Relay failure modes
gilles.thesee(at)free.fr
PostPosted: Sun Jan 08, 2017 2:05 am    Post subject: Relay failure modes Reply with quote
Hi all,
Is there such a thing as a typical, or most likely relay failure mode ?
For instance "failure to operate when the coil is energized",
"uncommanded contact opening", etc. ? We are speaking of "ordinary" relays.
Let's say we have a load permanently connected to the normally closed
contacts, and the relay is occasionally energized to open the circuit.
Is failure likeliness on the same order as that of the contacts of a
switch, for instance ? Or does such a relay significantly impair the
circuit reliability vs an ordinary switch ?
Thanks in advance for any facts or opinions,
Best regards,
Gilles
http://contrails.free.fr
http://lapierre.skunkworks.free.fr
cbirdsall6(at)cox.net
PostPosted: Sun Jan 08, 2017 5:26 am    Post subject: Relay failure modes Reply with quote
My experience:
Most common relay failure mode by far is failure to "set" - whether by mechanical or electrical failure inside the relay, the contacts fail to open or close as designed when current is applied to the coil. Often begins manifesting itself as intermittent operation (sometimes works, sometimes not).
Second to that is not an actual relay failure, but a failure in the installation. The result is the same (failure of the relay to actuate), but the cause is usually a wiring or mechanical fault introduced by the person that installed it. Bad soldering, incorrectly terminated wires, insufficient ground, not securing plug-in type relays, etc. Also often begins with intermittent operation.
Third and low in percentage of failures would be failure of the relay to "reset" after the coil current was removed (stuck "on").
Can't say as I've ever seen a relay actuate without input to the coil. Whenever I've run across a relay that's actuating when it's not supposed to be, it's always been a fault in the controlling circuit. I suppose it's possible under high g or heavy vibration to mechanically move the contacts.
Chuck
On Jan 8, 2017, at 4:03 AM, GTH <gilles.thesee(at)free.fr> wrote:
Hi all,
For instance "failure to operate when the coil is energized", "uncommanded contact opening", etc. ? We are speaking of "ordinary" relays.
Let's say we have a load permanently connected to the normally closed contacts, and the relay is occasionally energized to open the circuit. Is failure likeliness on the same order as that of the contacts of a switch, for instance ? Or does such a relay significantly impair the circuit reliability vs an ordinary switch ?
Best regards,
Gilles
PostPosted: Sun Jan 08, 2017 7:16 am    Post subject: Re: Relay failure modes Reply with quote
It takes a lot more magnetic force to pull a relay armature in than it does to hold it in the pulled position. In fact, just residual magnetism in the coil core could be enough to hold the armature pulled in, even after the coil has been de-energized. To prevent that, a thin layer of non-magnetic material is bonded to the armature. If that thin layer wears away or falls out, the relay could remain in the pulled-in position after the coil has been de-energized.
At work many years ago, a machine operator complained that a 5 HP, 3 phase, 480 volt motor started up all by itself after he had previously shut it off. Another electrician verified the operators observation, but could not find the problem. He asked me to help. It turns out that the motor did not actually stop running. But it appeared that it did because the run-indicator light went out when the operator pressed the stop button. I measured the coil voltage of the 3 phase contactor and it was zero. So the contactor never pulled in all by itself for no reason, it just never dropped out. Replacing the contactor fixed the problem. Examining the contactor back in the shop, it repeatedly stuck closed when manually pulled in. I do not know if was residual magnetism or atmospheric pressure (like a suction cup) that held the large area mating surfaces together. The mating surfaces were slightly oily. This was a highly unusual failure. I only saw it happen that one time.
So yes, it is possible for relays to get stuck in the closed position. But it is not very common. If I wanted to use relays in my airplane, I would not let fear of relay failure deter me. A relay is less likely to fail than the fuel system is. If the relay controls a critical circuit, then have a backup plan.
Joe Gores
MMiller
PostPosted: Sun Jan 08, 2017 7:26 am    Post subject: Re: Relay failure modes Reply with quote
Gilles,
Often the failure of a relay can be traced to a design choice. On a single pole relay the most common failure modes (in no special order);
Open coil (won't pick)
Shorted coil (blows fuses)
Welded contact (fails to break)
Contact fails to make (dirt)
Mechanical binding
Relays are generally used to drive loads greater than the rating of the switch piloting the relay or when multiple signals (poles) are needed. Comparing equally rated switches and relays, one disadvantage of a relay is that it adds one more step to the process, a power failure in the coil circuit and it won't pick. Other than that, It doesn't matter if you use a switch or a relay, it's more important that the device you choose meets the requirements of the circuit. A properly selected relay or switch will likely last then life of the design, trouble free.
When choosing a contact, bigger isn't better. As an extreme example, don't use a contactor in a telecom circuit. Also, not all loads are equal, when driving an inductive load, manage the kickback and de-rate, when driving lamps, the cold filament can be 10 times rated lamp current.
PostPosted: Sun Jan 08, 2017 8:01 am    Post subject: Re: Relay failure modes Reply with quote
Vern Little has lots of relays in his plane. Below is a link to his electrical schematic.
http://www.vx-aviation.com/sprocket/photos/panel_elec/schematics/Rocket_electrical-C1.sch
Joe Gores
Peter(at)sportingaero.com
PostPosted: Sun Jan 08, 2017 3:23 pm    Post subject: Relay failure modes Reply with quote
What is an sch file? What app can open these?
Peter
wgreenley
PostPosted: Sun Jan 08, 2017 3:34 pm    Post subject: Relay failure modes Reply with quote
Can open with ExpressSCH, free at expresspcb.com
On Sun, Jan 8, 2017 at 6:20 PM, Peter Pengilly <Peter(at)sportingaero.com (Peter(at)sportingaero.com)> wrote:
[quote]--> AeroElectric-List message posted by: "Peter Pengilly" <Peter(at)sportingaero.com (Peter(at)sportingaero.com)>
Peter
larkrv10(at)gmail.com
PostPosted: Sun Jan 08, 2017 3:40 pm    Post subject: Relay failure modes Reply with quote
Peter the software comes from Express PCB, https://www.expresspcb.com/
I've used it to do all my elementary drawings.
Rick
#40956
Southampton, ont
[url=https://www.google.ca/?gws_rd=ssl#][/url]
Peter
PostPosted: Sun Jan 08, 2017 3:42 pm    Post subject: Re: Relay failure modes Reply with quote
The Express.sch program is similar to Excel in that there can be more than one tab. After opening Vern Little's schematic, click on the various tabs at the bottom of the page.
Joe Gores
n233ee(at)gmail.com
PostPosted: Sun Jan 08, 2017 4:43 pm    Post subject: Relay failure modes Reply with quote
Has anyone used this on an iPad?
On Jan 8, 2017 5:49 PM, "user9253" <fransew(at)gmail.com (fransew(at)gmail.com)> wrote:
Joe Gores
http://forums.matronics.com/viewtopic.php?p=464882#464882
PostPosted: Sun Jan 08, 2017 7:57 pm    Post subject: Relay failure modes Reply with quote
At 04:03 AM 1/8/2017, you wrote:
--> AeroElectric-List message posted by: GTH <gilles.thesee(at)free.fr>
Hi all,
Relay failures are rare . . . as are switch
failures. Relays are simply remotely operated
switches having manual actuators replaced with
electro-magnetic actuators.
If one does measurement/analysis of contact performance
and the effects of environmental stress for
manual switches vs. electro-mechanical relays,
they are virtually identical. Contacts are
made from the same materials. They 'bounce'
on closure. Contact erosion and tendency to
'stick' as a byproduct of metal-transfer in
the electric arc are the same.
The only failures I had occasion to study
on TC aircraft had foundation in poor
application of the relay to intended task.
I worked one relay failure program on a bizjet
that took several years of sand-sifting to
identify root cause. The relays were being
used in a very benign environment (pressurized
cabin) and well within their electrical . . .
but were known to 'stick'. Single sticks
would disable a trim system. Double sticks
would produce a trim runaway.
Yet, all the 'failed' relays showed minimal
wear and tear . . . and would test normally
in a production test fixture.
Relays are, as a class of product, no more
prone to failure than their remote cousins
on the panel. I have operated three vehicles
to a cumulative total of more than 400K miles.
All three machines have a dozen or more relays
scattered about various systems. I've experienced
a range of mechanical failures due to end of life
wear out . . . but haven't replaced a single
relay.
Relays, like switches, have design lifetimes
in the tens of thousands of operations at
rated loads. Few relays in light aircraft see
more than a few hundred cycles per year . . .
and none are stressed to their maximum rated
loads.
We've studied some contactor failures due
to manufacturing error . . . a few more due
to electrical abuse (starter contactors down
stream of a soggy battery). But for the most
part, kept a cap-checked and charge battery
installed and even that risk drops dramatically.
Others were subject to moisture ingress due
to location and poor choice of installation
orientation.
You are probably more likely to lose a relay's
functionality due to a bad crimp on a mating
terminal than from failure within the relay.
The vast majority of failures I've investigated
on heavier iron had simply reached the end of
their service life . . . they were worn out.
PostPosted: Mon Jan 09, 2017 8:44 am    Post subject: Relay failure modes Reply with quote
Bob and all who reponded,
Thanks a lot for the facts and detailed explanations.
I do know that simpler is better, that a part not installed cannot fail, etc.
But concerning the so peculiar Rotax 912iS engine, my partners decided - and I do agree - that preventing pilot's errors is of highest priority.
So we are studying the possibility of grouping some functions or sequences.
The idea behind my relay question was powering an appliance via a normally closed relay, and energize that relay (open the contacts) only for testing once or twice during ground runup.
Still more funny questions to come !
Thanks again,
Best regards,
Gilles
PostPosted: Mon Jan 09, 2017 12:33 pm    Post subject: Re: Relay failure modes Reply with quote
A momentary push button switch could energize a relay for testing with no chance of the pilot leaving the switch in the wrong position.
Joe Gores
PostPosted: Mon Jan 09, 2017 2:49 pm    Post subject: Relay failure modes Reply with quote
Joe,
Yes, that's the idea.
Best regards,
Gilles
reaper
PostPosted: Sun Feb 26, 2017 3:36 pm    Post subject: Re: Relay failure modes Reply with quote
orientation.
I'm installing my battery contactor (Cole Hersee) 'cap down'.
It seems extremely unlikely that G loading would 'open' the contactor,
but my question is what would be the system repercussions
should a battery contactor open while the alternator was
under normal system load?
Would the crowbar overvoltage protect the avionics?
PostPosted: Mon Feb 27, 2017 8:54 am    Post subject: Relay failure modes Reply with quote
That's fine.
Change 'unlikely' to 'impossible'
Not a thing. You probably won't know the
contactor is open until you turn on the
master during next pre-flight (depending
on sequencing of switches).
If the alternator were seriously unstable
sans battery . . . but this is unlikely.
If you have Klieg Lights on the wings or an
electro-hydraulic landing gear system, then
you may stall the system when those accessories
are activated . . . but unless you make some
LARGE changes in electrical system demands
before landing, you'll probably be unaware
of the loss of a battery contactor.
reaper
PostPosted: Mon Feb 27, 2017 9:36 am    Post subject: Re: Relay failure modes Reply with quote
Great
I'm using a 2-10 per Z-11P for Batt/Alt so I guess
I would notice on shutdown.
Thanks!
dave
