jackinkeywest
Posted: Tue May 29, 2012 5:07 am Post subject: Wing Strut drag... |
So as not to 'high-jack' an earlier email re:March crash, there was a comment about the Kolb wing strut drag which I am curious about hence the new thread.
For those who have installed fairings on your wing/lift struts, what are the noticeable benefits (or detractors...) of flight/handling qualities before and after the fairings were installed? What material did you use (Alum or PVC) for your struts? Personally fabricated or purchased from vendor? Any final observations... are the fairings worth installing or not?
Thanks in advance!
Jack Lockamy
Key West
Kolb M3C/582/Floats
 Download |
| Filename: |
smime.p7s |
5.16 KB |
| Downloaded: |
428 Time(s) |
Posted: Tue May 29, 2012 5:30 am Post subject: Wing Strut drag... |
Jack Lockamy
Jack L/Folks:
Streamlined lift struts improve glide, reduce drag and vibration.
The best struts are streamlined 4130, but 20 years ago the price was already
out of sight.
I replaced the round aluminum lift struts on my Firestar with streamlined
4130, in 1987. The improved glide was responsible finding the money to
install brakes. Had difficulty getting the Firestar stopped on my short
grass strip.
My MKIII is equipped with extruded aluminum lift struts included in the
early kits. They work great.
There are many different ways to streamline lift struts. I am sure others
will chime in and share their method.
_________________ John Hauck
Titus, Alabama |
gajindra(at)sbcglobal.net Guest
Posted: Tue May 29, 2012 6:00 am Post subject: Wing Strut drag... |
Kolb has a plastic fairing that goes over the round tube and is rivited on.It is what I used on my Mark 3
Gary Jindra
Mark 3
56 hours
Sent: Tue, May 29, 2012 9:37:46 AM
Subject: RE: Wing Strut drag...
--> Kolb-List message posted by: "John Hauck" <jhauck(at)elmore.rr.com (jhauck(at)elmore.rr.com)>
Jack Lockamy
Jack L/Folks:
out of sight.
grass strip.
Titus, Althe Matronics List Features Navigator to /www.matronics.com/Navigator?Kolb-List" target=_blank>http://www.matronicsp; -Matt Dralle, List Admin.
