etandrews(at)westnet.com. Guest
Posted: Tue Jun 05, 2012 2:00 am Post subject: : broken pilot step |
Everyone
I have had a broken pilots step after approximately 200hrs flying. I noticed a minor crack in the paint above the top weld where the upright section of the step connected to the horizontal fuselage section. Later that day when alighting the step it failed. The weld appeared almost non existent. It may be worth inspecting your own steps for signs of failure. I am planning to install an inspection hatch to access the step anchor bolt along with a new step.
Kind regards
Evan Andrews
VH-OSH Australia flying
AirMike
Posted: Tue Jun 05, 2012 5:57 am Post subject: broken pilot step |
Truly sorry to hear about the broken step. At least nobody was hurt when it broke - could have caused a nasty gash. I have long recommended an inspection hatch for the step bolt as well as to check on corrosion. I used the access hatch from the wing. Installed it fits flush.
1.48 MB |
5766 Time(s) |
_________________ See you OSH '18
Q/B - sold. |
glastar(at)gmx.net Guest
Posted: Tue Jun 05, 2012 7:57 am Post subject: : broken pilot step |
Mike,
how did you solve that two of your screws are hidden behind the riveted
baggage side panel? Any picture with that panel in place? I moved mine a
little bit to the center and cut out a bit on the flange of the panel.
Cheers Werner
On 05.06.2012 15:57, AirMike wrote:
Posted: Wed Jun 06, 2012 3:15 am Post subject: : broken pilot step |
Thanks Mike - this one caught me by surprise. Very good thinking about the installation of the hatch during the build. It will be fun to get the building gear out for a change.
Evan
On 05/06/2012, at 11:57 PM, "AirMike" <Mikeabel(at)Pacbell.net> wrote:
michael(at)sausen.net Guest
Posted: Mon Jun 11, 2012 1:01 pm Post subject: : broken pilot step |
This was actually discussed in the past and you should be able to find some references in the archives.
Solution was a combination of beefing up the welds and putting on an access panel. My welds were seriously lacking and I re-TIG'd them.
Michael
On Jun 5, 2012, at 5:11 AM, "Etandrews" <etandrews(at)westnet.com.au> wrote:
Everyone
Kind regards
Evan Andrews
Posted: Mon Jun 11, 2012 1:35 pm Post subject: : broken pilot step |
Thanks Michael,
My wife reminded me of the earlier step failure posts!
I cut the hole for the inspection panel in the weekend and removed the internal anchor portion of the step. I was thinking that for builders installing the step that it may be worthwhile considering to install the securing bolt for the step in the horizontal rather than vertical position. This would aid removal of the bolt with the inspection hatch out from the side panel.
Evan
On 12/06/2012, at 7:00 AM, Michael Sausen <michael(at)sausen.net> wrote:
Michael
> Everyone
> Kind regards
> Evan Andrews
> Sent from my iPad
Posted: Tue Jun 12, 2012 5:42 am Post subject: : broken pilot step |
There are a couple other things people have done around the step. One is to put a block of Al or wood in it where the bolt goes to keep it from crushing and thereby loosening. The other is to use a self locking SS pin that allows for easy removal. I only have to push a button on the top of the pin to remove it.
On Jun 11, 2012, at 4:52 PM, "Etandrews" <etandrews(at)westnet.com.au> wrote:
Thanks Michael,
Evan
> Michael
> Sent from my iPhone
>> Everyone
>> Kind regards
>> Evan Andrews
>> Sent from my iPad
Jim(at)JimVillani.com Guest
Posted: Tue Jun 12, 2012 5:51 am Post subject: : broken pilot step |
What's the "Pin" look like?
civengpe
Posted: Tue Jun 12, 2012 5:53 am Post subject: : broken pilot step |
Michael,
Where did you purchase these pins?
Shannon
On Tue, Jun 12, 2012 at 8:42 AM, Michael Sausen <michael(at)sausen.net (michael(at)sausen.net)> wrote:
[quote]--> RV10-List message posted by: Michael Sausen <michael(at)sausen.net (michael(at)sausen.net)>
On Jun 11, 2012, at 4:52 PM, "Etandrews" <etandrews(at)westnet.com.au (etandrews(at)westnet.com.au)> wrote:
> --> RV10-List message posted by: Etandrews <etandrews(at)westnet.com.au (etandrews(at)westnet.com.au)>
> Thanks Michael,
> Regards
> Evan
> Sent from my iPad
> On 12/06/2012, at 7:00 AM, Michael Sausen <michael(at)sausen.net (michael(at)sausen.net)> wrote:
>> Michael
>> Sent from my iPhone
>> On Jun 5, 2012, at 5:11 AM, "Etandrews" <etandrews(at)westnet.com.au (etandrews(at)westnet.com.au)> wrote:
>>> Everyone
>>> Kind regards
>>> Evan Andrews
>>> Sent from my iPad
http://forums.matronics.com
le, List Admin.
Posted: Tue Jun 12, 2012 6:03 am Post subject: : broken pilot step |
I would have to find it but I got it from McMaster. Looks like a hitch pin with a button that releases a little ball on the bottom that allows insertion/removal.
Neal.George(at)hurlburt.a Guest
Posted: Tue Jun 12, 2012 6:13 am Post subject: : broken pilot step |
This weak step issue is not confined to the RV-10. I've had the step
fail on my Cherokee, too. Yes, it's mounted differently, but suffers
the same abuse and failure mode.
I've taken to briefing every individual who approaches the airplane with
the intention of climbing on the wing:
"It's an aide, not a launching pad. Grab the handle with your left hand
and PLACE your foot on the step, then stand up - don't stomp on it."
Likewise for exiting the aircraft: "It's not a landing pad. Turn
around, grab the handle, PLACE your foot on the step, then transfer your
weight and step off. If you're not agile enough for that, sit down and
scoot off the wing."
It's not the weight that breaks the steps. It's the force of folks
stomping on and striding off the wing.
Neal
taildragon(at)msn.com Guest
Posted: Tue Jun 12, 2012 6:28 am Post subject: : broken pilot step |
<?xml:namespace prefix="v" /><?xml:namespace prefix="o" /><![endif]--> Amen! "Standard" pilots weigh about 170# so when 240# pilots like me climb on the wing caution MUST be exercised!
Roger
