brubakermal(at)yahoo.com Guest
Posted: Thu May 17, 2012 9:59 am Post subject: MK II twinstar plans and drawings |
i came acrost my set of plans and drawings from my mk11 that i sold 15 years ago
there up for grabs please contact me off list for moor info mal
Malcolm & Jeanne Brubaker
Michigan Sport Pilot Repair
http://michigansportpilotrepair.com
LSRM-A, PPC, WS
Great Sails - Sailmaker
for Ultralight & Light Sport
(989)513-3022
Sent: Thursday, May 17, 2012 9:17 AM
Subject: Re: CG on a MK II twinstar
--> Kolb-List message posted by: "Richard Pike" <richard(at)bcchapel.org (richard(at)bcchapel.org)>
zeprep251(at)aol.com wrote:
| Quote: | Gene,
I really believe adjusting the controls to overcome a CG problem does a terrible disservice to a normally good handling airplane.The weight and balance is the way to go. Someone will give you the info you need Lee, How about it Crystal,do you still have that info?
G.Aman MK3C
I think "adjusting the controls to overcome a CG problem" is an oversimplification when it comes to fine tuning the Kolb wing and how it works. The normal procedure is to get the CG right where it needs to be, and then fly it. If it flies like it wants to keep nosing up, you can either put a trim tab on the elevator to hold the nose down, or droop the ailerons. (or flaps) If it flies like it wants to keep nosing down, once again, you can adjust a trim tab to raise the elevators, or raise the ailerons. (or flaps) The airplane responds well to moving the center of lift aft or forwards across the wing and is the accepted way of fine tuning the aircraft for trim once the CG is correct and everything else is suitable.
That is why I modified my flap lever with 3 positions close together at the nominally up position, to fine tune how the airplane behaves in conjunction with the normal MKIII trim system.
Richard Pike
Kolb MKIII N420P (420ldPoops)
richard (at) bcchapel(dot)org
Kingsport, TN 3TN0
Now faith is the substance of things hoped for, the evidence of things not seen.
Hebrews 11:1
http://forums.matronics.com/viewtopic.php?p=373220#373220http://www.matronics.com/Navigator?Kolb-List
Richard Pike
Posted: Thu May 17, 2012 6:27 pm Post subject: Re: MK II twinstar plans and drawings |
Dude: Why don't you scan them and put them on the list? That is something that deserves to be archived, and you would be doing something that many would appreciate! Yeah, it's a lot of work, but still...
Kingsport, TN 3TN0
Posted: Thu May 17, 2012 7:27 pm Post subject: MK II twinstar plans and drawings |
i would consider that, any body wanta pay for it? I cant scan that large a stuff
LSRM-A, PPC, WS
(989)513-3022
Sent: Thursday, May 17, 2012 10:27 PM
Subject: Re: MK II twinstar plans and drawings
Richard Pike
Kingsport, TN 3TN0
Hebrews 11:1
http://forums.matronics.com/viewtopic.php?p=373258#373258
