Pat Reilly
Posted: Thu Mar 01, 2012 8:14 pm Post subject: Warning Regarding 4130 Tube Sources |
Kitfoxers, Wicks Aircraft bought out Dillbacks when they closed. Dillbacks 4130 supplier was China I was told by a reputable source close to Wicks.
Pat Reilly
Mod 3 582 Rebuilt
Rockford, IL
On Wed, Feb 1, 2012 at 5:27 PM, Noel Loveys <noelloveys(at)yahoo.ca (noelloveys(at)yahoo.ca)> wrote:
For those of us interested in aircraft
Noel
From the fly soob list.
Hello All!
Recently I have purchased a good bit of 4130 tube. Here at Thunder Aviation
we
test every batch of material we will be using and have
had some very disconcerting results. This particular batch came from a major
supplier of aircraft products. Once it was unloaded we took several random
samples and performed pull tests with shocking results. So we then pulled
several more samples for x-ray. We received 4130 chrome moly with as many
as 18
inclusions per inch! This is without a doubt junk material. We had a
similarexperience from a second major supplier and a nightmare issue with
some
5052 aluminum that would barely weld. The problem with the chrome moly is by
looking you would never have realized a problem. Without testing I wonder
how
much of this material is out there flying around now?
My best advice folks is to require a supplier to certify country of origin
when
ordering such materials. And only accept materials from the US and Germany.
We
have found no issues with materials from these two countries.
Tom Parker
Thunder Aviation
http://thunderaviationengines.com
arget="_blank">http://www.matronics.com/Navigator?Kitfox-List
tp://forums.matronics.com
Pat Reilly
Mod 3 582 Rebuild
Rockford,IL
