trigo(at)mail.telepac.pt Guest
Posted: Thu May 17, 2012 9:45 am Post subject: Building the tail cone |
Question for those who used a quickbuild fuselage:
Did you build the tail cone structure using the quickbuild fuselage as a hanger (not to be mistaken with hangAr)?
In other words, did you hang the tail cone structure on the fuselage when building it, or did you build it separately?
Carlos
philperry9
Posted: Thu May 17, 2012 9:52 am Post subject: Building the tail cone |
On Thursday, May 17, 2012, Carlos Trigo wrote:
It is done separately and attached after the fuselage is built.
Carlos
get="_blank">http://www.matronics.com/Navigator?RV10-List
tp://forums.matronics.com
dmaib@me.com
Joined: 25 Apr 2006 Posts: 455 Location: New Smyrna Beach, Florida
Posted: Thu May 17, 2012 10:03 am Post subject: Building the tail cone |
It is built separately. The plans tell you when to attach the tail cone to the fuselage.
David Maib
40559
RV-10 Transition Trainer
Carlos
style="color: blue; text-decoration: underline; ">http://www.matronics.com/Navigator?RV10-List
blue; text-decoration: underline; ">http://forums.matronics.com
style="color: blue; text-decoration: underline; ">http://www.matronics.com/contribution
_________________ David Maib
RV-10 #40559
New Smyrna Beach, FL |
Bob Turner
Posted: Thu May 17, 2012 12:54 pm Post subject: Re: Building the tail cone |
Due to a backlog of QB orders at Vans', my tailcone was completed before I ever had the QB fuselage.
_________________ Bob Turner
RV-10 QB |
Kelly McMullen
Posted: Thu May 17, 2012 6:27 pm Post subject: Building the tail cone |
About what I had...ordered when I figured I need the QB in 10 weeks. 8
months later I got my shipment, with some significant errors by the
"new" QB facility. Hopefully they have improved in the last 2 yrs.
On Thu, May 17, 2012 at 1:54 PM, Bob Turner <bobturner(at)alum.rpi.edu> wrote:
A&P/IA, EAA Tech Counselor
KCHD |
civengpe
Posted: Fri May 18, 2012 3:46 am Post subject: Building the tail cone |
If you are concerned about the quality of the QB, one option is Wally at Synergy Air. He did both my QB wings and fuse. The workmanship was second to none and it was the same price as Van's.
Shannon
On May 17, 2012, at 9:26 PM, Kelly McMullen <apilot2(at)gmail.com> wrote:
> Bob Turner
> RV-10 QB
> http://forums.matronics.com/viewtopic.php?p=373247#373247
Posted: Fri May 18, 2012 4:16 am Post subject: Building the tail cone |
Well, thanks for the answers, but I do know that the plans tell you to build the tail cone separately from the middle and forward fuselage.
What I want to know is if anybody used, or recommends using the QB fuselage to hang the tail cone structure, while building the tail cone.
If not, where does everybody put the tail cone while building it? Just laid over your work bench, or did you make a kind of gig?
Carlos
[quote] --
EdKranz
Joined: 29 Dec 2010 Posts: 132 Location: Hastings, MN
Posted: Fri May 18, 2012 4:48 am Post subject: Building the tail cone |
I'm just finishing up my tail cone, and I think having it attached to the fuse would just make it almost impossible to get things installed. Once you put the longerons and top skin on, it's fully rigid and doesn't need a jig.
I built mine on a pair of 2x3's screwed to the top of my bench, overhanging about 2.5 feet. I think I got this idea from Tim Olsen. Worked awesome! This both supported everything well and kept a gap between the bench top and the skins so the clecos wouldn't have interference.
I am keeping video of my entire build, so you can see exactly how it goes together here (and in later videos as well):
http://www.edandcolleen.com/tail-cone-taking-shape/
I have been able to do all construction on the tail cone single handed up to the point I'm at now.
On Fri, May 18, 2012 at 7:14 AM, Carlos Trigo <trigo(at)mail.telepac.pt (trigo(at)mail.telepac.pt)> wrote:
Carlos
_________________ Ed Kranz
RV10
Finishing
www.edandcolleen.com |
Posted: Fri May 18, 2012 5:18 am Post subject: Building the tail cone |
It sits on a work bench. Amazingly the CNC pre-punch system is so good that if you follow the instructions the tail cone mates perfectly with the fuselage.
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Carlos Trigo
Sent: Friday, May 18, 2012 8:15 AM
Subject: RE: Re: Building the tail cone
Carlos
[quote] --
mauledriver(at)nc.rr.com Guest
Posted: Fri May 18, 2012 5:21 am Post subject: Building the tail cone |
Hanging it would only make it more difficult. You'll want to build the tailcne on a flat bench. No jig.
What worked well for me was large back riveting plate. Mine was about 24" x 12" x 1/4" (guesstimate) from a local scap yard. This was laid on the bench and scrap 1/4" ply from the crate was used to fit around the plate to provide a folate surface for the cone to lie on.
With that setup, you can backrivet 80% or more of rivets flat on the bench. That makes high quality results very easy. A short and long backrivet set is needed.
For many of the rivets that can't be backriveted flat on the bench, you can use a back rivet bucking bar (larger mushroom shaped) and bang the rivets with the backrivet set from inside the cone. Again, most of this is easily done laying on a flat bench.
I considered most riveting that required crawling in the cone after it was hung the result of planning oversights. Everything done on the bench was done single handed.
Bill Watson
On May 18, 2012, at 8:14 AM, "Carlos Trigo" <trigo(at)mail.telepac.pt (trigo(at)mail.telepac.pt)> wrote:
Carlos
[quote] --
Posted: Fri May 18, 2012 5:49 am Post subject: Building the tail cone |
I should add that for the clecoing and match drilling you need saw horses or something to raise cone off the bench to clear the clecos. It becomes pretty obvious as you proceed.
Yes, the accuracy of the CNC stuff is simply amazing. It just all fits despite your best efforts.
Bill
On May 18, 2012, at 9:20 AM, Bill Watson <mauledriver(at)nc.rr.com (mauledriver(at)nc.rr.com)> wrote:
[quote]Hanging it would only make it more difficult. You'll want to build the tailcne on a flat bench. No jig.
Bill Watson
Carlos
[quote] --
Posted: Fri May 18, 2012 6:00 am Post subject: Building the tail cone |
Thanks Ed
That’s exactly the kind of answer I was looking for
Carlos
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Ed Kranz
Sent: sexta-feira, 18 de Maio de 2012 13:48
Subject: Re: Re: Building the tail cone
Carlos
| Quote: | | http://www.matronics.com/Navigator?RV10-List | 0123456789
Posted: Fri May 18, 2012 6:01 am Post subject: Building the tail cone |
Thanks Bill
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Bill Watson
Sent: sexta-feira, 18 de Maio de 2012 14:21
Bill Watson
Carlos
[quote] --
Kellym
Posted: Fri May 18, 2012 6:58 am Post subject: Building the tail cone |
If you are just starting out, it is well worth the money to get a #40
and #30 chucking reamer. Keeps the holes rounder and more accurate, as
well as reducing need for deburring. (actually, since most holes are
dimpled, which enlarges the hole, a #41 reamer gives a finished hole
closer to AN3 rivet size). Avery and other tool sources stock the reamers.
On 5/18/2012 6:48 AM, Bill Watson wrote:
[quote] I should add that for the clecoing and match drilling you need saw
Bill
> Bill Watson
> Sent from my iPad
>> Carlos
KCHD |
rleffler
Posted: Fri May 18, 2012 7:07 am Post subject: Building the tail cone |
Serves no real advantage other than to take up more space. Following the plans in this case would be the best practice.
On May 18, 2012, at 7:14 AM, "Carlos Trigo" <trigo(at)mail.telepac.pt (trigo(at)mail.telepac.pt)> wrote:
Carlos
[quote] --
_________________ Bob Leffler
N410BL - Phase I
http://mykitlog.com/rleffler |
jeff(at)westcottpress.com Guest
Posted: Fri May 18, 2012 8:52 am Post subject: Building the tail cone |
It helps to have one of these:
[img]cid:92CBDAD4-BCE5-4ACB-9391-B457C8F9FA1F[/img]
On May 18, 2012, at 5:14 AM, Carlos Trigo wrote:
[quote]Well, thanks for the answers, but I do know that the plans tell you to build the tail cone separately from the middle and forward fuselage.
Carlos
[quote] --
149.18 KB |
9239 Time(s) |
robin(at)PaintTheWeb.com Guest
Posted: Fri May 18, 2012 9:25 am Post subject: Building the tail cone |
I strongly suggest renting one of those. There are many maintenance issues associated with ownership.
Robin
Sent from the new iPad
On May 18, 2012, at 10:16 AM, "Jeff Carpenter" <jeff(at)westcottpress.com (jeff(at)westcottpress.com)> wrote:
[quote] It helps to have one of these:
<100_3235.jpg>
[quote] Well, thanks for the answers, but I do know that the plans tell you to build the tail cone separately from the middle and forward fuselage.
Carlos
149.18 KB |
9238 Time(s) |
taildragon(at)msn.com Guest
Posted: Fri May 18, 2012 1:37 pm Post subject: Building the tail cone |
<?xml:namespace prefix="v" /><?xml:namespace prefix="o" /><![endif]--> Couldn't have done it without mine!
Roger
#40291 flying 215 hours
