Need Fuel System Parts for TechoAvia SP55
SP55
PostPosted: Fri May 25, 2012 5:42 pm    Post subject: Need Fuel System Parts for TechoAvia SP55 Reply with quote
Sorting through multiple fuel indication and low fuel warning issues on my TechnoAvia SP55M.
Going to have to replace the cheap westach guage with one that I can calibrate to the voltage output of my fuel senders. Anyone have any experience with Aerospace Logic programmable fuel level gauges?
Also looking for a part. See attached photo. This is a switch that activates the right fuel tank low light. It is magnetically activated. Could not get any continuity between the posts. The switch part is glued into the back of this piece. Would this be a common part with any of the other Yaks or CJ's? I need one.
Also need a float for the left fuel low indication light. Looked in the tank and my float don't float.
So if anyone is familiar with TechnoAvia fuel system parts and where to buy some, please send me the info.
Francisbutler(at)mac.com
 Filesize:  66.34 KB
 Viewed:  2279 Time(s)
