firewall sealing
sean(at)stephensville.com
PostPosted: Tue Apr 24, 2012 6:15 pm    Post subject: firewall sealing Reply with quote
I used some extra biotherm I had left over from buying the firewall
pass-throughs found here...
http://www.planeinnovations.com/firewallkits.html (bottom of page)
I've been looking for a local source for the biotherm 100, but have yet
to find it.
-Sean #40303 (Doors)
On 4/24/12 8:47 PM, Rick Lark wrote:
Hi Guys, I see that Vans wants you to seal the F-1001K stainles recess
with pro seal..Did anyone use some other type of high temp sealant for
this purpose. Seems to me even hi temp RTV would be beter than pro seal?
Comments??
Thx, Rick
#40956
Southampton, Ont
jesse(at)saintaviation.co
PostPosted: Tue Apr 24, 2012 6:26 pm    Post subject: firewall sealing Reply with quote
I prefer the high temp RTV personally. I don't like any pro seal in the engine compartment. Some people have done tests on the pro seal with high heat and it didn't react well, IIRC. I use black high-temp RTV to seal the firewall and all other things in the engine compartment.
Jesse Saint
Saint Aviation, Inc.
C: 352-427-0285
F: 815-377-3694
On Apr 24, 2012, at 9:47 PM, Rick Lark wrote:
[quote]Hi Guys, I see that Vans wants you to seal the F-1001K stainles recess with pro seal..Did anyone use some other type of high temp sealant for this purpose. Seems to me even hi temp RTV would be beter than pro seal?
Comments??
Thx, Rick
#40956
Southampton, Ont
rv10pro(at)gmail.com
PostPosted: Tue Apr 24, 2012 9:40 pm    Post subject: firewall sealing Reply with quote
Rick, the area in question deserves the best sealant possible.  RTV is a cheap and easy solution that does NOT meet the challenge.  I installed a product  Desoto Proseal CS-1900 which was a fiberous proseal type "fire-retandant" sealant with the manufacturers endorsement of higher temperature.  When your fire annunciator system fails.  When Your Fire Suppression system fails, your only recourse is to think of Bob Hoover and pray. Dont use RTV.  Time from point of crisis awareness to remediation is the longest period in your life. FLY the damn aircraft to a safe landing point.
Fly the aircraft to the accident site and insure that all POBs are safely away.  From the moment of acknowledgement of a fire  to the moment of safety, your actions speak volumes on your instruction and skill as a pilot.
I lost a friend leaving OSH a few years ago that failed to heed those words in his Lancair Legacy 2000. Thought he could be a HERO.
"From the moment of acknowledgement to the moment of reflection on your actions , a great pilot knows the aircraft instantly belongs to the insurance company.  Your responsibility is to your passengers, your family and your brothers-in-arms who love flying after your memorial service.  "Dan Lloyd, I still miss you and pray I follow the wiser choice and don't place human life on a $ savings on RTV.". CHOOSE WISELY, FLY OFTEN, THINK ABOUT THOSE WHO WILL FOLLOW.
You guys slay me occasionally on the decision process you follow! DAMN I AM GETTING OLD.
John #40600
On Tue, Apr 24, 2012 at 6:47 PM, Rick Lark <larkrv10(at)gmail.com (larkrv10(at)gmail.com)> wrote:
Comments??
Thx,  Rick
#40956
Southampton, Ont
get="_blank">http://www.matronics.com/Navigator?RV10-List
tp://forums.matronics.com
jrlark
PostPosted: Wed Apr 25, 2012 3:13 am    Post subject: firewall sealing Reply with quote
Thx all, I am on my way to Aircraft Spruce this morning to pick up a few things. I probably will buy a tube of Biotherm 100 which is rated to 2000 degrees. I did find a write up on the Plane Innovations web site, www.planeinnovations.com/firewallkits.html. I will stay away from the RVT.
Rick
Kellym
PostPosted: Wed Apr 25, 2012 6:49 am    Post subject: firewall sealing Reply with quote
I fault Van's for simply calling for proseal when they clearly should be calling for the Proseal 1900 or other suitable sealant. While proseal may be adequate for keeping carbon monoxide from seeping through the firewall, it gives no fire protection. Not to mention Van's supplying aluminum heater control boxes that simply defeat the benefits of having a firewall completely. The Plane innovations or other stainless heater control boxes both work better and restore the all stainless content on the firewall, and come with a small tube of Biotherm. Also unfortunate that Van's doesn't do much product improvement over time. Apparently afraid to admit that something could be better than their original specifications.
John #40600
Checked by AVG - www.avg.com
Kelly McMullen
KCHD
glastar(at)gmx.net
PostPosted: Wed Apr 25, 2012 7:17 am    Post subject: firewall sealing Reply with quote
Kelly,
you forgot to mention, that the FW is as well riveted with alu rivets to
the structure, so that will not help either in case of a fire.
Cheers Werner
dlm34077(at)q.com
PostPosted: Wed Apr 25, 2012 7:34 am    Post subject: firewall sealing Reply with quote
My answer to the fire problem (hope I never need it), 10# of Halon sprayed between the firewall and baffling and over the engine. From Stroud Fire Safety OKC
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Kelly McMullen
Sent: Wednesday, April 25, 2012 7:34 AM
Subject: Re: firewall sealing
Rick,[b] the area in question deserves the best sealant possible[/b].
John #40600
 Filesize:  1.19 MB
 Viewed:  6484 Time(s)
jrlark
PostPosted: Wed Apr 25, 2012 8:28 am    Post subject: firewall sealing Reply with quote
Werner, the fact that there are aluminum rivets crossed my mind too. None
the less John Cox is right, you owe it to your pasengers and yourself to
make the firewall as good as possible. Solid rivets are still more fire
resistant than normal pro seal, and using the Biotherm 100 is a step in the
right direction.
Perhaps another look at the David McNeils under cowling fire suppresion
system is in order.
Rick
rv10flyer(at)verizon.net
PostPosted: Wed Apr 25, 2012 9:06 am    Post subject: firewall sealing Reply with quote
Your hosed if there is a fire! Rivets are the least of your problem, the
issue is sealing the area around the rivets and the areas that are most
prone to "holding off" the fire and smoke with a heat sealant. We are
talking buying time here, the smoke will blind and cause all sorts of
breathing issues, hence the solid steel vents (that I know seal better than
the Vans one) but inhaling burning proseal is not something I would want to
add to the issue.
There are many rivets, there is a whole lot of fiberglass above the area,
the glass will give far sooner than the rivets ever will.
dlm34077(at)q.com
PostPosted: Wed Apr 25, 2012 9:23 am    Post subject: firewall sealing Reply with quote
A before and after photo; I teed it at the firewall, one sprayer was clamped
near the spider and the other was between the firewall and baffling. Be sure
and isolate engine vibrations from the sprayers by a rubber flex tube
between with hose clamps.
 Filesize:  33.16 KB
 Viewed:  6477 Time(s)
 Filesize:  24.16 KB
dlm34077(at)q.com
PostPosted: Wed Apr 25, 2012 9:34 am    Post subject: firewall sealing Reply with quote
If you are worried about fire, think fire suppression. Try http://www.stroudsafety.com/FireExtinguisherSystems.html
All of that fiberglass is going to burn well with a lot of noxious fumes. It's best to put it out. Fuel selector OFF, pull the pin and blow the bottle.
dlm34077(at)q.com
PostPosted: Wed Apr 25, 2012 9:49 am    Post subject: firewall sealing Reply with quote
Email check
