Torque values
cpayne(at)joimail.com
PostPosted: Mon Apr 23, 2012 11:55 am    Post subject: Torque values Reply with quote
Installing an OH'd M-14P which came with new rubber cushions in the mount. Does anyone know if there is a published torque value? So far I tightened the nuts until the mounts were compressed some. Took about 50 in-lbs.
Craig Payne
dsavarese0812(at)bellsout
PostPosted: Mon Apr 23, 2012 12:03 pm    Post subject: Torque values Reply with quote
Craig,
See attached. This should answer your question.
Dennis
A. Dennis Savarese
334-285-6263
334-546-8182 (mobile)
www.yak-52.com
Skype - Yakguy1
Craig Payne
ENGINE_DAMPER_MOUNT_INSTALATION_Model.pdf
 Filename:  ENGINE_DAMPER_MOUNT_INSTALATION_Model.pdf
 Filesize:  29.25 KB
 Downloaded:  341 Time(s)
DAMPER_SECTION_A-A_Model_(1).pdf
 Filename:  DAMPER_SECTION_A-A_Model_(1).pdf
 Filesize:  22.8 KB
 Downloaded:  550 Time(s)
viperdoc(at)mindspring.co
PostPosted: Mon Apr 23, 2012 1:03 pm    Post subject: Torque values Reply with quote
That's what I did to mine. Nice pdf. file Dennis. Some work went into that! Maybe I missed it but where were the torque values. I'm looking for the torque values for the motor mounts on the ring and the fire wall. Right now I am using the Deutch values...goottentight.
Doc
PostPosted: Mon Apr 23, 2012 1:47 pm    Post subject: Torque values Reply with quote
There actually are no specific torque values. It is a compression
value. IE: the dimension of the mount rubber once compressed.
Dennis
A. Dennis Savarese
334-285-6263
www.yak-52.com
Skype - Yakguy1
Doc
PostPosted: Mon Apr 23, 2012 4:53 pm    Post subject: Torque values Reply with quote
Copy.. That is what I did. The T.O.'s did not give any guidance.
Doc
On Apr 23, 2012, at 4:45 PM, "A. Dennis Savarese" <dsavarese0812(at)bellsouth.net> wrote:
There actually are no specific torque values. It is a compression value. IE: the dimension of the mount rubber once compressed.
Dennis
A. Dennis Savarese
334-285-6263
www.yak-52.com
Skype - Yakguy1
> Doc
