Posted: Sun Apr 29, 2012 1:55 pm Post subject: Fuel vent modification |
Here is a simple way to keep mud-dabbers from clogging your fuel vent. I think more than one RV has collapsed a fuel tank from a clogged vent.
Take a few inches of 3/8” aluminum tubing, cut one end at 45 degrees or so, then JB Weld on a piece of aluminum window screen material. Once the JB Weld is cured, clean up the edge on a ScotchBrite wheel or similar. Do a ¾” cut in the other end for a hose clamp, then slide this over the now somewhat shortened standard ¼” vent tubing. Have the ¼” tubing extend well past where the clamp goes.
Carl
RV-8A (800 hours)
RV-10 (FSDO comes to inspect May 23rd)
83.03 KB |
7621 Time(s) |
dlm34077(at)q.com Guest
Posted: Sun Apr 29, 2012 2:45 pm Post subject: Fuel vent modification |
A simpler solution; just drill a size 50 hole inside the intersection fairing on the back side of the vent tube. It will also prevent impact ice from sealing a vent.
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Carl Froehlich
Sent: Sunday, April 29, 2012 2:54 PM
To: rv10-list(at)matronics.com; rv8-list(at)matronics.com; rv-list(at)matronics.com
Subject: Fuel vent modification
Carl
RV-8A (800 hours)
dmaib@me.com
Joined: 25 Apr 2006 Posts: 455 Location: New Smyrna Beach, Florida
Posted: Sun Apr 29, 2012 5:21 pm Post subject: Re: Fuel vent modification |
That looks like a great solution, Carl. I have tried to use JB Weld to glue a similar piece of window screen on the existing vent, and it is so small that it is difficult to get the screen to stay in place.
It seems to me that the #50 hole on the back of the tube inside the wing root would work as a way to prevent ice from blocking your vent tube, but couldn't a mud dauber go past the hole and do it's thing? I also think I would prefer not to have a vent inside the fairing because of the potential for fumes or avgas venting inside the fairing.
_________________ David Maib
RV-10 #40559
New Smyrna Beach, FL |
JohnCiolino(at)carolina.r Guest
Posted: Sun Apr 29, 2012 11:46 pm Post subject: Fuel vent modification |
An alternate method: flare the end of the tube, cut a circular patch of flexible fiberglass screening and make radial cuts leaving center ¼” uncut. The cuts will allow you to wrap the screen around the tube overlapping the cut pieces. Secure the screen with a piece of shrink tubing.
Easy to do, lasts a long time (2 years so far on my - but can be easily replaced if necessary.
John Ciolino
RV-8
N894Y
From: owner-rv8-list-server(at)matronics.com [mailto:owner-rv8-list-server(at)matronics.com] On Behalf Of Carl Froehlich
Sent: Sunday, April 29, 2012 5:54 PM
Carl
RV-8A (800 hours)
Posted: Mon Apr 30, 2012 3:00 am Post subject: Fuel vent modification |
Yep, the 1/4" tubing is just too small to do this. I think I will add the small hole for the ice issue.
I've had this vent mod on my 8A for 10 years - works fine.
Carl
On Apr 29, 2012, at 9:21 PM, "dmaib(at)me.com" <dmaib(at)me.com> wrote:
David Maib
RV-10 #40559
Transition Trainer
http://forums.matronics.com/viewtopic.php?p=372110#372110
michael(at)sausen.net Guest
Posted: Mon Apr 30, 2012 5:20 am Post subject: Fuel vent modification |
For anyone that lives in an area where these critters are common, I highly recommend you do something to keep them from blocking your vent. I had one block the crankcase vent on my motorcycle years ago and it took me two trips to the dealership to try and figure out why I had oil coming up the clutch cable before one of the guys said check your breather for mud daubers and sure enough, it was plugged tight. Couple of good raps on the tube and a whole lot of dirt later and the problem went away. I’m confident that one of these guys could cause a tank collapse from the vacuum.
Michael
Sent: Sunday, April 29, 2012 4:54 PM
Carl
RV-8A (800 hours)
Kellym
Posted: Mon Apr 30, 2012 5:56 am Post subject: Fuel vent modification |
There just might be some pitot tube covers that would do the trick. Old
aircraft from the post WWII era had pitots that were just 1/4" tubing,
like the Cessnas of that era. Reminds me, should check with airport
maintenance...they collect pitot covers by the dozens off the runways.......
On 4/30/2012 6:18 AM, Michael Sausen wrote:
Michael
Checked by AVG - www.avg.com
KCHD |
Tim Olson
Posted: Mon Apr 30, 2012 7:35 am Post subject: Fuel vent modification |
You'd still have to protect the hole from Mud Daubers if you
are in an area where that is something that can happen, but,
there is a way to do a vent in the wing root that shouldn't
cause fume issues:
http://www.myrv10.com/N104CD/upgrades/20090525/index.html
I have a one-way checkvalve in there so that if the vent
ices over, I can't have a vacuum collapse on the tank.
I saw this one from the Lancair builders.
Tim
On 4/29/2012 8:21 PM, dmaib(at)me.com wrote:
David Maib
RV-10 #40559
Transition Trainer
Posted: Mon Apr 30, 2012 8:07 am Post subject: Fuel vent modification |
Another area for blockages is the end of the fuel quick drains; at 1H0 I
left the Glastar overnight and returned the next day to an egg sac inside
the hole where the fuel cup pin is inserted. Gasoline takes a while to clean
it out; usually quicker to change drains and soak the fitting in acetone or
gasoline overnight.
deej(at)deej.net Guest
Posted: Mon Apr 30, 2012 12:04 pm Post subject: Fuel vent modification |
On 04/29/2012 05:53 PM, Carl Froehlich wrote:
| Quote: | Here is a simple way to keep mud-dabbers from clogging your fuel vent.
Here is another simple and cheap way to keep mud daubers out of your vent:
http://deej.net/glastar/pics/measure/photo7.jpg
I think I paid $0.99 for a pack of 100:
http://www.walmart.com/ip/Kids-Craft-100pk-Fuzzy-Sticks-Neon/19525338
1) Take one fuzzy stick and cut it in half.
2) Take one of the halves and fold in two forming a "V".
3) About 2 inches from the base of the "V", bend each side out 90
degrees. You will end up with a shape like _/\_
4) Stick the end of the "V" into your vent.
5) Add it to your checklist to remove during pre-flight. If you do
happen to forget to remove them, they do allow some air to pass. You
could use the whole fuzzy stick per vent if you wanted to make them
longer and stick out more to be more noticeable for a low wing plane.
-Dj
Dj Merrill - N1JOV
Sportsman 2+2 Builder #7118 N421DJ - http://deej.net/sportsman/
Glastar Flyer N866RH - http://deej.net/glastar/
nukeflyboy
Joined: 05 Jan 2008 Posts: 162 Location: Granbury, TX
Posted: Tue May 01, 2012 10:41 am Post subject: Re: Fuel vent modification |
Here is another suggestion.
I bought a small ball check valve from Grainger. It has a 1/4 NPT fitting and is small, about the size of an AN fitting. I used a Tee to splice it into the vent line inside of the gap. It acts as a vacuum breaker in the event that the vent is blocked for any reason. It also keeps the small positive pressure on the fuel tank.
I can send details later if anyone is interested.
_________________ Dave Moore
RV-6 built and sold
RV-10 built and flying |
