Anyone interested in a 9lb battery/jumpstart kit?
rparigoris
PostPosted: Thu May 31, 2012 5:17 pm    Post subject: Anyone interested in a 9lb battery/jumpstart kit? Reply with quote
Hi Jack
No scam, everyone will get their stuff. Yours will go out in the next day or two. It ends up packaging two or three in the Flat Rate box is rather time consuming. They are also rather heavy so I have only been dropping off two or three at the post office at a time.
You have my word, if not you can come take away my first born, just mind he is in college!
I made a post that this is last chance to order,, and I got more orders from that post than the first posting!
The charge controllers are rather kool. You will get a 500mA 115VAC transformer to power the charge controller. That I have used a lot and it works fine. Because I needed to charge a number of batteries for this last wave, since I have a 200 amp 12V battery on hand, I used it to power a half dozen charge controllers through the 12 volt input of the charge controller. Works great, just like using the transformer.
I include in the package a little schematic, but be aware that once the battery "peaks", you need to unplug the input to get the holding circuit to reset.
Ron Parigoris
