Posted: Sun Apr 15, 2012 6:52 am Post subject: Open source product development for OBAM aircraft |
At 07:54 AM 4/15/2012, you wrote:
| Quote: | The days of writing machine code are over except for the simplest
tasks that somehow need specialized hand tweaking.
Agreed. A little 8-pin PIC watching a bus
voltage to flash a light . . . or a timer to wig-wag
the landing lights is just such a 'simple' task that
yields nicely to programming in assembler.
But as soon as you need to do any math beyond a
simple integer add/subtract the glow is off the
assembler rose.
If I were teaching a hands-on class in uC product
development, we'd certainly use assembler to explore
the various registers. But evolution into higher
order functionality is not well served by learning
to the assembler necessary to do floating point math
or deeply nested prioritizing of tasks.
Not exploiting advantages of higher order language
compilers is like running a roofing company without
nailguns. If your roofers or programmers are getting
a good wage and have a deadline to meet, efficient use
of manpower and time is the name of the game.
gregmchugh
Posted: Sun Apr 15, 2012 3:17 pm Post subject: Re: Open source product development for OBAM aircraft |
Bob and all,
I had a little more time to play with the PICkit 1 Flash Starter Kit since my
last update on the project.
In our last episode, I had loaded the Hex file that come with Lesson 1
onto the board and it seemed to function fine (you push a button and an
LED changes state).
Next, I checked that I could reassemble and load from the code
that came with Lesson 1 (switch debouncing). Worked fine with the latest
MPLAB IDE that I downloaded from Microchip. Hex file seems to function
the same but it is different than the hex file that come with the kit. Not
unusual for this to happen (assembled years later with a newer version
of the toolchain). Something I may take some time to look at but
since I am planning to use the C version not something critical to do.
I next compiled the C code that came with the lesson and it had one
error (due to a missing define to allow the use of legacy header files)
and two warnings (the count for the timer was defined as 20. instead
of 20, not sure why, giving a warning about float to integer conversion). A
Google search solved the first one and the second one was readily found
by looking at the warning message. The legacy header define is
needed to allow older code to be compiled under the current
toolchain. I would guess that no one got the job of updated the C
code that comes with the Starter Kit to reflect changes in the standard
header files.
Downloaded the hex file produced that had been produced from
the C code and it seems to function as expected. All in all, about
what I would be expecting at this point. Getting to this point would be
pretty easy for anyone familiar with embedded software development but
a novice might have gotten stuck along the way. The MPLAB IDE is
feature filled which is good for experienced users but can be daunting
for a novice. Next I will do any porting required to move over from the
PIC12F675 to the PIC12F683. Time to take a look at the datasheets for
the chips and find any significant differences.
I have only the MPLAB simulator to investigate how the code executes
and I will next spend some time learning how that works. Seems pretty
straightforward but I have only stepped through the code. Need to
see how to set up the external stimulus inputs into the simulator.
Again seems to me like something that is pretty familiar but I am not
sure how a novice would look at it.
I decided to go ahead and order the low-end debugger (PICkit 3 Debug
Express plus an interface adapter and the PIC12F683 ICD Header) from
Microchip. That should be coming tomorrow and I will have access to
debugging in the chip. So, for those keeping score the Flash Starter Kit
is $36, the Debug Express is $70, the interface adapter is $10, and the
ICD header for a specific chip is $25. I would call this reasonable cost
to get what you get but a novice might say it was too much to get started.
You could get by with just the Starter Kit but I like having a view into
the chip as the code is running. You could skip the Flash Starter
Kit and go with the just the Debug Express but the Starter Kit does
have all of the hardware to support the tutorials and some
prototyping area to play around with. The PICAXE and Arduino folks
get around the debug issue by keeping the serial interface open to the
development PC, allowing debug messages to be displayed. Works
fine for most simple applications but it would tie up two pins on
our 8 pin device.
That is enough for now, I am still planning to write up a short summary
of all of this for anyone who wants to give it a try. Only a few small
gotcha's up to this point...
Greg McHugh
Posted: Tue Apr 17, 2012 9:18 am Post subject: Open source product development for OBAM aircraft |
The ECB layout is done. I'll put it down for a few
hours and then 'proof' it against the schematic.
I'll publish the ECB layout and schematic as soon
as I've confirmed their agreement.
Posted: Tue Apr 17, 2012 9:03 pm Post subject: Open source product development for OBAM aircraft |
At 10:03 PM 4/17/2012, you wrote:
<retasker(at)optonline.net>
I don't know what you use for board layout, but if you use something
like Eagle from http://www.cadsoftusa.com/ the layout connections
will always agree with the schematic since they are linked.
I use ExpressPCB which does have a schematic capture
feature. Never did like the looks of their schematics.
I grew up with ARRL publications. the look, feel and
smell of their publications symbols became part of my
DNA.
Also cut my teeth on ECB layouts with little reels of
black, red and blue tape and donuts. All the time
I was putting parts on the board, I was working out
the mechanics of heat sinking, current density,
vibration resistance, ergonomics of the wiring,
etc.
Auto-routers don't mesh well with that train of thought.
So I still enjoy doing the layout "by mouse" with
design goals aforethought. Going thought the schematic
one trace and component at a time is when I cull
the schematic for bugs. At HBC, we had guys to do
layouts for us but they didn't know much, if anything,
about the mechanics of the end-product. But it did made sense
for big, complex boards. I'm more comfortable somewhere
between tape-n-dots and full up schematic capture
with autorouting.
