cpayne(at)joimail.com Guest
Posted: Mon Apr 23, 2012 11:55 am Post subject: Torque values |
Installing an OH'd M-14P which came with new rubber cushions in the mount. Does anyone know if there is a published torque value? So far I tightened the nuts until the mounts were compressed some. Took about 50 in-lbs.
Craig Payne
Posted: Mon Apr 23, 2012 12:03 pm Post subject: Torque values |
Craig,
See attached. This should answer your question.
Dennis
A. Dennis Savarese
334-285-6263
334-546-8182 (mobile)
www.yak-52.com
Skype - Yakguy1
On 4/23/2012 2:51 PM, Cpayne wrote:
Craig Payne
 Download |
| Filename: |
ENGINE_DAMPER_MOUNT_INSTALATION_Model.pdf |
29.25 KB |
| Downloaded: |
278 Time(s) |
 Download |
| Filename: |
DAMPER_SECTION_A-A_Model_(1).pdf |
22.8 KB |
| Downloaded: |
494 Time(s) |
Posted: Mon Apr 23, 2012 1:03 pm Post subject: Torque values |
That's what I did to mine. Nice pdf. file Dennis. Some work went into that! Maybe I missed it but where were the torque values. I'm looking for the torque values for the motor mounts on the ring and the fire wall. Right now I am using the Deutch values...goottentight.
Doc
Posted: Mon Apr 23, 2012 1:47 pm Post subject: Torque values |
There actually are no specific torque values. It is a compression
value. IE: the dimension of the mount rubber once compressed.
Dennis
A. Dennis Savarese
334-285-6263
www.yak-52.com
Skype - Yakguy1
Doc
Posted: Mon Apr 23, 2012 4:53 pm Post subject: Torque values |
Copy.. That is what I did. The T.O.'s did not give any guidance.
Doc
On Apr 23, 2012, at 4:45 PM, "A. Dennis Savarese" <dsavarese0812(at)bellsouth.net> wrote:
There actually are no specific torque values. It is a compression value. IE: the dimension of the mount rubber once compressed.
Dennis
A. Dennis Savarese
334-285-6263
www.yak-52.com
Skype - Yakguy1
> Doc
