engine mount torque values
samira.h(at)shaw.ca
PostPosted: Tue Apr 24, 2012 12:19 am    Post subject: engine mount torque values Reply with quote
FWIK the engine mounts are not tightened
by torque but rather by measurement, please
see attached picture.
BTW Viperdoc, in the past I have sent you
several times documents regarding some
of your questions on the list but all my emails
bounced, guess you have blocked me - tough luck Smile
cheers
Elmar
 Filesize:  416.54 KB
 Viewed:  2553 Time(s)
samira.h(at)shaw.ca
PostPosted: Tue Apr 24, 2012 12:44 am    Post subject: engine mount torque values Reply with quote
In the unlikely event the attached
png file doesn't work, here comes
an alternative (low-res pdf).
cheers
Elmar
EngineMounts.pdf
 Filename:  EngineMounts.pdf
 Filesize:  340.31 KB
 Downloaded:  368 Time(s)
viperdoc(at)mindspring.co
PostPosted: Tue Apr 24, 2012 4:26 am    Post subject: engine mount torque values Reply with quote
Elmar,
Thank you...will over ride the com nazis to let you through the firewall.
Doc
PostPosted: Tue Apr 24, 2012 9:46 am    Post subject: engine mount torque values Reply with quote
