40950(at)rv10.net Guest
Posted: Thu May 03, 2012 6:01 pm Post subject: Low Fuel Sensor Location |
Looking for information regarding where to locate low fuel sensor in inboard tank ribs related to vertical height vs location. I am building tanks, would like to drill and install before final assembly, have calculated a location but would like to verify my results. Looking for fuel measurements once installed. I have AE Fuel Guardian sensors.
Any related data would be appreciated.
Tom Koelzer
40950 Wings
rleffler
Posted: Fri May 04, 2012 4:58 pm Post subject: Low Fuel Sensor Location |
Attached is a photo that Scott Schmidt provided me several years ago. I put
mine in the same location.
Bob
1.32 MB |
7013 Time(s) |
_________________ Bob Leffler
N410BL - Phase I
http://mykitlog.com/rleffler |
Posted: Fri May 04, 2012 7:02 pm Post subject: Low Fuel Sensor Location |
Thanks Bob,
I'm planning to put my sensor in the same position fore and aft but probably an inch or so lower to get warning at about 4 1/2 gal useable per my calculations. Do you know what fuel level corresponds to the sensor location in the picture you attached?
Tom
rleffler
Posted: Sat May 05, 2012 1:22 am Post subject: Low Fuel Sensor Location |
My memory seems to recall about five gallons, but I'm sure that Scott can share his results since he's been flying for awhile. I'm about 90 days away from putting fuel in the tanks.
Bob
On May 4, 2012, at 11:01 PM, Tom Koelzer <40950(at)rv10.net> wrote:
Thanks Bob,
Tom
N410BL - Phase I
glastar(at)gmx.net Guest
Posted: Sun May 06, 2012 10:29 pm Post subject: Low Fuel Sensor Location |
Bob,
do you know, what amount of fuel is left when the warning comes on?
Many thanks
Werner
On 05.05.2012 02:46, Bob Leffler wrote:
[quote] Attached is a photo that Scott Schmidt provided me several years ago. I put
Bob
rleffler
Posted: Mon May 07, 2012 1:36 am Post subject: Low Fuel Sensor Location |
| Quote: | From what I recall in conversations with Scott, it should be about 5 gallons. I made those mods about three years ago, so the memory is a little fuzzy. I will test in July when I first put fuel in the tanks.
Bob
On May 7, 2012, at 2:28 AM, Werner Schneider <glastar(at)gmx.net> wrote:
Bob,
Many thanks
Werner
> Bob
N410BL - Phase I
Posted: Mon May 07, 2012 11:11 am Post subject: Low Fuel Sensor Location |
Werner,
I sent a PM to Scott Schmidt asking him same question. I'll post once I
find out.
Tom
Werner Schneider writes:
Bob,
Many thanks
Werner
jchang10
Posted: Mon May 07, 2012 11:30 am Post subject: Low Fuel Sensor Location |
I can confirm. I used Scott's measurements, and i got the optical
warning at 5 gallons in level flight the other day. However, with
turbulence, it can warn with as high as 10 gallons.
Jae
On 5/7/2012 12:10 PM, Tom Koelzer wrote:
| Quote: | Werner,
I find out.
Tom
> Bob,
> Many thanks
> Werner
#40533 RV-10
First flight 10/19/2011
Phase 1 Done 11/26/2011
_________________ #40533 RV-10
Phase 1 Done 11/26/2011 |
Posted: Mon May 07, 2012 12:07 pm Post subject: Low Fuel Sensor Location |
Have you ever verified by fuel measurement on the ground or just indication
on the fuel gauge in flight?
Tom
Jae Chang writes:
I can confirm. I used Scott's measurements, and i got the optical warning
at 5 gallons in level flight the other day. However, with turbulence, it
Jae
rene(at)felker.com Guest
Posted: Mon May 07, 2012 12:34 pm Post subject: Low Fuel Sensor Location |
I did my own measurements and used a different point ....but I could not find it in my documentation....I will keep looking and let you know if I find it. Mine warns at about 3 gallons, smooth air, level flight. At 6 gallons in turbulence and approach to landing with a little bit of rudder work.
I am happy with mine. I get a 10 gallon alarm from the efis based on fuel burn, a 5 gallon alarm on each tank from the float sensor, and a 3 gallon or more alarm from the optical......
I should never run out of gas......
I normally do not fly with both tanks less than 10 gallons....so it is unusual for me to get any of the alarms.
Rene' Felker
N423CF
801-721-6080
jchang10
Posted: Mon May 07, 2012 12:37 pm Post subject: Low Fuel Sensor Location |
No, i have never verified the optical warning on the ground. It would
be a somewhat moot point for me since the optical sensor was installed
at least 4 years prior to my wings installed. there was no way i was
going to change its location now. thus, yes, 5 gals is what was
indicated form the float senders only, which were calibrated every 2
gallons.
Jae
On 5/7/2012 1:06 PM, Tom Koelzer wrote:
| Quote: | Have you ever verified by fuel measurement on the ground or just
indication on the fuel gauge in flight?
Tom
Jae Chang writes:
> Jae
#40533 RV-10
Posted: Mon May 07, 2012 1:25 pm Post subject: Low Fuel Sensor Location |
Thanks Jae,
I'm trying to decide before I drill the hole and prior to final assembly.
Tom
michael(at)sausen.net Guest
Posted: Mon May 07, 2012 3:41 pm Post subject: Low Fuel Sensor Location |
If you can find my entries in the http://www.mykitlog.com/msausen/ site, I actually put one of the wings in flight orientation and used a manometer to set the 5gal mark. Haven't flown it yet though so YMMV.
Michael
Posted: Mon May 07, 2012 4:04 pm Post subject: Low Fuel Sensor Location |
Bob,
Thanks! That is very close to the position I have chosen for which my calculations show 4.7 gal total or an estimate of 4.4 gal useable (sucking air). Jae reports his sensor on at 5 gal in level flight using the same Scott Schmidt location.
Tom
Begin forwarded message:
| Quote: | From: Bob Leffler <bob(at)thelefflers.com (bob(at)thelefflers.com)>
Subject: Fuel sensor
Date: May 7, 2012 4:43:50 PM CDT
To: Tom Koelzer <40950(at)rv10.net (40950(at)rv10.net)>
The bottom is on the right. This is a photo of my right wing.
[img]cid:6802CC7F-F6B3-4F37-B899-C6BD726E952B[/img]
264.85 KB |
6968 Time(s) |
Posted: Mon May 07, 2012 6:00 pm Post subject: Low Fuel Sensor Location |
Michael,
Looked at your the relevant page at:
http://tinyurl.com/msausen
There you stated you marked the tank for 2.5 gal (vs the 5gal) and the mark on your tank is consistent with my calculations. I had included the 3.5 deg dihedral but not the incidence but further calculations showed only a decrease in my figures by about one-half pint because of fuel being higher towards the back of the tank. And that looked pretty close to what you measured.
All this means is that I have more confidence my model calculations are consistent with results, at least at the 5 gal and 2.5 gal levels. But as others have stated, sensor indications vary, maybe even double for rough air or rudder inputs (I'm probably measuring with a micrometer and cutting with an axe). This was really only a cerebral exercise more than anything.
Thanks to all who responded. I will provide analysis if interested.
Tom
40950
On May 7, 2012, at 6:39 PM, Michael Sausen wrote:
Michael
larkrv10(at)gmail.com Guest
Posted: Tue May 08, 2012 5:39 pm Post subject: Low Fuel Sensor Location |
Hey Michael
I see in your KIt Pro log, you stated dihedral was 3.5 degrees, and angle of incidence was 1.5 degrees plus. Does that mean the spar is leaning 1.5 degrees at the top or bottom? I guess since there is almost always some turbulence in flight, it probably doesn't matter. Does this sound right to you? I'm also going to install optical sensors. Thx for your advise.
Rick
#40956
Southampton, Ont
On Mon, May 7, 2012 at 7:39 PM, Michael Sausen <michael(at)sausen.net (michael(at)sausen.net)> wrote:
[quote]--> RV10-List message posted by: Michael Sausen <michael(at)sausen.net (michael(at)sausen.net)>
Michael
rv10rob(at)gmail.com Guest
Posted: Wed May 09, 2012 12:38 pm Post subject: Low Fuel Sensor Location |
A bit off topic, I know, but I'm curious: what problem does having this low fuel sensor solve?
-Rob
On Tue, May 8, 2012 at 6:38 PM, Rick Lark <larkrv10(at)gmail.com (larkrv10(at)gmail.com)> wrote:
[quote]Hey Michael
Rick
#40956
Southampton, Ont
Michael
Posted: Wed May 09, 2012 1:51 pm Post subject: Low Fuel Sensor Location |
Being stupid and running out of gas…..that is after I ignore the two other warnings I would have received by then. Would also be helpful in a fuel leak situation where the fuel flow and tank float sensors did not agree……the low fuel sensor would be the tie breaker….i.e. the fuel flow sensor (calculation) shows you have not used 25 gallons, but the mechanical sensor in the tank does and the low fuel optical sensors also says you are down to 5 gallons…..
Rene' Felker
N423CF
801-721-6080
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Rob Kochman
Sent: Wednesday, May 09, 2012 2:36 PM
Subject: Re: Low Fuel Sensor Location
-Rob
Hey Michael
Rick
#40956
Southampton, Ont
Michael
rleffler
Posted: Wed May 09, 2012 4:36 pm Post subject: Low Fuel Sensor Location |
It just another idiot light to remind you before you run the tank dry.
On May 9, 2012, at 4:35 PM, Rob Kochman <rv10rob(at)gmail.com (rv10rob(at)gmail.com)> wrote:
[quote]A bit off topic, I know, but I'm curious: what problem does having this low fuel sensor solve?
-Rob
[quote]Hey Michael
Rick
#40956
Southampton, Ont
Michael
N410BL - Phase I
Posted: Wed May 09, 2012 7:25 pm Post subject: Low Fuel Sensor Location |
The reality is it's probably not going to matter much. I did go back and notice I set it at 2.5. The main reason being that the fuel levels are going to be a lot more sensitive as the tank empties. E wise of the dihedral. I didn't want it false alarming a lot in turbulence or turns I possible. As bob said, it is really a last chance, pay attention dummy, type warning.
On May 8, 2012, at 6:49 PM, "Rick Lark" <larkrv10(at)gmail.com (larkrv10(at)gmail.com)> wrote:
[quote] Hey Michael
Rick
#40956
Southampton, Ont
[quote] --> RV10-List message posted by: Michael Sausen <michael(at)sausen.net (michael(at)sausen.net)>
Michael
