Ed Godfrey
Posted: Mon Jun 04, 2012 10:59 am Post subject: Door Gutter and McMaster Seals |
Could anyone tell me where to get a copy of Les' document? I am at that
stage and would like to do the research necessary. Thanks.
Ed Godfrey
40717
On 4/9/2012 7:48 PM, Sean Stephens wrote:
I've read Les' document on using McMaster Carr door seals. He trimmed
off the entire radius on the door gutter. I ordered the same 1/4 inch
with 3/8 inch bulb seals he used.
I have yet to trim off the full radius as he did, but it seems that if
I do, there will me no way the 3/8 inch bulb will be enough to
actually touch and seal against the door. Seems the gap between the
gutter and the door would be too large.
His doc showed the older green canopy instead of the pink. Is there a
difference there? Did others using the McMaster seals trim off the
full radius on the gutter and have it work with the 3/8 inch bulb?
-Sean #40303 (very dim light at the end of the tunnel)
sean(at)stephensville.com Guest
Posted: Mon Jun 04, 2012 1:48 pm Post subject: Door Gutter and McMaster Seals |
Sent to your email...
-Sean #40303
On 6/4/12 1:59 PM, egodfrey(at)ameritech.net wrote:
<egodfrey(at)ameritech.net>
that stage and would like to do the research necessary. Thanks.
Ed Godfrey
40717
> trimmed off the entire radius on the door gutter. I ordered the same
> 1/4 inch with 3/8 inch bulb seals he used.
> if I do, there will me no way the 3/8 inch bulb will be enough to
> a difference there? Did others using the McMaster seals trim off the
> Thanks,
rv10free2fly(at)yahoo.com Guest
Posted: Mon Jun 04, 2012 1:58 pm Post subject: Door Gutter and McMaster Seals |
Ed and colleagues, this is a compilation of door seal installation guidelines provided by various builders.
I hope that it helps you too.
Warm regards
Patrick Pulis
Adelaide, South Australia
#40299 - Engine & Avionics have arrived
From: "egodfrey(at)ameritech.net" <egodfrey(at)ameritech.net>
Sent: Tuesday, 5 June 2012 4:29 AM
Subject: Re: RV10-List: Door Gutter and McMaster Seals
--> RV10-List message posted by: "egodfrey(at)ameritech.net (egodfrey(at)ameritech.net)" <egodfrey(at)ameritech.net (egodfrey(at)ameritech.net)>
Could anyone tell me where to get a copy of Les' document? I am at that stage and would like to do the research necessary. Thanks.
Ed Godfrey
40717
| Quote: | --> RV10-List message posted by: Sean Stephens <sean(at)stephensville.com (sean(at)stephensville.com)>
I've read Les' document on using McMaster Carr door seals. He trimmed off the entire radius on the door gutter. I ordered the same 1/4 inch with 3/8 inch bulb seals he used.
I have yet to trim off the full radius as he did, but it seems that if I do, there will me no way the 3/8 inch bulb will be enough to actually touch and seal against the door. Seems the gap between the gutter and the door would be too large.
His doc showed the older green canopy instead of the pink. Is there a difference there? Did others using the McMaster seals trim off the full radius on the gutter and have it work with the 3/8 inch bulb?
http://www.matronics.com/Navigator?RV10-Linbsp; ; -Matt Dralle, Lis========
RV-10_McMaster_Carr_Door_Seal_Installation_Compilation.pdf |
2.38 MB |
17761 Time(s) |
drfred(at)suddenlinkmail. Guest
Posted: Mon Jun 04, 2012 2:30 pm Post subject: Door Gutter and McMaster Seals |
Ed
I forwarded the email that you needed directly to your box. Let me know
if you didn't get it.
Fred Williams
515FW
On 6/4/2012 1:59 PM, egodfrey(at)ameritech.net wrote:
Ed Godfrey
40717
> Thanks,
Kelly McMullen
Posted: Mon Jun 04, 2012 4:55 pm Post subject: Door Gutter and McMaster Seals |
After much consideration, I've decided that on my pink canopy I don't choose to remove that full radius, because of the implications to reducing strength of the door post. I also did not want to do the huge amount of build up and sanding that would be required to make the door sill uniform enough for an even sealing edge with the door. So I will try the seal that Alex D sells.
On Mon, Jun 4, 2012 at 11:59 AM, egodfrey(at)ameritech.net (egodfrey(at)ameritech.net) <egodfrey(at)ameritech.net (egodfrey(at)ameritech.net)> wrote:
[quote]--> RV10-List message posted by: "egodfrey(at)ameritech.net (egodfrey(at)ameritech.net)" <egodfrey(at)ameritech.net (egodfrey(at)ameritech.net)>
Ed Godfrey
40717
http://forums.matronics.com
le, List Admin.
A&P/IA, EAA Tech Counselor
KCHD |
Posted: Mon Jun 04, 2012 5:46 pm Post subject: Door Gutter and McMaster Seals |
This is what I used from McMaster. Easy on and seals well. I put them on the door, not the frame. I also used some semi ridged foam to fill in the door hinge recess so that this seal just goes over it around the perimeter of the door.
93085K11
Adhesive Back Foam Rubber Bulb Seal, 3/8" Overall Width, 7/16" Overall Height, 3/16" ID, 20' L
20
feet
in the morning
0.54
per foot
10.80
You need 30 feet.
Carl
RV-10 (6 hours)
RV-8A (800 hours)
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Kelly McMullen
Sent: Monday, June 04, 2012 8:51 PM
Subject: Re: Door Gutter and McMaster Seals
Ed Godfrey
40717
le, List Admin.
| Quote: | | http://www.matronics.com/Navigator?RV10-List | 01234567
Jim Berry
Posted: Mon Jun 04, 2012 6:42 pm Post subject: Re: Door Gutter and McMaster Seals |
[quote="Kelly McMullen"]After much consideration, I've decided that on my pink canopy I don't choose to remove that full radius, because of the implications to reducing strength of the door post. I also did not want to do the huge amount of build up and sanding that would be required to make the door sill uniform enough for an even sealing edge with the door. So I will try the seal that Alex D sells.
Kelly,
Another option is a method that I borrowed from Dave Saylor IIRC.
It uses a EDPM rectangular seal 1/8" x 1/2" and mounts on the inner surface of the door. It allows you to leave a significant portion of the gutter and is easy to fit. With the doors closed, trim the gutter so there is 1/8" gap between the door surface and the edge of the gutter; install seal, done.
Jim Berry
N15JB
dave.saylor.aircrafters(a Guest
Posted: Mon Jun 04, 2012 8:12 pm Post subject: Door Gutter and McMaster Seals |
| Quote: | >trim the gutter so there is 1/8" gap<<
It turns out you don't even need 1/8". Â The seals compress to less than 1/16. Â I use a couple layers to build up any areas that are more than 1/8, or you can use thicker material.
I posted a couple pictures to the list on 10/5/09.
Dave Saylor
[url=tel:831-750-0284]831-750-0284[/url] CL
On Mon, Jun 4, 2012 at 7:42 PM, Jim Berry <jimberry(at)qwest.net (jimberry(at)qwest.net)> wrote:
| Quote: | [quote="Kelly McMullen"]After much consideration, I've decided that on my pink canopy I don't choose to remove that full radius, because of the implications to reducing strength of the door post. I also did not want to do the huge amount of build up and sanding that would be required to make the door sill uniform enough for an even sealing edge with the door. So I will try the seal that Alex D sells.
| Quote: | Kelly,
href="http://www.matronics.com/Navigator?RV10-List" target="_blank">http://www.matronics.com/Navigator?RV10-List
      - MATRONICS WEB FORUMS -
| Quote: | ="_blank">http://forums.matronics.com
     - List Contribution Web Site -
| Quote: | _ Â Â Â Â Â Â Â Â Â Â Â Â Â -Matt Dralle, List Admin.
jchang10
Posted: Tue Jun 05, 2012 8:28 am Post subject: Door Gutter and McMaster Seals |
I never did the build-up for the mcmaster seal, so it is constantly falling off. In retrospect, i wish i had used a simple foam seal. It would have been far far simpler and easier to maintain than either the mcmaster seal or the stock seal.
Jae
| Quote: | #40533 RV-10
First flight 10/19/2011
Phase 1 Done 11/26/2011
do not archive | On 6/4/2012 9:09 PM, Dave Saylor wrote: [quote]>>trim the gutter so there is 1/8" gap<<
Dave Saylor
_________________ #40533 RV-10
Phase 1 Done 11/26/2011 |
robin(at)PaintTheWeb.com Guest
Posted: Tue Jun 05, 2012 3:09 pm Post subject: Door Gutter and McMaster Seals |
I cannot hope for a better seal and door fit on my -10 partially due to the McMaster Carr door seal. Extremely happy we used it. Like many items on the build you just have to put one foot in front of the other and one day you are flying. As far as effort we built a simple guide that we attached to pneumatic grinder and had each door precisely trimmed in 15 minutes.
Robin
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Jae Chang
Sent: Tuesday, June 05, 2012 9:27 AM
Subject: Re: RV10-List: Re: Door Gutter and McMaster Seals
Jae
#40533 RV-10
It turns out you don't even need 1/8". The seals compress to less than 1/16. I use a couple layers to build up any areas that are more than 1/8, or you can use thicker material.
Dave Saylor
831-750-0284<tel:831-750-0284> CL
Strasnuts
Joined: 10 Feb 2009 Posts: 502 Location: Salt Lake City, UT
Posted: Tue Jun 05, 2012 5:03 pm Post subject: Door Gutter and McMaster Seals |
Ditto for me, thanks to Robin. I copied the grinder tool and it made the job a lot easier. If I had to do it all over again, I wouldn't change a thing with the door seal. Definitely quieter than the vans seal possibly due to the hinge covers and consistent pressure around the door.
_________________ 40936
RV-10 SB N801VR Flying
780 Hours
SuperSTOL 60 hours |
Ed Godfrey
Posted: Tue Jun 05, 2012 5:13 pm Post subject: Door Gutter and McMaster Seals |
Just to ask a question, since I am not at the stage installing sun
visors, would it be possible to glass in a "block" that the visor could
be mounted to? That way, you could screw the mount into the block and
not to the cabin top. Any problems with this method that anyone can
throw a flag on the idea?
Ed Godfrey
40717
On 4/10/2012 7:35 AM, jkreidler wrote:
We each build our own airplanes and make our own decisions – please don’t take this as criticism just food for thought. I had a conversation with Ken K. regarding drilling holes in the gutter in order to add sun visors the cabin top, specifically the cabin top posts. Ken indicated that one of the challenges in the design was getting the cabin top to pass the inverted drop test. He was visibly uncomfortable with the idea of drilling any holes in the gutter to mount visors, for those who have had conversations with Ken K. in person you may know the wince he gives.
By removing the entire inside radius of the gutter in order to install the McMaster Carr style seal you are significantly changing the section modulus of the cabin top post and COULD be significantly increasing the likelihood of a cabin top failure in a roll over type accident. Just something to consider as you make what may seem to be a harmless improvement to the design.
Again, these are your decisions – I am only trying to provide an alternate perspective to the decision.
Thanks – Jason
Jason Kreidler
4 Partner Build - Sheboygan Falls, WI
Tony Kolar, Kyle Hokel, Wayne Elser, Jason Kreidler
N44YH - Flying - #40617
http://forums.matronics.com/viewtopic.php?p=370434#370434
philperry9
Posted: Tue Jun 05, 2012 6:05 pm Post subject: Door Gutter and McMaster Seals |
That is what I wanted to do originally. But there just isn't that much space to work with, so they kinda find their own spot.
If you don't have an overhead center console, you might have a few more inches to work with, but not much. The curve of the door frame pretty much dictates where they go.
On that topic, I would wait on determining the visors position until the the panel can be installed temporarily and the seats (with foam) adjusted so they're comfortable. Once you're comfortable in the cockpit, then figure out where the visors go. It's pretty easy to put them directly in the line of vision if you don't go through the prep work to put the cockpit together.
Phil
On Tue, Jun 5, 2012 at 7:34 PM, egodfrey(at)ameritech.net (egodfrey(at)ameritech.net) <egodfrey(at)ameritech.net (egodfrey(at)ameritech.net)> wrote:
Just to ask a question, since I am not at the stage installing sun visors, would it be possible to glass in a "block" that the visor could be mounted to? That way, you could screw the mount into the block and not to the cabin top. Any problems with this method that anyone can throw a flag on the idea?
Ed Godfrey
40717
Posted: Tue Jun 05, 2012 7:18 pm Post subject: Door Gutter and McMaster Seals |
15 minutes? I'd like to see a pic of this guide. It could cut a couple
hours off my total build time on my next RV-10!
On 6/5/12 5:19 PM, Robin Marks wrote:
Robin
[mailto:owner-rv10-list-server(at)matronics.com] *On Behalf Of *Jae Chang
*Sent:* Tuesday, June 05, 2012 9:27 AM
*To:* rv10-list(at)matronics.com
*Subject:* Re: Re: Door Gutter and McMaster Seals
Jae
#40533 RV-10
Dave Saylor
831-750-0284 <tel:831-750-0284> CL
���~��,�g���M4�G�q���z����.�'�8E]t.+-f��Z+�`��axÆï¿½ï¿½ï¿½r���^jÛ«z�Z�(�����Ƕ�j|���n�)b�'���!j���'�+����ب�r�y'���C�
å¡§{
����,x(Z�P�!j���ٮr�r��j�|����&j��',r��5��h�uи��m����
���'���o�j�j�+E]t.+-�0�8�Ia�T1
jg���r��z{Z�����i�^�&���lZ+�k�y����+�k&j��',r������+�k&j��',r��h��B�{k������y�����ʋ����������.��+����jY^.+-٢����i��0�f����r�(��(���n�b�xm����&j��',r��r��&�*'���'��k{��w/�tml=
robin(at)painttheweb.com Guest
Posted: Tue Jun 05, 2012 9:32 pm Post subject: Door Gutter and McMaster Seals |
Photos attached. Don't think I haven't thought about building another -10 because I already have this guide.
Robin
437.43 KB |
12998 Time(s) |
360.82 KB |
12998 Time(s) |
aerosport1
Posted: Wed Jun 06, 2012 4:53 am Post subject: Door Gutter and McMaster Seals |
I agree 100% with Robin. Mcmaster seals
Are the best. The extra effort to put fit them
Correctly will make them easy to install
Will not come off and are easy to replace if
Ever needed. They also look great and make
The door opening look more finished
Geoff combs
On Jun 5, 2012, at 6:19 PM, Robin Marks <robin(at)painttheweb.com (robin(at)painttheweb.com)> wrote:
| Quote: | <![endif]--> <![endif]-->
Robin
From: owner-rv10-list-server(at)matronics.com (owner-rv10-list-server(at)matronics.com) [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Jae Chang
Subject: Re: Re: Door Gutter and McMaster Seals
Jae
| Quote: | | #40533 RV-10First flight 10/19/2011Phase 1 Done 11/26/2011do not archive |
Dave Saylor
======================================[/b] | 10-List Email Forum -[/b][/quote] [/b][/quote] p>[/b][/quote] o:p>[/b][/quote] or?RV10-List">http://www.matronics.com/Navigator?RV10-List[/b][/quote] ======================================[/b][/quote] sp; - MATRONICS WEB FORUMS -[/b][/quote] p>[/b][/quote] p://forums.matronics.com[/b][/quote] ======================================[/b][/quote] sp; - List Contribution Web Site -[/b][/quote] > sp; -Matt Dralle, List Admin.[/b][/quote] ution">http://www.matronics.com/contribution[/b][/quote] ======================================[/b] [/quote]
���~��,���%��4�M4}�r�����{(����8^E]t.+-f��Z+�e,z�^1�k�x�����W���ް֯����hn�0��azf�ȸ���b�+bz�.r�.+-Rҹ��*m����b��j�!�'����6��0��j�(at)(at)�h��!j���ٮr�r��æ¡ï¿½ï¿½ï¿½ï¿½0��k�x���&�֯����U�B��m����&j��',r��5�â�«h�u��4N4��X(at)E9I&�z �j�(�ק��l��ڊV����j�^Y�����ky�m���~��ɚ��'���hm���~��ɚ��'���o�.+- ��&�*'Y�Ҋד���ʋ����������.��+�Æï¿½:Ú–W���(at)vh�j�~m���� ���'���oÜ¢{k��������0��k�x���&��'����ب��o�����ۡܿ�٥
_________________ Geoff Combs
RV-10 QB N829GW
Flying 500 hrs
40033 |
Strasnuts
Posted: Wed Jun 06, 2012 5:40 am Post subject: Door Gutter and McMaster Seals |
Another pic of a copy I made.
1.23 MB |
12991 Time(s) |
780 Hours
bcondrey
Posted: Wed Jun 06, 2012 6:56 am Post subject: Door Gutter and McMaster Seals |
So you guys did initial trimming with a cutoff wheel and then the grinder metal guide runs along the outside door edge with the tool doing the final trimming the remaining gutter?
Bob
On Jun 6, 2012, at 8:38 AM, "Seano" <sean(at)braunandco.com> wrote:
[quote] Another pic of a copy I made.
Strasnuts
Posted: Wed Jun 06, 2012 7:12 am Post subject: Door Gutter and McMaster Seals |
That's basically what I did. I used a belt sander on a lot of the cabin. I
also used a diamond cut off wheel and the grinder tool shown. This made a
consistent 1/4 or 3/16 lip for the seal to attach to. You can buy the lip
size in 3/16 or 1/4.
Personally I have a 1/4 reveal around the whole door and I feel like this is
the optimal gap for the 3/8 bulb.
Sean
780 Hours
john.maccallum(at)bigpond Guest
Posted: Fri Jun 08, 2012 6:25 am Post subject: Door Gutter and McMaster Seals |
Hi Carl,
Can you show us photo of your install?
John Maccallum
41016
VH-DUU
On 05/06/2012, at 11:39, "Carl Froehlich" <carl.froehlich(at)verizon.net (carl.froehlich(at)verizon.net)> wrote:
[quote] <![endif]--> <![endif]-->
93085K11
20
feet
in the morning
0.54
per foot
10.80
You need 30 feet.
Carl
RV-10 (6 hours)
RV-8A (800 hours)
From: owner-rv10-list-server(at)matronics.com (owner-rv10-list-server(at)matronics.com) [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Kelly McMullen
Ed Godfrey
40717
le, List Admin.
01234567
8
