Posted: Mon May 29, 2006 2:55 pm Post subject: Stall Vane |
I’m assembling the stall vane assembly, and the instructions say not to torque so much that the vane can’t rotate freely. In order for my vane to rotate freely, the screw/nut that holds it in place also rotates freely. Yes, the screw is engaged in the self-locking plastic of the nut, so I consider the nut locked. However, if I tighten the nut just enough that the screw won’t rotate, the vane won’t either. So, I can’t even tighten the nut snugly, much less to any torque value. I figure if I leave it the way it is it’ll allow the screw to spin and eventually wear something through, most likely the aluminum mount plate. Any tips?
Rob Wright
#392 Wings QB
n8vim(at)arrl.net Guest
Posted: Mon May 29, 2006 3:18 pm Post subject: Stall Vane |
Just file the ends (the ends of the tube the vane is welded to) of the
vane itself a bit so you can tighten the screw so it doesn't turn. Or
just use some loctite on the screw head.
-Jim 40384 (Slow build all the way)
Robert G. Wright wrote:
| Quote: | I’m assembling the stall vane assembly, and the instructions say not
Rob Wright
#392 Wings QB
ichelva(at)netspace.net.a Guest
Posted: Mon May 29, 2006 4:26 pm Post subject: Stall Vane |
Try grinding the VA-196 down a little, so that it rotates freely when the nut is torqued
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Robert G. Wright
Sent: Tuesday, 30 May 2006 6:54 AM
Subject: Stall Vane
Rob Wright
#392 Wings QB
Posted: Mon May 29, 2006 4:35 pm Post subject: Stall Vane |
Thanks James and Indran, Duh! There I go, pole-vaulting over mouse turds again…
Rob Wright
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Indran Chelvanayagam
Sent: Monday, May 29, 2006 7:25 PM
Subject: RE: Stall Vane
Subject: Stall Vane
Rob Wright
#392 Wings QB
