Posted: Mon Apr 09, 2012 10:25 am Post subject: Open source product development for OBAM aircraft |
At 11:21 AM 4/9/2012, you wrote:
I probably should have changed the Subject line on this but I decided
to leave it alone to continue
the thread we had started. It is getting away from the LED wig-wag topic...
Okay, how about 'open source product development for OBAM aircraft"
I have thought about this a little and I think it would be worthwhile
to consider the option of a general purpose
programmable module and use the LED wig-wag as a simple example
application. I see three useful
characteristics for this module
1. Functionality set in software
2. Some capability to configure the I/O circuits for each application
3. A standard module package and connector such as the one you showed
using an enclosed case with d-sub connector
That was the idea behind the "do allot" ECB
and companion schematic. It's readily deduced
that no single product would use ALL the parts
in the schematic. But selective use of parts
and software offers a host of possibilities.
This particular board was bounded by the dimensions
of the case . . . but there are larger cases
that could be considered. But there's value in
maximizing the 'core' of a bill of materials
that varies only slightly from product to product
and this size seemed like a good starting place.
To be useful for a wide audience there needs to be simple learning
curve for developing the software
functionality and I/O configuration. I agree that the use of a PIC
micro would be the way to go based on
their ready availability, good price per performance, and
availability of development tools.
<snip>
My father-in-law has been doing my PIC software
on a PICkit 1. I think they're $36 from Digikey.
The source editor/compiler is free.
http://tinyurl.com/7dq97tv
<snip>
I don't know enough about hardware design to know if the use of these
types of boards or even just a prototyping board
from Radio Shack are robust enough to handle the environment of
mounting in an experimental aircraft but based on the
VX-Aviation module it would seem they may be up to the job...
these same considerations drove the do-lots board.
Everything needed to do a lot of tasks could be
completely contained in the 'standard enclosure'.
Anyway, this note is getting a little long so I will end it here. I
would appreciate feedback from anyone who is interested
in something along these lines in order to see if my thoughts on this
make any sense to anyone beside me. I am only
interested as an end user of the module and have no real interest in
designing / producing any type of hardware boards.
I can handle setting up the I/O circuits on a pre-made board but I
don't have much interest in board development even
though I know it is something that is not that hard to learn.
Not 'hard' but certainly time consuming. This
is where the open-source approach might allow
the community of interested users to contribute
in concert with their interests and available
time.
For my part, I can readily advise on schematics
and functionality that are 'aviation friendly'.
Been doing that for decades. I would proposed that
the development chain of any single device be
published, certainly here on the List and perhaps
archived on aeroelectric.com
I did the c-mos gate wig-wag as a practical exercise
with low risk for success. It's not been laid up
on a board but could be easily brass-boarded and
hardened for installation on an airplane. Doing
a PIC based flasher might be the short path to
success. The board and packaging is done. The aviation
friendly architecture is done.
So, tell you what. If you program this beastie,
I'll supply the parts. We can turn this into a practical
path to service your needs along with a teaching
moment for interested readers. I'll turn it into
an off-the-shelf product. I'll make cases and bare
board available to anyone who wants to do their own
version of a do-lots module. If they contribute their
own efforts to the open-source library, then depending
on interest-at-large . . . we can make that an
off the shelf product as well.
I'll look into the options for getting some
beefier fets in the box.
JLuckey(at)pacbell.net Guest
Posted: Mon Apr 09, 2012 1:15 pm Post subject: Open source product development for OBAM aircraft |
All
Regarding Selection of Micro-controller:
There should probably be some due diligence with respect to selection of
micro-controller and micro-controller families to be considered for a
Do-Lots (generic controller w/ hardened interfaces to the real world)
device.
I've used PIC & ATMEL uControllers and I have opinions about both (which I'm
happy to share if people are interested). I'm hoping others on this list do
too.
With some careful design, it may be possible to create a device that is
uController/Manufacturer agnostic.
Food for thought...
-Jeff Luckey
gregmchugh
Posted: Mon Apr 09, 2012 2:38 pm Post subject: Re: Open source product development for OBAM aircraft |
Sounds like a reasonable approach to me. Using these PIC chips gives a lot
of options for software development. The kit you mention is $36 direct
from Microchip. I just ordered one and will come up with the code for
the wig-wag example using the kit. We just need to decide on which
chip provides the right capabilities for the expected applications. I
expect the option exists to allow several of the PIC chips to drop into
the same board layout since the added pins simply increase the
number of I/O ports.
I believe the PICAXE chips are drop in replacements for the standard PIC
chips supported by the kit you referenced without the need for the
development kit. They can be programmed using the PICAXE kits which
are readily available for $30 to $50 with the major cost being a USB
programming cable. If you have a serial port available the cable is $6.
I expect the serial cable is easy to make yourself since it is simply a
connection to a 3.5mm stereo audio plug...
Development tools for BASIC on the PICAXE are free and there is also
an option to program the PICAXE directly from flowcharts using the
Logicator tool ($15 tool).
Enough options to satisfy most of the potential users...
Greg McHugh
gregmchugh
Posted: Mon Apr 09, 2012 3:45 pm Post subject: Re: Open source product development for OBAM aircraft |
One question I forgot to ask in the previous note. When I looked at
using the Perihelion Wig-Wag for my LED landing lights I was
surprised at the compact size and the capability to switch the loads
on standard landing lights. Is there something unique about this
design to handle the 250 watt load?
Greg McHugh
Posted: Fri Apr 13, 2012 9:34 am Post subject: Open source product development for OBAM aircraft |
I will 3rd that. C is the way to go. It takes some effort to move from
BASIC but it is worth it. Get the de facto C bible: "The C Programming
Language" by Kernighan & Ritchie.
I would also like to suggest that people look at the AVR line of
uControllers from Atmel.
I started many years ago on Parallax & pretty quickly needed more
performance. Then I latched onto PIC because they are very popular in
industry & I had some acquaintances who were professional electronic types,
and they were using them.
The thing I did not like about PIC was that you needed different programming
hardware, software, techniques for different families of their uCons. I
like to use the little 8-16 pin devices & they were difficult to get
programmed in C. On the very small PICs, they recommend you program them in
assembler. (this may have changed by now)
So I began exploring AVR
http://www.atmel.com/products/microcontrollers/avr/default.aspx
and now primarily use them.
I like:
1. One programming environment for their entire family
2. Their Tiny(tm) chips are programmed in C
3. All ATMEL development tools are free & pretty good
4. Very good programmer/debuggers are available for around $100.
Aside from those differences, the product lines among uController
manufacturers are surprisingly similar. So my logic at the time was, as a
newbie, I did not want to go spend a couple of hundred dollars on
programming tools (both software & hardware) only to find out later that the
tools did not support the chip I had chosen or that I needed another
emulator, etc.
It seemed that Atmel made that decision much safer because the software
tools are free.
gregmchugh
Posted: Fri Apr 13, 2012 10:49 am Post subject: Re: Open source product development for OBAM aircraft |
Jeff,
On the PIC vs AVR question I am also getting the feeling that PIC
may not be the best long-term choice. Bob has some PIC's in
stock and has a board designed so I have no issue with supporting
a software application for the wig-wag on that module. As I noted
before I have no real experience with PIC, or with AVR for that
matter, but I do see that PIC development tools are not universal.
When I looked at adding a PICkit 3 Debug Express (their $45 low
end debugging tool) to get real time debugging I found that I
would have to also add an interface board ($9) then a debug board for
each of the chips that do not have onboard debug support. The
interface board essentially has a version of the chip in a larger
DIP package to include the debugging support. Each of these
goes for $25. So, as you change processors in the PIC line you
are looking at additional cost for development tools. If Atmel
works around this with universal tools then I think that is a
significant plus in their favor.
Not sure if the consistency between the general AVR chips and
Arduino plays into this. Similar to PIC and PICAxe but not
quite the same since Arduino runs compiled C code. Can a
generic AVR chip be made Arduino compatible with
the download of the Arduino Loader onto the chip?
Greg McHugh
Posted: Fri Apr 13, 2012 11:35 am Post subject: Open source product development for OBAM aircraft |
Greg,
I haven't had the time to play w/ Arduinos (but I know many people who
have). I believe that Arduinos are AVR chips just like PICAXE are PICs and
accomplish the same mission (i.e. making the chip more user-friendly) but I
think they suffer a performance hit, also.
I'm not familiar enough w/ Arduino to answer your question.
-Jeff
enginerdy(at)gmail.com Guest
Posted: Fri Apr 13, 2012 12:47 pm Post subject: Open source product development for OBAM aircraft |
Yes, check out this fairly minimal implementation here:
http://arduino.cc/en/uploads/Main/Arduino-Pro-schematic.pdf
U2 is the 3.3v or 5v regulator, depending on the board variant, and the odd-looking 0.1uF cap (C2) coupled to DTR allows the serial dongle to reset the chip. This makes programming the Arduino simpler with many of the USB<->serial TTL converters out there. (the chip must be reset to enter the bootloader, and if it times out before programming begins, it will not work. This allows the Arduino IDE to enter the bootloader/programming mode without requiring the user to press reset)
Additionally, following the 'FTDI Basic' header convention at JP5 gives you several options for plug-and-play arduino programmers. (Make sure you pick the right one, either 3.3v or 5v!)
And don't forget the ISP port JP3 so you can load the Arduino bootloader, or alternately load programs with AVR Studio and an AVR ISP device, without taking the chip out of the board.
Overall, making an Arduino clone should be pretty straightforward.
--Daniel
On Apr 13, 2012, at 1:49 PM, gregmchugh wrote:
| Quote: | Can a
Greg McHugh
rose9065f
Posted: Tue Apr 17, 2012 6:33 pm Post subject: Open source product development for OBAM aircraft |
BASIC, COBOL, assembler, C++++, reminds me of a heated debate many years ago regarding the merits of octal vs hex. Of course all these things are tools, and you use the tool that is most appropriate for the job at hand. But if your only tool is hammer then everything looks like a nail.
Another famous debate was on the use of the GOTO statement. Everybody knows that the GOTO is very bad. I am proud to say that I once assisted in the development of a system that completely eliminated the GOTO. It was based on the COMEFROM statement and also the FISH stack. COMEFROM has fallen out of favor recently, but the FISH stack is still widely used: first in, still here. The system was implemented as a SNOBOL preprocessor for a structured JOVIAL compiler. Sadly it never caught on.
My native language is FORTRAN, which is very useful because you can write FORTRAN in any language. Nostalgia aint what it used to be.
Jim
PS The most useful assembler statement is XPI, execute programmer immediate
_________________ KF2 582 |
henador_titzoff(at)yahoo. Guest
Posted: Tue Apr 17, 2012 7:03 pm Post subject: Open source product development for OBAM aircraft |
Interesting. The octal vs. hex debate didn't last long, did it? The reason these two were invented was to get away from too many 1s and 0s, i.e. binary. There are only 10 types of people in this world - those who understand binary and those who don't.
Henador Titzoff
Sent: Tuesday, April 17, 2012 10:32 PM
Subject: Re: Open source product development for OBAM aircraft
Jim
PS The most useful assembler statement is XPI, execute programmer immediate.
[quote]-===================================
ainut(at)knology.net Guest
Posted: Wed Apr 18, 2012 2:28 am Post subject: Open source product development for OBAM aircraft |
Would that XPI be most effective when in indexed, indexed direct, or indexed
indirect mode? My favorite instruction was NOP... Octal didn't have a chance.
PDP-8's didn't live long and besides, octal could only represent itself half as
well as hex. 2, 3, 4, (drum rap)
Nibbles, now there was some compact power.
Today, one gets arrested for twiddling their bits in public... Does that
register? Ah, the highs and lows of assembly... For one thing, we never knew
whether we were on the leading edge or the trailing edge... Only Nyqist and our
hairdressers know for sure.
David
On Tue 04/17/12 10:02 PM , Henador Titzoff henador_titzoff(at)yahoo.com sent:
| Quote: | Interesting. The octal vs. hex debate didn't last long, did it? The
Henador Titzoff
TO: aeroelectric-list(at)matronics.com
SENT: Tuesday, April 17, 2012 10:32 PM
SUBJECT: Re: Open source product development for
OBAM aircraft
looks like a nail.
Jim
immediate.
Links:
[1]
http://webmail2.knology.net/HTTP://WWW.MATRONICS.COM/NAVIGATOR?AEROELECTRIC
-LIST[2] http://webmail2.knology.net/HTTP://FORUMS.MATRONICS.COM
[3] http://webmail2.knology.net/HTTP://WWW.MATRONICS.COM/CONTRIBUTION
steve(at)tomasara.com Guest
Posted: Wed Apr 18, 2012 6:10 am Post subject: Open source product development for OBAM aircraft |
All,
Regarding the discussions of what "real programmers" use etc. it was
once explained to me that there are only two kinds of programming
languages and those are ones that "everyone" bitches about and argues
against and those that "nobody" uses.
Steve Stearns
Boulder/Longmont, Colorado
CSA,EAA,IAC,AOPA,PE,ARRL,BARC (but ignorant none-the-less)
Restoring (since 1/07) and flying again (8/11!): N45FC O235 Longeze
Cothern/Friling CF1 (~1000 Hrs)
Flying (since 9/86): N43732 A65 Taylorcraft BC12D
