Epistaxis
Joined: 19 Dec 2010 Posts: 13 Location: Nebraska, USA
Posted: Fri Mar 09, 2012 10:14 am Post subject: flex hose mandrels |
I would like to purchase a set of metric mandrels to assemble the flex hoses and reusable fittings on yak aircraft. Any help with this would be greatly appreciated.
czech6(at)mesanetworks.ne Guest
Posted: Fri Mar 09, 2012 1:03 pm Post subject: flex hose mandrels |
Has anyone installed a Dynon in their Yak and has anyone used the Dynon engine gauges?
I need to know if there are special sending units required. If so what and where might I find these.
Thanks.
dabear(at)devere.us Guest
Posted: Fri Mar 09, 2012 3:39 pm Post subject: flex hose mandrels |
I installed the Dynon in my CJ with the M14P. completely standard sending
units/sensors.
Bear
Posted: Fri Mar 09, 2012 5:07 pm Post subject: flex hose mandrels |
Clarify the statement "completely standard sending units/sensors". What did they change in the last three years since I looked at it. Are you using the YAK stock tach drive or using a P lead wire to sense RPM. Have they changed the program in the EMS to give %RPM? What adapters are you using to tie into the fuel and oil sending unit?
I'm asking because I'm preparing to hang my M-14PF tomorrow so I have a fairly blank slate to work with.
Doc
units/sensors.
Bear
Posted: Fri Mar 09, 2012 7:19 pm Post subject: flex hose mandrels |
Sorry, I'm talking about the Dynon standard sensors. I'm using p lead wire.
I'm using RPM not % . Im using the dynon oil temp/pressure sensors. You
can use the standard fuel tank sensors they just have to be calabrated with
the new system. I also am using 9 EGT and 5 CHT since the EGT will react to
a problem before the CHT.
That answer your questions?
Bear
Posted: Fri Mar 09, 2012 8:04 pm Post subject: flex hose mandrels |
Roger, Bear. Thank you for the update.
Doc
Bear
Posted: Fri Mar 09, 2012 9:26 pm Post subject: flex hose mandrels |
If you want to talk live, email me your phone number and I'll call.
Bear
barryhancock
Posted: Fri Mar 09, 2012 9:31 pm Post subject: Re: flex hose mandrels |
The Dynon EMS is working flawlessly in my CJ. I have the Sky View system (as does DaBear) and am very pleased with it. There is an adapter for the tach drive, or you can take it off the p-leads. The only parameter it does not monitor in my set up is air pressure.
We're a Dynon dealer and offer a discount to Red Star users.
Hope this helps.
Happy Flying,
Barry
_________________ Barry Hancock
Worldwide Warbirds, Inc.
www.worldwidewarbirds.com |
Posted: Sat Mar 10, 2012 5:08 am Post subject: flex hose mandrels |
Yes it does. I have a D10 (extra) that I may sell or tree in on a the EMS. I have the D10 in the 50 already.
Doc
On Mar 9, 2012, at 11:31 PM, "barryhancock" <bhancock(at)worldwidewarbirds.com> wrote:
Hope this helps.
Happy Flying,
Barry
Barry Hancock
(877) 869-6458
http://forums.matronics.com/viewtopic.php?p=368094#368094
brian(at)lloyd.com Guest
Posted: Sat Mar 10, 2012 8:21 am Post subject: flex hose mandrels |
And speaking of topic-slip, I am still trying to figure out how one gets directly from flex-hose mandrels to Dynon engine monitor sensors.
I think I will start a new thread so that others can follow.
Brian Lloyd, WB6RQN/J79BPL
3191 Western Dr.
Cameron Park, CA 95682
brian(at)lloyd.com (brian(at)lloyd.com)
+1.767.617.1365 (Dominica)
+1.916.877.5067 (USA)
KingCJ6(at)aol.com Guest
Posted: Sat Mar 10, 2012 8:29 am Post subject: flex hose mandrels |
Any way to work MMO into the new thread?
In a message dated 3/10/2012 8:21:38 A.M. Pacific Standard Time, brian(at)lloyd.com writes:
| Quote: | And speaking of topic-slip, I am still trying to figure out how one gets directly from flex-hose mandrels to Dynon engine monitor sensors.
3191 Western Dr.
cjpilot710(at)aol.com Guest
Posted: Sat Mar 10, 2012 8:31 am Post subject: flex hose mandrels |
Gee why didn't I notice that?
Pappy
Posted: Sat Mar 10, 2012 8:33 am Post subject: flex hose mandrels |
LOVE THAT ONE!!!!!!!!
Posted: Sat Mar 10, 2012 8:36 am Post subject: flex hose mandrels |
Good questions.
On Mar 9, 2012, at 8:06 PM, "Roger Kemp M.D." <viperdoc(at)mindspring.com> wrote:
Doc
> units/sensors.
> Bear
Posted: Sat Mar 10, 2012 8:43 am Post subject: flex hose mandrels |
On Sat, Mar 10, 2012 at 8:28 AM, <KingCJ6(at)aol.com (KingCJ6(at)aol.com)> wrote:
| Quote: | Any way to work MMO into the new thread?
No, not unless the topic passes through fuel imbalance first. A proper statistical analysis will show the acceptable order and transition of topics. And I think we are about due to revisit the downwind turn as well.
3191 Western Dr.
Posted: Sat Mar 10, 2012 8:44 am Post subject: flex hose mandrels |
| Quote: | | Quote: |
But then I thought better of it. While I like to talk about the design of engine monitors (yes, I have designed one) I am not sure anyone else *really* cares. Have a great day!
3191 Western Dr.
Epistaxis
Posted: Sat Mar 10, 2012 9:12 am Post subject: flex hose mandrels |
Was the synthetic vision over kill for these airplanes? I would like it but in a yak that really doesn't go far, is it worth the extra money?
Brian, send me a copy of the yak list itinerary. I've misplaced mine.
Doc
> units/sensors.
> Bear
Posted: Sat Mar 10, 2012 9:40 am Post subject: flex hose mandrels |
On Sat, Mar 10, 2012 at 9:09 AM, Bill Geipel <czech6(at)mesanetworks.net (czech6(at)mesanetworks.net)> wrote:
| Quote: | --> Yak-List message posted by: Bill Geipel <czech6(at)mesanetworks.net (czech6(at)mesanetworks.net)>
I think that is a personal preference. I find an iron-gyro panel with a simple VOR/ILS receiver to be simplicity itself and amazingly low workload but it requires discipline to maintain the "situational awareness picture" in my head. The more often I fly, the easier it is to do. I suspect that, the less IFR you fly, the more useful synthetic vision becomes. YMMV.
Just do a search from the web site and pick up the dates. It'll only take a few minutes to compile the list yourself.
3191 Western Dr.
Posted: Sat Mar 10, 2012 4:37 pm Post subject: flex hose mandrels |
Dawn. Soft hands while turning it thru.
I thought Jill, G. coy and Doug said they had them. Which part didn't translate properly?
On Mar 10, 2012, at 11:53 AM, "Epistaxis" <ShawnJBurwell(at)aol.com> wrote:
Wasn`t goining to say anything BUT!!! Since you brought it up, Thanks for pirating the topic [Shocked] Now that you have your sensor problem in check how bout helpin find those elusive mandrels Oh, by the way what kinda prop wash do you guys use..........(new thread) Shawn
http://forums.matronics.com/viewtopic.php?p=368118#368118
