB
 Viewed:  3495 Time(s)
ssssskippy
PostPosted: Fri Jun 08, 2012 6:51 am    Post subject: drain the main oil sump Reply with quote
Thanks for your answers!
Olivier
Le 8 juin 2012 à 15:03, Warren Hill <k7wx(at)earthlink.net (k7wx(at)earthlink.net)> a écrit :
Oliver,
Warren Hill
<sump.jpg>
Hi All
Olivier
threein60(at)yahoo.com
PostPosted: Fri Jun 08, 2012 8:14 am    Post subject: drain the main oil sump Reply with quote
Looks sorta like a mouse trap..
Larry Pine
Date: Thursday, June 7, 2012, 5:39 PM
Oliver,
Warren Hill
[img]cid:1.3910262877(at)web161403.mail.bf1.yahoo.com[/img]
Hi All
Olivier
 Filesize:  1.36 MB
 Viewed:  3489 Time(s)
markdavis(at)wbsnet.org
PostPosted: Fri Jun 08, 2012 1:08 pm    Post subject: drain the main oil sump Reply with quote
5/8" heater hose 3.5' long into a 5 gallon bucket for the sump. 5/8" heater hose 5' long from the oil tank to the bucket. A twist of safety wire on the ends of both to hang on a nail above a trash can to finish dripping out on a couple of paper towels after the change prevents a later mess as well.
Mark Davis
N44YK
 Filesize:  1.36 MB
 Viewed:  3480 Time(s)
