glipaz
Posted: Sun Mar 11, 2012 6:03 pm Post subject: CJ Trim Cable replacement |
Wondering if anyone has any words of wisdom (or, even better, some photos etc) that would help me install a new trim cable. Mine snapped over the weekend and unspooled off both wheels. Not sure if the tail spool is still intact but the lack of tension leads me to think it is not. I saw some talk about replacing with electric servos but, I prefer to use the cable system.
Gil Lipaz
310-245-7078
http://tigersquadron.com
yakjock(at)gmail.com Guest
Posted: Mon Mar 12, 2012 9:13 am Post subject: CJ Trim Cable replacement |
Gil,
On my earlier CJ my mechanic at the time replaced the trim wire using a fine, woven US wire after he twice tried using the Chinese wire. The woven wire was much easier to work with, and he was able to purchase a much longer length of the US wire making it much simpler to lead through and install on the trim wheels.
I have electric three-axis trim tabs on my current CJ. If I was doing it over I would keep the manual tim for the elevator and use electric for aileron and rudder.
Hal
Pete Fowler
Posted: Mon Mar 12, 2012 5:45 pm Post subject: Re: CJ Trim Cable replacement |
I know Hal recently did this on Ernie's (later James's) plane. He might be able to offer some advice.
jcolquit(at)law.ua.edu Guest
Posted: Tue Mar 13, 2012 6:12 am Post subject: CJ Trim Cable replacement |
Hal Morley wrote:
<![if !supportLists]>Ø <![endif]>Gil,
<![if !supportLists]>Ø <![endif]> On my earlier CJ my mechanic at the time replaced the trim wire using a fine, woven
<![if !supportLists]>Ø <![endif]> US wire after he twice tried using the Chinese wire. The woven wire was
<![if !supportLists]>Ø <![endif]> much easier to work with, and he was able to purchase a much longer length of
<![if !supportLists]>Ø <![endif]> the US wire making it much simpler to lead through and install on the trim wheels.
I have Hal’s “earlier CJ” with the trim wire in question. It still looks and works just fine. When I purchased the airplane though, the elevator trim neutral light did not work. I tried replacing the bulb. No luck. Then while troubleshooting the system, we noticed there was no slug /nub on the wire to activate the trip switch for the light. I installed a replacement slug and everything works fine now.
Joe Colquitt
TCL
wlannon(at)shaw.ca Guest
Posted: Wed Mar 14, 2012 8:19 am Post subject: CJ Trim Cable replacement |
Gil;
If you could send your email address I will send some info that may help in the trim cable replacement saga.
Walt
wlannon(at)shaw.ca (wlannon(at)shaw.ca)
Sent: Sunday, March 11, 2012 7:03 PM
Subject: CJ Trim Cable replacement
Gil Lipaz
310-245-7078
href="http://www.matronics.com/Navigator?Yak-List">http://www.matronics.com/Navigator?Yak-List
