Europa for repair on AFORS
gholland(at)content-strea
PostPosted: Fri Jun 01, 2012 10:46 am    Post subject: Europa for repair on AFORS Reply with quote
Can I just ask the advice of one of two well known Guru's on this List.There is a Europa for Sale on AFORS at:
http://www.afors.com/index.php?page=adview&adid=15525&imid=0
Part of the write up quotes:
Professionally built just needs fibreglass repairs and a new stick assembly, lower cowl and elevator push/pull tube in replacement parts.
Am I being naive in thinking that the fuselage will need a complete new Fuselage, lower and upper and control Module.
I'm looking for a project but this one looks to be listed with an emphasis that it's very practical exercise and not a big deal. I'm thinking it's a big task.
Comments please.
Gerry
groups(at)thegoddards.com
PostPosted: Fri Jun 01, 2012 1:23 pm    Post subject: Europa for repair on AFORS Reply with quote
Gerry,
I have a lower cowl you can have foc.
Vince
G-BWUP
ULPower 260iS Swiss tail dragger
Sent from my iPad
On 1 Jun 2012, at 19:44, Gerry Holland <gholland(at)content-stream.co.uk (gholland(at)content-stream.co.uk)> wrote:
[quote]Can I just ask the advice of one of two well known Guru's on this List.There is a Europa for Sale on AFORS at:
Comments please.
Gerry
tp://www.matronics.com/Navigator?Europa-List
cs.com
matronics.com/contribution
PostPosted: Fri Jun 01, 2012 1:39 pm    Post subject: Europa for repair on AFORS Reply with quote
Thanks Vince.I think I'll defer full stop on this one. Opinion and advice to date is leave well alone with this wreck.
Hope your UL install is going well. Come over and see us when it's all cleared up.
Gerry
rlborger(at)mac.com
PostPosted: Fri Jun 01, 2012 1:46 pm    Post subject: Europa for repair on AFORS Reply with quote
Gerry,
Whoo, there's a bit of work.
If you actually are interested in that "project" Europa, I'd suggest you directly contact Nev and Bud to get their opinions on the amount of real work necessary to restore that bird to flying condition. They'd have the necessary experience to evaluate it. All that fiberglass damage can be repaired but the question is whether or not it is worth the effort involved or would you be better off seeking another project. Maybe something like a partially completed kit that's been lurking, untouched, in someone's shed for the last few years.
Blue skies & tailwinds,
Bob Borger
Europa XS Tri, Rotax 914, Airmaster C/S Prop.
Little Toot Sport Biplane, Lycoming Thunderbolt AEIO-320 EXP
3705 Lynchburg Dr.
Corinth, TX 76208-5331
Cel: 817-992-1117
rlborger(at)mac.com (rlborger(at)mac.com)
Comments please.
Gerry
PostPosted: Sat Jun 02, 2012 12:59 am    Post subject: Europa for repair on AFORS Reply with quote
Carl Hi!
Your observations on the Europa 'wreck' were eloquently put and match my own.
I thought I would air the subject as someone less expert on Europa building maybe drawn into thinking this is doable.
Both of us have built a Europa and based on that experience I think, like you, this advert lacks realistic direction and fact.
The occurrence leading to this crash was the alternator belt burning up after alternator seized.
Details: http://www.aaib.gov.uk/cms_resources.cfm?file=/Europa,%20G-BWCV%2003-07.pdf
A Subaru Engine as per this Aircraft is worth only £1000 max.
The rest of aircraft is of dubious serviceability due to crash damage and being stored over 5 years since incident.
IMHO. Buyer beware!
Gerry
stephen vestuti
PostPosted: Sat Jun 02, 2012 2:13 am    Post subject: Re: Europa for repair on AFORS Reply with quote
Hi Gerry,
nice to see you may be building another Europa. Hope you manage to
find somthing.
Incidentally, that's been for sale for a really long time - it's obviously not worth what he's asking,
Steve.
klinefelter.kevin(at)gmai
PostPosted: Sat Jun 02, 2012 5:03 am    Post subject: Europa for repair on AFORS Reply with quote
Gerry,
Thanks for the link regarding this forced landing. Very interesting!
Kevin
On Jun 2, 2012, at 1:58 AM, Gerry Holland <gholland(at)content-stream.co.uk> wrote:
Carl Hi!
IMHO. Buyer beware!
Gerry
Fred Klein
PostPosted: Sat Jun 02, 2012 7:25 am    Post subject: Europa for repair on AFORS Reply with quote
..the author of the text for the advert deserves a special award for
creativity and imagination...
houlihan(at)blueyonder.co
PostPosted: Sat Jun 02, 2012 8:37 am    Post subject: Europa for repair on AFORS Reply with quote
Hi Carl.
I agree with all you say except why do you pick out a Classic wing as being very difficult to repair.
In my very humble opinion damage to a foam core structure like the classic wing should be easier to part replace or repair than say a monocoque structure like the XS wing.
As I say this comment is only based on my experience building a classic aircraft so I am not an expert in this area.
Tim Houlihan
On 2 June 2012 09:23, Carl Pattinson <carl(at)flyers.freeserve.co.uk (carl(at)flyers.freeserve.co.uk)> wrote:
The “aircraft” looks like a complete disaster area and the idea that the fuselage can safely be pieced together is pure fantasy.  I can’t see any inspector in his right mind signing this off unless the whole area was paint stripped and checked for further stress damage. The fuselage is a “write off” – you would need to purchase a new fuselage, though it might be possible to save the cockpit module.
One thing not mentioned to date is one of the wings appears to have significant leading edge damage – if it’s a classic Europa will be very difficult (though not impossible) to repair. The wing profile on the Europa is critical (performance wise) so if the repair is not perfect it will fly like a brick (and probably stall/ spin like a kamikazee !)
The engine is a Subaru which I if I am not mistaken was the reason it the aircraft crashed in the first place – the early ones were unreliable !
Is it worth £6,500 in parts – questionable.
Unless you are looking for a project that will never fly.
From: owner-europa-list-server(at)matronics.com (owner-europa-list-server(at)matronics.com) [mailto:owner-europa-list-server(at)matronics.com (owner-europa-list-server(at)matronics.com)] On Behalf Of Andrew Sarangan
Sent: 02 June 2012 04:09
To: europa-list(at)matronics.com (europa-list(at)matronics.com)
Subject: Re: Europa for repair on AFORS
When I read "just needs fibreglass repairs" what I was picturing was an airframe with a few dings, damaged control surfaces, broken canopy and prop. But the website photo shows the firewall and the tail cone completely separated from the fuselage. It looks far more serious than "just needs fibreglass repairs".
On Fri, Jun 1, 2012 at 2:44 PM, Gerry Holland <gholland(at)content-stream.co.uk (gholland(at)content-stream.co.uk)> wrote:
Comments please.
Gerry
  arget="_blank">http://www.matronics.com/Navigator?Europa-Listtp://forums..matronics.com_blank">http://www.matronics.com/contribution
No infections found in this incoming message
Scanned by iolo System Shield®
http://www.iolo.com
No infections found in this outgoing message
http://www.iolo.com
rparigoris
PostPosted: Sat Jun 02, 2012 8:40 am    Post subject: Europa for repair on AFORS Reply with quote
Hi Gerry
Just a note on the forced landing. Anyone who is trying to fly with a prop that has the ability to truly free windmill better be prepared to count on performance comparable to having a drogue chute in trail with a dead engine. If I were to have a sub setup like this, practice with a stopped (not idling engine) engine would be on my agenda. I met a piper Archer II who walked with a severe limp because one leg was several inches shorter than the other. He was giving a very capable instrument student a last lesson before he took his instrument check ride. Perfect day, long runway, 10MPH right down the runway, clear and very wide runway. several hundred feet over the runway with plenty left, the engine quit. The next thing they both knew they were in a mass of twisted metal on the grass off to the side of the runway? Everyone was having a very hard time figuring out what happened? It ends up the catastrophic engine failure was a broken crankshaft just aft of the main bearing for the prop. This allowed the prop to really spin up without any frictional and other drag from the motor. DRAG CITY! This is not something one could easy practice. They remembered having the nose pointed down a lot further than normal but things went bad anyway. Just to send this message home, the next time you have access to a pinwheel, stick it out car window with 30MPH airspeed and prevent from turning and note drag, then let it spin up WOW. Stuff happens, but if you have this one built in you can somewhat prepare. I don't know if anyone still offers a power plant with free windmilling prop?
Ron Parigoris [quote][b]
Fred Klein
PostPosted: Mon Jun 04, 2012 6:39 am    Post subject: Europa for repair on AFORS Reply with quote
The photos in the ad would seem to indicate that its author is a true believer in The Greater Fool Theory; i.e., in this case, that no matter how foolish one may appear when setting a price for something...a greater fool will eventually buy it...
raimo.toivio(at)rwm.fi
PostPosted: Tue Jun 05, 2012 1:22 pm    Post subject: Europa for repair on AFORS Reply with quote
Hi /All
I read this accident summary. There was a mention
"pilot´s workload was increased because the master
switch was off and the trim was then unavailable".
That is bad.
I have connected the trim and all the warnings
like a gear warning so, that I still have have
them as well as a re-start possibility.
There is a separate mechanical grand-masterswitch
which cuts really everything. I use that only
during long stops (days) /own hangar stops because
that deactivates also an alarm /a bandit radar.
Raimo
-----Alkuperäinen viesti-----
Sent: Saturday, June 02, 2012 1:13 PM
AFORS
vestuti" <s.vestuti(at)gmail.com>
Hi Gerry,
Hope you manage to
find somthing.
asking,
Steve.
http://forums.matronics.com/viewtopic.php?p=374520#374520
browse
Un/Subscription,
FAQ,
Forums!
List Admin.
