Michigan, U.S.A., Moore KIS TR-1 For Sale
mark_trickel
PostPosted: Sun Jun 24, 2012 3:16 am    Post subject: Michigan, U.S.A., Moore KIS TR-1 For Sale Reply with quote
George Moore’s KIS TR-1 is for sale.
Like many builders before, sometime just past the mid 1990s George took a trip out west to see the KIS up close. He went for a ride with Rich in the TR-1, examined the TR-4, and toured the small airplane shop in Oxnard, California. Not long afterward he took delivery of KIS TR-1 kit # 085. He persevered, and the kit was completed in 2001. George has been flying it ever since. George was one of early the pioneers of the Subaru engine conversion and contributed to a Contact Magazine article entitled “Why you should know your ECU; Three Case Studies”. His Subaru experience has proven the Subaru to be a reliable workhorse in the air. George notes his KIS is an excellent performing aircraft and an all around great flying airplane. It has been everything he expected it to be and more. The build features an extended elevator by two inches. The main landing gear is in the stock position and George reports handling in the landing mode to be adequate in this configuration. This airplane has a high level of fit and finish with excellent workmanship exhibited through out the airplane. The well appointed interior has comfortable temperfoam cushions. It is a ten inside and out and a head turner where ever it goes. The airplane has served George well for many years but regrettably it has come time find a new home for it.
KIS TR-1 #085
Total Time - 226 hrs. (equates to less than 20,000 car miles, engine wise)
Power - Subaru 2.2 by Eggenfellner Aircraft with a 1.8 reduction drive
Prop: Prince 68/72
Full gyro panel
Radios:
Garmin GNC 250 GPS/Navcom
Collins Transponder with Mode C (King encoder)
RST marker beacon
Empty Wt. 1046.5
Useable - 403.5 lbs. at 1450 lbs. gross wt.
Useable - 450.5 lbs. at 1500 lbs. gross wt.
Cruise Speed: 170 mph
Top Speed: 200+mph
Typical landing pattern:
Downwind 90 to 100 mph - one notch flaps (12 degrees)
Base leg 90 mph – full flaps (28 degrees)
Final approach 85 mph
Flair out 75 mph
Touch down 68-70 mph
This airplane has been previously offered for sale but the price has been reduced. This is a more than fair price; consider any comparable kit available today.
$36,000.00 U.S. Dollars
If you are interested or know somebody that might be, call George at:
Phone: 517-536-1034
If you would like his email contact me and I will forward it to you.
 Filesize:  180.18 KB
 Viewed:  3229 Time(s)
 Filesize:  296.51 KB
 Filesize:  126.03 KB
