Sudden loss of power susequent emergency landing
brad(at)runawaymedia.co.z
PostPosted: Sat May 05, 2012 8:01 am    Post subject: Sudden loss of power susequent emergency landing Reply with quote
Hello all , yesterday ZU-CWJ was participating in a corporate function. Her is the scenario.
Pilot : Comm +700 hrs
  250 on yak 52
  Aerobatic rating
  Aerobatic display rating
Aircraft : Yak 52 1985
AF     TT 876
Eng     TT 1850 smoh 425
After 2 pax flights he loaded the 3rd pax and took off , fuel on board 45/50
Oil +8L
After climb out , as he throttled back an audible “crump” was heard and the engine lost all power, as if it was set to idle (38%)
Pilot cycled the throttle the engine momentarily tried to pick up revs but failed and continued to mill as if in and idle.
Pilot closed the flaps and the gear and converted height into speed putting the aircraft down wheels up on the beach on the downwind leg of the circuit, no injuries
The prop is shorter and some structural damage to the tail section and rudder /elevator from the surf.
(http://www.ecr.co.za/kagiso/content/en/east-coast-radio/east-coast-radio-news?oid=1607463&sn=Detail&pid=6028&-Photos--Plane-crash-on-Durban-beach)
Post recovery :
Tanks: both had fuel
Oil: 8 litres
Prop: can still be rotated
Throttle fully functional both to Max and min
Any possible suggestions?
Brad
Bradly Banks
Merlin Aviation Services
Cell:0825083200
Tel :0333308580
Email :Brad(at)runawaymedia.co.za
Skype: bradly.banks
dsavarese0812(at)bellsout
PostPosted: Sat May 05, 2012 12:00 pm    Post subject: Sudden loss of power susequent emergency landing Reply with quote
If the prop can be rotated, check the following:
Compressions on all cylinders
Engine timing - verify the engine timing on both magnetos.
Let me know what you find out with these two checks. We'll proceed from
there after these two checks.
A. Dennis Savarese
334-285-6263
334-546-8182 (mobile)
www.yak-52.com
Skype - Yakguy1
250 on yak 52
Aerobatic rating
AF TT 876
After 2 pax flights he loaded the 3^rd pax and took off , fuel on
board 45/50
Oil +8L
<http://www.ecr.co.za/kagiso/content/en/east-coast-radio/east-coast-radio-news?oid=1607463&sn=Detail&pid=6028&-Photos--Plane-crash-on-Durban-beach>)
Post recovery :
Oil: 8 litres
Brad
Bradly Banks
Cell:0825083200
Tel :0333308580
Skype: bradly.banks
viperdoc(at)mindspring.co
PostPosted: Sat May 05, 2012 7:39 pm    Post subject: Sudden loss of power susequent emergency landing Reply with quote
Did you have a chance to look at fuel and oil pressure?
On May 5, 2012, at 2:57 PM, "A. Dennis Savarese" <dsavarese0812(at)bellsouth.net> wrote:
Let me know what you find out with these two checks. We'll proceed from there after these two checks.
A. Dennis Savarese
334-285-6263
www.yak-52.com
Skype - Yakguy1
> 250 on yak 52
> Aerobatic rating
> AF TT 876
> After 2 pax flights he loaded the 3^rd pax and took off , fuel on board 45/50
> Oil +8L
> (http://www.ecr.co.za/kagiso/content/en/east-coast-radio/east-coast-radio-news?oid=1607463&sn=Detail&pid=6028&-Photos--Plane-crash-on-Durban-beach <http://www.ecr.co.za/kagiso/content/en/east-coast-radio/east-coast-radio-news?oid=1607463&sn=Detail&pid=6028&-Photos--Plane-crash-on-Durban-beach>)
> Post recovery :
> Oil: 8 litres
> Brad
> Bradly Banks
> Cell:0825083200
> Tel :0333308580
> Skype: bradly.banks
PostPosted: Sat May 05, 2012 10:46 pm    Post subject: Sudden loss of power susequent emergency landing Reply with quote
Good morning Rodger, firstly thank you for your kind consideration as far as im aware the pilot did confirm the run up procedure before the take off and confirms all was in order also on the level out glanced at the oil and was satisfied all was ok, in the subsequent high pressure situation did not have time to verify that information.
Kind regards
Brad
PostPosted: Sun May 06, 2012 9:25 am    Post subject: Sudden loss of power susequent emergency landing Reply with quote
Morning to you also Brad...more like early Monday morning now down under.
I can speculate on what caused the loss of power but the tear down will answer the majority of your questions. Having gone through an engine issue one year ago now, the obvious as speculated was not the answer. They were close but no banana. Wait for the tear down. The answers will be forthcoming. Tough to do in this age of instant gratification for sure but the answer at tear down may surprise you. It did for me.
Glad all walked away without injury.
From there to this, it was not what I thought as revealed by the tear down. It was maliciously introduced FOD. Bottom line, it will be a better plane when done as yours will be also.
Good luck.
Doc
On May 6, 2012, at 1:28 AM, "Bradly Banks" <brad(at)runawaymedia.co.za> wrote:
Kind regards
Brad
 Filesize:  52.02 KB
 Viewed:  5438 Time(s)
 Filesize:  36.38 KB
 Filesize:  46.09 KB
 Filesize:  45.68 KB
PostPosted: Sun May 06, 2012 10:34 am    Post subject: Sudden loss of power susequent emergency landing Reply with quote
Dear all, Its quite emotional, seeing the aircraft you have tendered so
carefully lying on the beach , helpless was really came to mind, but even
more precious than this was all the encouragement off this particular forum,
Thanks to Dennis , and Rodger , Jill and Mike Beresford. May we long
continue to build the community through these kind and considerate replies,
they are ostensibly the very back bone of the yak community.
I will wait to see what the CAA here recommend , (not really confident that
they will even pitch up to inspect the situation.)
Hopefully we will be able make a speedy and complete restoration
Kindest regards
Brad
