Removing contacts from a King radio connector
PostPosted: Sun Apr 22, 2012 7:27 pm    Post subject: Removing contacts from a King radio connector Reply with quote
At 05:35 PM 4/21/2012, you wrote:
Peter
The working blade is 10mm long, 1.5mm wide and 0.65mm thick on a "handle"
5mm wide and 67mm long, same thickness
Best Regards
Peter
I've made similar tools from a pocket screwdriver
using a grinder. Adjust dimensions to your specifics.
( -Thomas Paine 1776- )
PostPosted: Mon Apr 23, 2012 6:09 am    Post subject: Removing contacts from a King radio connector Reply with quote
Peter
Best Regards
Peter
See:
http://aeroelectric.com/Pictures/Tools/Extraction_Tools/extraction_tool.jpg
email(at)jaredyates.com
PostPosted: Mon Apr 23, 2012 9:05 am    Post subject: Removing contacts from a King radio connector Reply with quote
Street sweeper bristles are also good tool blanks. They are made from a soft steel that is easy to grind, and in most municipalities they are available for free.
On Apr 23, 2012, at 10:08, "Robert L. Nuckolls, III" <nuckolls.bob(at)aeroelectric.com> wrote:
> Peter
> Best Regards
> Peter
See:
berkut13(at)berkut13.com
PostPosted: Mon Apr 23, 2012 9:21 am    Post subject: Removing contacts from a King radio connector Reply with quote
Here's a really simple, cheap and amazingly effective, homemade Molex KK pin extractor:
http://www.berkut13.com/extractor.htm
Enjoy.
-James
Berkut/Race 13
www.berkut13.com
peter(at)sportingaero.com
PostPosted: Mon Apr 23, 2012 1:36 pm    Post subject: Removing contacts from a King radio connector Reply with quote
Many thanks to all who replied, I modified an small screwdriver on the belt sander which works admirably.
Peter
On 23/04/2012 18:16, berkut13(at)berkut13.com (berkut13(at)berkut13.com) wrote: [quote] Here's a really simple, cheap and amazingly effective, homemade Molex KK pin extractor:
Enjoy.
-James
Berkut/Race 13
www.berkut13.com
skywagon
PostPosted: Mon Apr 23, 2012 4:49 pm    Post subject: Removing contacts from a King radio connector Reply with quote
James,
..great tips. Thanks for the details.
ceengland(at)bellsouth.ne
PostPosted: Mon Apr 23, 2012 5:09 pm    Post subject: Removing contacts from a King radio connector Reply with quote
Now all you have to do is find a way to make them stay in the shell when you insert the radio....
Smile
On 04/23/2012 07:47 PM, David Lloyd wrote: [quote] James,
mrspudandcompany(at)veriz
PostPosted: Tue Apr 24, 2012 3:41 am    Post subject: Removing contacts from a King radio connector Reply with quote
If the pins are not staying in the shell when reinserted, it
may be due to the fact that the locking tab is not engaging the shell. When
you use the tool to remove the pin, you are deforming the locking tab into
the pin and it won't grab the shell. After pin removal it is essential to
pry the tab out, gently, only enough so it will lock in place when reused.
Roger
winmail.dat
 Filename:  winmail.dat
 Filesize:  4.55 KB
 Downloaded:  385 Time(s)
