Measurements Needed - Throttle/Prop/Mixture (Vernier)
philperry9
PostPosted: Tue Apr 17, 2012 7:15 am    Post subject: Measurements Needed - Throttle/Prop/Mixture (Vernier) Reply with quote
Hi Everyone,
I'm having some custom length vernier cables manufactured by McFarlane and need some basic measurements from Vans stock cables before I can proceed.
Does anyone have a set of cables that are not installed and who can make some measurements for me?  I had no idea it was this complex of a process.
Attached to this message is the McFarlane spec sheet for their cables.
Once I get the basic measurements from a stock set of cables, I can figure out the rest.  I'll be happy to share all the dimensions for the future builders so they don't have to go through the process.
Thanks in advance for your help!
Phil
Cable_Measurements.pdf
 Filename:  Cable_Measurements.pdf
 Filesize:  240.12 KB
 Downloaded:  411 Time(s)
Bob Turner
PostPosted: Tue Apr 17, 2012 11:37 am    Post subject: Re: Measurements Needed - Throttle/Prop/Mixture (Vernier) Reply with quote
One caution: I bought the stock cables with the Firewall Forward kit, and they were not long enough to route as shown in the plans. I made them fit, but it is a little tighter than I would have liked. And I think I'm not the only one who has had this problem.
Bob Turner
RV-10 QB
philperry9
PostPosted: Tue Apr 17, 2012 11:49 am    Post subject: Measurements Needed - Throttle/Prop/Mixture (Vernier) Reply with quote
That's exactly the reason I'm getting custom length cables made.
On Tue, Apr 17, 2012 at 2:37 PM, Bob Turner <bobturner(at)alum.rpi.edu (bobturner(at)alum.rpi.edu)> wrote:
[quote]--> RV10-List message posted by: "Bob Turner" <bobturner(at)alum.rpi.edu (bobturner(at)alum.rpi.edu)>
Bob Turner
RV-10 QB
http://forums.matronics.com/viewtopic.php?p=371091#371091
le, List Admin.
john.maccallum(at)bigpond
PostPosted: Tue Apr 17, 2012 11:24 pm    Post subject: Measurements Needed - Throttle/Prop/Mixture (Vernier) Reply with quote
Hi Phil,
I will measure mine for you tonight. I think that I am going to have the same problem as I have the Aerosport Products Carbon Fibre Panel
and the Cables sit a little lower and a little further rearwards than the stock support bracket.
Cheers
John MacCallum
#41016
VH-DUU
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Phillip Perry
Sent: Wednesday, 18 April 2012 1:14 AM
Subject: Measurements Needed - Throttle/Prop/Mixture (Vernier)
Hi Everyone,
Phil
sean(at)stephensville.com
PostPosted: Wed Apr 18, 2012 4:46 am    Post subject: Measurements Needed - Throttle/Prop/Mixture (Vernier) Reply with quote
John, check out the third to last post in this thread from Ivan. Phil,
there may be some info in there for you also.
http://forums.matronics.com/viewtopic.php?p=321568
-Sean #40303 (fitting doors)
On 4/18/12 2:23 AM, John MacCallum wrote:
Hi Phil,
Cheers
John MacCallum
#41016
VH-DUU
[mailto:owner-rv10-list-server(at)matronics.com] *On Behalf Of *Phillip Perry
*Sent:* Wednesday, 18 April 2012 1:14 AM
*To:* rv10-list(at)matronics.com
*Subject:* Measurements Needed - Throttle/Prop/Mixture
(Vernier)
Hi Everyone,
proceed.
process.
Phil
philperry9
PostPosted: Wed Apr 18, 2012 6:38 am    Post subject: Measurements Needed - Throttle/Prop/Mixture (Vernier) Reply with quote
Thanks John...
Sean, I've seen that post and I'm using those lengths for my final lengths, but there are a few more measurements that McFarlane is looking for and I can't get them without having my hands on a set of controls to measure.
Phil
On Wed, Apr 18, 2012 at 7:45 AM, Sean Stephens <sean(at)stephensville.com (sean(at)stephensville.com)> wrote:
[quote] --> RV10-List message posted by: Sean Stephens <sean(at)stephensville.com (sean(at)stephensville.com)>
John, check out the third to last post in this thread from Ivan.  Phil, there may be some info in there for you also.
maca2790
PostPosted: Wed Apr 18, 2012 4:23 pm    Post subject: Re: Measurements Needed - Throttle/Prop/Mixture (Vernier) Reply with quote
Thanks Sean and thank you Ivan. I think I will have to go with the 3 "
extension to all the cables. I'm not sure if Vans will take the others back
after 2 years Smile.
Phil I measured my cables but they don,t have the firewall wear sleeves or
the Clamp reduced diameter Dimension E.
Throttle is 47.5 " Extended Dimension B + C Dim D is 6" (retracted)
Prop 72.5" B + C Extended Dim D is 6 " (retracted)
Mixture 51.5 B + C and D is 6" (retracted)
cheers
John MacCallum
VH-DUU
#41016
philperry9
PostPosted: Thu Apr 19, 2012 8:05 am    Post subject: Measurements Needed - Throttle/Prop/Mixture (Vernier) Reply with quote
Very Helpful - Thank you!
I'm guessing there wasn't a protective sleeve for the firewall penetration on the factory cables?
Phil
On Wed, Apr 18, 2012 at 7:23 PM, maca2790 <vk2gcn(at)cirruscomms.com.au (vk2gcn(at)cirruscomms.com.au)> wrote:
[quote]--> RV10-List message posted by: "maca2790" <vk2gcn(at)cirruscomms.com.au (vk2gcn(at)cirruscomms.com.au)>
cheers
John MacCallum
VH-DUU
#41016
http://forums.matronics.com/viewtopic.php?p=371226#371226
le, List Admin.
larkrv10(at)gmail.com
PostPosted: Thu Apr 19, 2012 6:59 pm    Post subject: Measurements Needed - Throttle/Prop/Mixture (Vernier) Reply with quote
Guys, I've just started on the firewall construction.  Do any of the aftermarket (non Vans type) cables require different sized holes through the firewall recess (F-1001K)?
Thx,  Rick
#40956
Southampton, Ont
On Thu, Apr 19, 2012 at 12:03 PM, Phillip Perry <philperry9(at)gmail.com (philperry9(at)gmail.com)> wrote:
[quote]Very Helpful - Thank you!
Phil
cheers
John MacCallum
VH-DUU
#41016
le, List Admin.
get="_blank">http://www.matronics.com/Navigator?RV10-List
maca2790
PostPosted: Fri Apr 20, 2012 1:07 am    Post subject: Re: Measurements Needed - Throttle/Prop/Mixture (Vernier) Reply with quote
G'day Rick
There are quite a few different options for cables and some do require
larger holes. My QB Fuselage already had the pilot holes drilled into the firewall for the cables so I'm going with the Vans plans for the holes.
I have sent the cables supplied with the FF back and I will be using the VANS type cables from Aircraft spruce but 3 inches longer than the original ones supplied from Vans.
If you have a look at the Aircraft Spruce web page you will get some idea of the different types available.
Phil, yes your right there were no firewall wear sleeves on Vans Cables.
What they say to do in the Plans is to put an SB500 inside a SB625 and then to fill it with heat proof RTV.
cheers
John MacCallum
#41016
VH-DUU
rleffler
PostPosted: Fri Apr 20, 2012 1:48 am    Post subject: Measurements Needed - Throttle/Prop/Mixture (Vernier) Reply with quote
Typically not. However there are a variety of devices available to protect the cables and to minimize co into the cabin that require different spacing if you choose to use them.
On Apr 19, 2012, at 10:57 PM, Rick Lark <larkrv10(at)gmail.com (larkrv10(at)gmail.com)> wrote:
[quote]Guys, I've just started on the firewall construction. Do any of the aftermarket (non Vans type) cables require different sized holes through the firewall recess (F-1001K)?
Thx, Rick
#40956
Southampton, Ont
Phil
cheers
John MacCallum
VH-DUU
#41016
le, List Admin.
Bob Leffler
N410BL - Phase I
http://mykitlog.com/rleffler
