jpleasants(at)bellsouth.n Guest
Posted: Thu Jun 01, 2006 9:51 am Post subject: choices |
Listers:
I'm to the point where I need to make some choices as regards
autopilots.
The advertisements for TruTrak and Trio each "speak highly of
themselves". I can't get a clue as to which of these would be, for me, the
best choice.
I respectfully request that anyone who has a reason to recommend either
of these, or any other, please share with me their thoughts -- good, bad, or
indifferent.
I have the same quandry regarding glass cockpits -- do I choose Dynon,
AFS, GRT, BMT, Chelton, or some other?
All inputs will be appreciated.
Jim Pleasants
RV-7A QB N1QZ(reserved)
sbuc(at)hiwaay.net Guest
Posted: Thu Jun 01, 2006 10:17 am Post subject: choices |
Jim Pleasants wrote:
Listers:
autopilots.
best choice.
indifferent.
Jim Pleasants
Jim, you are opening a can of worms about as messy as asking "which
primer do I use?"!!!
It would be most helpful if you would reply with the mission profile of
your plane. Whether or not you intend IFR ops, plan to install multiple
electrical systems, budget, etc, etc will have a huge bearing on how you
want to equip your plane. Also, your choice of EFIS will have a big
impact on which autopilot will best suit your needs.
You might also do some digging in the archives of this list. These
matters have been hashed to death during the past few years and you
might find a head start to your research.
I have experience with various autopilots and EFII but will withhold my
observations until we know more about how you intend to use your plane.
Fortunately, the new digital equipment as a general rule works very well
so it comes down mostly to what you like more than what will work.
Sam Buchanan
http://thervjournal.com
walter(at)tondu.com Guest
Posted: Thu Jun 01, 2006 10:36 am Post subject: choices |
> autopilots.
> best choice.
> indifferent.
I have had zero regrets going with the GRT/TT combination. I have no
experience with the other options you mention.
I would make the same decision again.
Walter Tondu
http://www.rv7-a.com
Flying!
stein(at)steinair.com Guest
Posted: Thu Jun 01, 2006 11:13 am Post subject: choices |
Jim,
This is a discussion which simply can't be hashed out in an email...there is
far too many factors invloved - if you'd like give me a call off line and we
can discuss the various options out there and which one probably might fit
your overall needs the best. It truly depends on the plan of your flying
mission, instruments in the panel, radios/Avionics, EFIS's, your flight
rating (IFR/VFR), etc... It used to be pretty simple, but now it's quite
complex as there are a LOT of options regarding AP and EFIS combinations
along with functionality. I'm pretty familiar with both the Trio and
Trutrak, as well as all of the Glass options too.
Stein
RV6's, Minneapolis
[quote]--
